Banks Big Head - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-19-2009, 02:02 AM   #1 (permalink)
CHILLLS's Avatar
Banks Big Head
how bout it what do you think of the big head?
going to put this on with the wheel
02 7.3l psd 6 spd 4x4 cc lb srw
cut muffler
afe stage 2 pro guard 7
wicked wheel
superchips programmer
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
viair 480c compressor
5 gal. tank running 200psi
train horns
firestone bags
piaa supper white head lights
70 gallon in bed tank
warn semi hidden winch mount
warn 12,000 winch
piaa 4" smr fog lights
thats it for now but more to come
CHILLLS is offline
Old 11-19-2009, 02:18 AM   #2 (permalink)
Do it. Works well.
2000 F250 7.3L Auto. CC 4X4 Lariat SB, 3.5 Fab Tech lift, 16X10 Typhoons 305/70/16 BFG's, AFE Stage2, Banks Big Head, Banks Exhaust, Bellowed up-pipes, Quadruple gauges, Wicked Wheel, Trans Go shift kit, Eaton TrueTrac, DP-Tuner F5, Stock, 60T, 60E, 80E, 120R.
JamieWS6 is offline
Old 11-03-2010, 03:54 PM   #3 (permalink)
aklim's Avatar
I would be so hot for Tyra Banks.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 11-03-2010, 08:32 PM   #4 (permalink)
Compared the Banks to the Turbo Master actuator when needed a replacement. Went with the Turbo Master and have no regrets
02 PSD Lariat CC DRW, 4X2, A/T, 4:10, Big Tex grill guard ,115 gal in bed fuel tank (switch on the go) ,5er notched in bed tool box, Reese 5er/gooseneck/bumper hitch, 20K fan powered under cab tranny cooler, AFE intake, Super chip, TC lock up, Gear vendors exhaust brake, 4 inch turbo back exhaust, oil/water/egt/boost/tranny/diff guages, CB radio, Back up camera, Air bags (inside cab control), Mag-hytek tranny/diff pans,, Ram tough computer stand, FS2500 Aux Oil filter, Turbo life saver, Turbo Master wastegate actuator
Fordpowerstroke350 is offline
Old 11-03-2010, 11:27 PM   #5 (permalink)
ScaldedDog's Avatar
I did the same thing, though I just got the Turbo Master in. How far in did you adjust yours, and where did you set it?
Mark
''Wise men talk because they have something to say; fools, because they have to say something.'' - Plato
2001 Excursion 4x4, v-codes, Western Diesel guages, DP-Tuner, ATS housing, AIS with fender sleeve & zoodad, MBRP 4" exhaust, Tru-Cool Max tranny cooler, 203* thermostat, BFG AT 285/75-16's, RS9000X's, Rancho steering stabilizer, tightened steering box, Hellwig sway bar, Air-Lift springs and compressor, Draw-Tite trunnion bar WD hitch, SUVlights.com harness, PIAA driving lights with homemade harness, Cobra 25STWX radio
ScaldedDog is offline
Old 11-04-2010, 12:39 AM   #6 (permalink)
I want to and will go Turbomaster when the funds allow for that particular upgrade. When you guys installed it what did you do with the red line, just leave it hang and plug it or snip it off shorter and then plug the leftover line?
2002 7.3L PSD F-250; 4x2; Crew Cab; Short bed; 3.73; {Autometer Pyro, Trans Temp, Boost}; {Tekonsha P3}; {Updated CCV Mod at 174k}; {New Ball Joints; Tie Rod Ends; Drag links; Dieselsite Coolant Filter, billet thermostat housing, 203* thermostat; Fleetrite ELC; Bilsteins from CaryT at 126k}; {Airtex water pump; Rear pinion seal; U-joints and carrier bearing at 146k}; {Dieselsite Motor and Intercooler boots, External Trans Filter, HP Oil Xover hard line, AIH Delete with Boost mod at 158k}; {Amsoil BMK21 Bypass Filter at 174k}
rosspulliam is offline
Old 11-05-2010, 09:54 PM   #7 (permalink)
I just used the suggested factory setting and this increased my boost pressure from 17 inches up to 22 inches. Could "tune" it a bit especially if used with boost fooler I suppose. Just plugged the red line with the ball furnished and tied up line so it is still there if needed sometime.
Old 11-06-2010, 12:02 AM   #8 (permalink)
Been running the Big Head for about the last 8 years. Set it where they said and forgot it. That along with the Banks 1.0 exh housing and Banks WW makes for 32+psi regularly.
2000 F250SD SCLB Lariat 4x4
.030 over Mahle pistons, fully studded, modified.
4R100 built by me with Suncoast/Transgo/Sonnax/Ford parts.
325/65/18 BFG A/Ts on Ultra rims, custom 4" lift with rear shackle flip(no blocks), Rancho 9000Xs, Homemade bypass fuel system, bypass oil filter, Racor CCV filter, 3.5/4/5 custom exhaust, 8 yr old DI 4 pos chip, and some other stuff.
22 year US Navy vet (retired)
ASE Master Auto Tech
My Pics (Webshots)
http://s414.photobucket.com/home/Stangrcr72
stangrcr1 is offline
Old 11-16-2010, 10:27 AM   #9 (permalink)
Did the same thing back in 02 truck has 112k and never had a problem turbo or intake related.
2011 F450 K/R ALL Stock and staying that way
2001 F250 Lariat. BTS, DP Tuner, Banks inter-cooler, Banks Turbo upgrades, Banks Exhaust, Banks Exhaust brake,
edinning is offline
Old 11-16-2010, 12:27 PM   #10 (permalink)
aklim's Avatar
I have used Boostvalve Home when I had a turbo car and it worked well. Only lets the wastegate open when it reaches a preset value instead of opening gradually. Makes the spool up much quicker or at least it did on the Merkur XR4Ti
aklim is offline
