For bellowed up-pipes- will the bolts come loose or do it cut them off? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-22-2008, 07:12 PM   #1 (permalink)
My Photos: (5)
I remember hearing that some suggested just cutting the bolts on the original up-pipes. I haven't really taken a good look yet, but was wondering if they will unbolt or just cut them.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 96,100 miles. truck Pictures
clydesdale is offline
Old 03-22-2008, 07:48 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
The ones at the exhaust manifold are thru-bolts and nuts. You might just be able to snap them off by tightening. Or cut them off. The ones at the turbo inlet are threaded into it, so those are a bit more problematic. If you have the turbo off, you could just get out the sawzall and pull the remnants out the top.
No need to worry about saving them by trying to unbolt, cause you have new hardware in the kit.
Hard or no-start? Check Here
klhansen is offline
Old 03-22-2008, 08:32 PM   #3 (permalink)
My Photos: (5)
That is what I wanted to hear. The turbo is coming out anyway. Thanks
Old 03-22-2008, 08:34 PM   #4 (permalink)
Spray the lower bolts and nuts with WD-40 everyday for a couple of weeks and they should come off fairly easy. If your pipes were like mine they will fall out of the collecter and if you really need the bolts take them out once you have the collecter off the turbo. The bellowed up-pipe kit comes with every thing you need to complete the job no need to save any of the old stuff.
2001 F-350 Crewcab shortbox auto, 4 in. exhaust, door-seal mod, zoo-dad mod, Alpine CDE 9870 to hook up the I-pod, Ford AIS, new bellowed up-pipes, harpoon and hutch mods, Reflex shocks.
cody40 is offline
Old 03-22-2008, 10:49 PM   #5 (permalink)
My Photos: (5)
Here ya go: Welcome to Pocket's International UP-Pipe Replacement Web Page
Pocket is offline
Old 03-23-2008, 09:25 AM   #6 (permalink)
My Photos: (5)
I forgot about that right up. Great job Pocket, much appreciated.
