ball bearing 25# boost - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-05-2006, 08:07 PM   #1 (permalink)
Installed garrett ball bearing turbo the other day. Was hitting 25 #s of boost with the stock turbo, the new one is only hitting 25 #s as well. Does this seem right or should I adjust the wastegate rod.
02 f250, Dp tuner 4 bank chip, afe stage 2, mbrp ss 4", sonnax valve,Garrett ball bearing, Dieselsite boots, dieselsite blow off valve, snow stage 2, oil pressure crossover line, 203 thermostat, 6.0 trans cooler, dieselsite air conditioner bypass, evans coolant, autometer gauges, ams oil, warn hubs, powerslot rotors.
davidboaz is offline
Old 05-05-2006, 08:14 PM   #2 (permalink)
thuglike's Avatar
Re: ball bearing 25# boost
If you want more boost= add fuel. Bigger fuel tunes on the chip, injectors or propane. Switching a turbo will not add boost. OR Do you believe you should be over 25 lbs. of boost with your current set-up, and think there is a problem?
'00 F-250 X-cab 4x4: Powered by DI PERFORMANCE
Best run to Date: Spring Fling-706/1400- ALL FUEL/ 12.21 @ 110.45 Diesel Nationals (all fuel)
thuglike is offline
Old 05-05-2006, 08:21 PM   #3 (permalink)
I have a 120 hp setting with the dp chip, thought if i could squeeze 25 out of the stock one i should get atleast 30 from a ball bearing one. Maybe i need to get a chip reburn.
Old 05-05-2006, 08:23 PM   #4 (permalink)
thuglike's Avatar
You should be over 30 lbs. with that chip. Check all the connections for any boost leaks, plug the red wastegate hose and let it rip, see what you get.
thuglike is offline
Old 05-05-2006, 08:23 PM   #5 (permalink)
My Photos: (22)
the 25 psi out of the BB is moving more air through your motor than the 25 out of the stocker. That being said...don't be surprised if you have a boost leak also.
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
Old 05-05-2006, 08:32 PM   #6 (permalink)
Boost leak? Thats funny you mention it, about two blocks into the test drive I blew one of the boots off. Heart sank into my lap for a sec thought I windowed the motor. Checked all the clamps on the boots anyhow they are all tight. I ll put two clamps on at every connection tonight.
Old 05-05-2006, 08:35 PM   #7 (permalink)
i had to adjust my wastegate a bit but i can nail 35# with mine in the 100 setting and just over 30 in the 80 setting.......and i experienced a boot blow off the cold side of the intercooler at about 33#........gets your attention thats for sure
96 f-350 2wd dually powerstroke roach coach 365k BTS tranny,4.10, XLT,alcoa alloys,tymar intake,western diesel downpipe, a/c bypass mod,coolant filter behind front bumper, beans stage 1's,dp tuner 60hp pcm, hx hardline crossover from ITP......
01 f-350 dually powerstroke lariat supercab 61k 4.10 4x4 ESOF, leather, heated seats all the toys i dont need, 4r100,garret ball bearing turbo,tymar intake, ccv redirected out under the truck,magnaflow 4inch tuner exhaust, a/c bypass mod,zoodad mod,autometer cobalt pyro boost and tranny,dp tuner 4program chip,ITP complete regulated return fuel kit,ITP hx crossover hard line,203 t-stat and dieselsite billet t-stat neck, coolant filter,dieselsite high pressure intercooler boots
2009 F-450 dually 6.4 auto 4.30 2wd XLT power pedals,aux cab heater, dual alternators,bostonian catering body,stock everything for now......things to change soon
chris bottom is offline
Old 05-05-2006, 08:40 PM   #8 (permalink)
Man, everybody has missed the obvious question so far. Do you have a boost regulator or blow off valve in line to the MAP sensor? If you don't have a blow off valve or something then the engine will start defueling at 25psi and won't let you go past it.
Early 99 F250 PSD XLT, Ext cab Short box 4x4
Engine mods: CCV reroute, DIY intake using Green filter, 4" SS MBRP downpipe, 4" straight pipe exhaust, DP Tuner stock/40/80/120 chip, ATS BB turbo on the way, FASS fuel system
Drivetrain mods: FTVB, Suncoast SD43 TC waiting to go in.
Exterior mods: Putco billet grill, Owens fiberglass running boards, 265/75/16 MTRs
powerstroke73 is offline
Old 05-05-2006, 08:45 PM   #9 (permalink)
thuglike's Avatar
Good call!!!!!
thuglike is offline
Old 05-05-2006, 09:04 PM   #10 (permalink)
Sorry I knew I forgot to add the blow off valve in the sig. I do have one. I just plugged the red tube going to the wastegate and hit 29#s boost. Is it okay to leave it this way? Also the ses light came on, I dont have a reader with me.
Old 05-05-2006, 09:07 PM   #11 (permalink)
I didn't
02 f250, Dp tuner 4 bank chip, afe stage 2, mbrp ss 4", sonnax valve,Garrett ball bearing, Dieselsite boots, dieselsite blow off valve, snow stage 2, autometer gauges, ams oil, warn hubs, powerslot rotors.
The reason his boost is the same is I think he still has the wastegate hooked up.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 05-05-2006, 09:41 PM   #12 (permalink)
Yeah, of course its there now. You know this place has an edit feature for signatures [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
