Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
I live in temecula,ca anyone now of a good shop to have my trans command installed???
thanks
Big john
2003 F250 Lariat sd cc 4x4 7.3 long bed,4.10 srw,Edge Juice w/Attitude,AIS Intake w/mod,Zoodad,magnefine trans filter,trumax cooler,autometer tt,4" exhaust,4" DP,airbags,coolant filter,Banks Big Head Act.,Banks Compressor Wheel,fomoto drain valve,Racor 3550 ccv,Amzoil dual bypass with pre-oiler,Amzoil fluids for all,Brakesmart,8" Fabtech lift,37x17 parneli's on helo max rims,Fabtech Full floating traction bars,Rough country dual steering stabilizer,16k 5th wheel hitch,Billet grill,Line-x,Gaylord FG bed cover, Complete alpine dvd,nav,cd pushing 1750 watts!
my truck pics http://community.webshots.com/user/trxjunkie
Its really such a simple thing to do, you should do it yourself. It literally plugs in between the factory harnes. Just go buy a couple self drilling sheetmetel screws to use with an electric drill, mount it to your passenger side with these and plug the couple plugs in. It should take you 30 min once you get the drill out and pre-read the instructions. My wife installed mine while I was out of town....she's a keeper!
2000 Excursion 33,500 miles and counting!
Banks Big Hoss LVL 4, Banks 6-Gun, Banks Power-elbow
Banks Big-Head Actuator (set at 25 PSI), Banks Quick Turbo, Banks Compressor Wheel, Banks 4" Exhaust system but straight piped!, Banks Intercooler, Banks TQ Convertor, Banks Trans-Command, Westin Nerf Bars
Ultimate Bull Bar, Helwig rear sway bar, V-code springs, 2 HELLA 500 Driving lights, 2 KC Dayliters, Lights mounted on a custom home fabricated mount on the Ultimate Bull Bar.
285-75-16 MT Tires, Visor over windshield and rear air dam over hatch. Custom painted monochromatic in factory dark green. Amsoil 3000 Synthetic engine oil With AMSOIL EA Synthetic Filter and Amsoil Synthetic differential lube. Warn manual hubs.
I'm ready for a hook at the next truckpull!
Is the Trans Command worth the money? What are the trans codes to determine if it is an E4OD or the 4R100 tranny? I just bought an 01 F250 PSD and was wondering if the Trans Command or the FTVB
Their are two different Part#s for the E40D 62560 / 4R100 62570 it works great with OEM up to additional 80hp after that I would recommend TC & Pump upgrades with a commander or equivalent.
I really liked the difference it made on mine over stock. I had it on for about 3 1/2 years with no complaints. I recently got a BTS Valve Body and it is again that much better than the Transcommand. I would think that the FTVB would be better than the Transcommand and the BTS would be better than the FTVB. Brian will set the valve body up for your truck and adjust it to what you want plus you can fine tune it yourself with Brians help if you want to change anything or if you add more HP or something. Mine shifts nice and firm when I'm really getting after it but softer if I'm just cruising around. I have heard that the FTVB is pretty much real firm all the time. Like I said that's only what I have heard. I have no hands on experience with the FTVB. Hopefully HAMMER69 will see this thread as he has had both and is fairly knowledgable on this subject.
Thanks for the info. I want to add some perfomance mods when I get the truck in a few weeks. Plus we have a 30' trave, trailer that I pull so I wnat a tranny that will handle the mountains in Western North Carolina where I live.
You may want to seek out a few options for your tranny before you settle on the Transcommand. I had them on two seperate trucks and
they seemed to cause strange electrical problems when ever they got
moisture on or around them. Sounds strange, but true. You can probably
find a better product for less money as Banks tends to be VERY proud
of their products.
As far as being worth the money I would say they are overpriced. Considering the prices on the FTVB and the BTS the transcommand wouldn't even be a consideration. Go with one of the valve bodies. After reading many posts on this subject I've determined that adusting your line pressures mechanically is much better than doing it electronically. As far as installing a valve body, it is really easy. Less than an hour. The only thing about then Transcommand is it's not as messy.
BTW, How much are the Transcommands going for now? I paid less for the valve body last month than I did for the transcommand 3 1/2 years ago.
Prind, with your 4" exhaust, it's a pain in the a$$. I had to unbolt the heat shroud (all 4' of it), push it back, and try to contort my hand/arm up to get to the tranny connector. 5 minutes once you get the connector off. Then you need to reverse the heat shield uninstall.
The instructions look easy on a stock truck. Either that or my hands are too big. You know what they say about big hands? They don't fit in tight places. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Dave
__________________ LED running lights below doors for turn signals, marker lights, and courtesy lights from JadSolution
FOKISD (Ford, Ohio, Kentucky, Indiana, Super Duty Club), Charter Member.
2001 F-350, PSD, 4X4, True Blue, 152 WB, SRW, Auto Trans, Manual Hubs, PMT3, Off Road Package, AIC, Heated Excursion Tow Mirrors w/cut off switch, Extang Tonneau Cover, Westin Step Bars, Lund Bug Shield, Nifty floor mats, Custom rear bumper/w fog reverse lights & 3rd brake light, LED running lights below doors, Poron USA reverse backup sensors.
"It's mine,ALLLLL mine, (Till Andrea wants to drive it)"
My exhaust was still stock at the time I did mine. I can see what you mean now that I've looked at it with the bigger exhaust. One more reason to just do the valve body.
