banks power pack HELP - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 03-16-2008, 03:45 PM Thread Starter
Just installed banks power pack except the ottomind . I took it for a test run and very little power . Is this because of the ottomind not installed or something else. I thought i would be able to do this job but 3 days into it and I'm at witts end. Also the pyrometer is not working. I hooked it in line without drilling the air manifold I don't know the directions were poor to say the least. I know I am rambling but if anybody can help. I would appreciate it.
vanbruntg is offline
post #2 of 19 (permalink) Old 03-16-2008, 04:28 PM
dondiesel444's Avatar
sorry you learned the haed way, but Banks products are very overrated, I will go on record as far and say Banks Sucks. I guess that "ottomind" may help, thats their "chip" correct? but you best be would be to get a DP Tuner. sorry....
2001 F-250 PSD Crew Cab short bed, 4x4 Lariet, only 97k miles bone stock for now
previous trucks:
2001 F-250 PSD CC SWB 4" lift, 315's, DP Tuner..
late '99 F-350 PSD CC LWB 4" lift, 315's, DP......
early '99 F-250 PSD SC SWB short shifted 6-speed, 5" stacks, 5.5" lift, 4.30 gears, DP Tuner, etc....
1997 F-350 PSD 4x4, 4" lift, 35's, Superchips tuner
dondiesel444 is offline
post #3 of 19 (permalink) Old 03-16-2008, 06:03 PM
It is because of something else. It should have the same power as stock without the chip installed. I'm not sure what you did with the pyro but it should go it the exhaust manifold. Where did you get your instructions? All the instruction's I've seen are very clear.
444-4D is offline
post #4 of 19 (permalink) Old 03-16-2008, 07:05 PM Thread Starter
maybe i miss spoke the boost gauge is not working.
post #5 of 19 (permalink) Old 03-16-2008, 07:30 PM
JUSTING's Avatar
where did you hook up the boost gauge
Early 1999 (4/98) f-250 superduty, 4x4, crewcab, shortbed.
knn intake
banks exhaust
banks turbo housing
banks power elbo
big head waste gate-disconnected
edge juice w/ attitude (just till i get a DP)
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
automatic tranny
ranch hand front and rear bumpers
pro comp 2.5 inch leveling kit w/315/75R16
JUSTING is offline
post #6 of 19 (permalink) Old 03-16-2008, 07:37 PM
If the hose from the manifold to the map sensor isn't connected, you won't have any power.
444-4D is offline
post #7 of 19 (permalink) Old 03-16-2008, 09:01 PM
if everything is not hooked in right the banks kit will not en-gauge any additional fueling.
it has a saftey that the truck has to be warmed up before it fuels...it does it by the pyrometer amongst other sensors prob boost too. if that isn't installed right it no worky...
early 99 f350 4x4 crew cab
work in progress
southmike is offline
post #8 of 19 (permalink) Old 03-16-2008, 09:12 PM
JUSTING's Avatar
sounds like you may have a boost leak
double check all your IC clamps and make sure they are tight, check the clamps and boots on the intake manifold.
did you put the red hose back on your waste gate?
is there a kink in the boost line going into the cab?
knn intake
banks exhaust
banks turbo housing
banks power elbo
automatic tranny
JUSTING is offline
post #9 of 19 (permalink) Old 03-16-2008, 09:29 PM
deltadrummer1's Avatar
Amen to that. When my boost hose blew off my inline T fitting to the MAP sensor after installing my DP-Tuner, I lost almost all power.
Check it 1st.
2001 E-350 15 passenger 7.3. New motor: .030 over, ceramic piston tops w/teflon skirts, 16.1, hypermax rods-springs-fire rings, crower push rods, main girdle, h-11 headstuds, ported heads, srp1, 250/100's, 38r, regulated return, walbro pump, ceramic manifolds, ceramic bellowed up-pipes, DC Power 190alt, FluidDampr, BTS Transmission, Precision Torque Converter. On the way: Eaton TruTrac and CalTracs.
deltadrummer1 is offline
post #10 of 19 (permalink) Old 03-16-2008, 09:33 PM Thread Starter
I used the map line for the boost . I thought I had all the clamps tight, but I'll check them in the morning. I rechecked the boost line through out the truck and in the cab seems ok.
post #11 of 19 (permalink) Old 03-16-2008, 09:34 PM Thread Starter
by the way it is a 2001 f-250 cc 7.3 4whhel drive short bed.
post #12 of 19 (permalink) Old 03-16-2008, 10:20 PM
He said the part that adds fuel hasn't been installed. He also said he is using a Power Pack.
444-4D is offline
post #13 of 19 (permalink) Old 03-17-2008, 01:27 AM
Layson's Avatar
My Photos: (28)
You could have kinked the boost line....?? You might want to check that...
One more thing is if you took it out for a drive or just went around the block... you won't see hardly any boost at all until you get on it..
01 F350 CC LB - 14" OUO 525 Series, 38x15.5 Toyo M/T's a 20x12 Weld Cheyenne's. BTS, Terminators, Hybrids...
Layson is offline
post #14 of 19 (permalink) Old 03-17-2008, 05:52 AM
Diezel Dawg's Avatar
The biggest problem was buying the Banks Power Pack, sorry, for bashing, but it isnt the best setup to get if u want power. U will see an improvement over stock, and u will like it. But u really need to look at getting a DP-Tuner, Tony Wildman or TS Performance chip. Most likely u have a kinked boost line, so check it out like everyone said. Good luck
Ken
99.5 7.3L PSD 4x4
WOP GQSSB TURBO
Tyrant Diesel Tunes
TYMAR Intake
Casserly 250cc Hybrid Injectors
BTS
496 hp 985 tq!! 16 Apr 11
13.74 sec in 1/4 mile @ 98.5mph
PNWFDE#2
Diezel Dawg is offline
post #15 of 19 (permalink) Old 03-17-2008, 05:35 PM
CSIPSD's Avatar
My Photos: (52)
The only thing that Banks does on the 7.3 for safety is not fuel the truck... Junk tuning...
Nothing has changed from the stock fueling tables, until EOT is up your power is down with any chip.
Your banks gauge, what "map" line did you hook it up to?
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
