Best Cold Air intake? - Diesel Forum - TheDieselStop.com
Closed Thread
post #1 of 29 (permalink) Old 05-15-2011, 07:33 AM Thread Starter
Just purchased my '03 F250 SD 7.3 and want to purchase the best intake for it (HP, Torque, and gas mileage) but don't know who the best truley K&N, Banks, AEM, AFE,or Airraid. Please advise. cost is not a factor. Thanks
M.Vespie is offline
post #2 of 29 (permalink) Old 05-15-2011, 08:35 AM
You aren't going to get any more HP, torque, or fuel mileage from any of them. If you don't mind some noise, the Banks system is the best. If you want a quiet system that filters better than anything else, get a Ford AIS.
444-4D is offline
post #3 of 29 (permalink) Old 05-16-2011, 10:06 AM
My Photos: (6)
Send a message via Yahoo to zrainha25
i got the tymar intake. 90% of people on this site has the tymar system in there 7.3s. theirs DIY clones too. search tymar intake and there will be tons of threads
black 99 f250 XLT
7.3, 190,000 miles
450 springs front and back
tymar intake
Tranny, EGT, Boost, Glowshift Gauges
4 in exhaust, 6in tip
DP tuner F5 chip, 80 eco, 120 race, 40 tow, stock
2004 head lights
Alpine head unit
Alpine Speakers
Kicker amp
Kicker 12in Sub
whelen strobe
8ft fisher... for now
pictures in my profile
zrainha25 is offline
post #4 of 29 (permalink) Old 05-16-2011, 06:53 PM
Feedback Score: 3 reviews
banks the best...ok
You will free up HP, TQ and MPG's with a free'r flowing intake just as you will with a exhaust system..
The best air filter system period is a Tymar nothing will out clean and out flow one. We sell them and use them.
caryt is offline
post #5 of 29 (permalink) Old 05-16-2011, 07:05 PM
mustangii's Avatar
1st choice tymar 2nd oh wait thats tymar too
1996 f250 crewcab auto trans 4.10 gears 4x4 7.3 ts 6 pos -idm mod -a real tymar intake -3in dp -4inch mbrp exhaust -3 guages -a big trans cooler
-coolingmist water methanol injection -baby swamps and custom tunes by swamps. will it ever be enough?
towing a 2003 keystone sprinter 5th wheel 33.7 ft
mustangii is offline
post #6 of 29 (permalink) Old 05-17-2011, 07:09 AM
The company that makes the Tymar filter says the filter in a Ford AIS system will flow more air and clean better. And besides the OP asked about a cold air intake. The Tymar is not a cold air intake.
444-4D is offline
post #7 of 29 (permalink) Old 05-17-2011, 10:40 AM
rammertide07's Avatar
Send a message via MSN to rammertide07
I would like to see a poll of who is running tymar and AIS and their experiences. Along with information about how long they have been running their set-up, longevity (what enviroment are they in?), changes in EGTs, etc... . A really good comparisson would be someone who has ran both.
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #8 of 29 (permalink) Old 05-17-2011, 02:27 PM
444, you keep posting this and that you have the proof..I keep asking to see it..
The AIS will provide excellent filtration efficiency, but will not improve overall restriction or allow much additional air flow in the configuration that Ford uses. The Tymar Intake will provide excellent filtration efficiency as well as decrease restriction to the turbo and add significant air flow.
quote:
“Tymar is going to give you better flow but AIS is going to give you unmatched filtration…the AIS plus it will last a LONG time, like 60K miles…”
Although the AIS will give better filtration efficiency, you are only talking about 1/10 of a percent over the filter Tymar Performance Intakes use at initial filtration efficiencies. Not enough of a difference to really differentiate between the two.
For the longevity, you have to start talking about restriction ranges in both stock and aftermarket applications and how dirt will affect them. AIS has a larger capacity, but not across the restriction ranges once installed on the truck. Because of the configuration you are not lowering restriction significant over stock levels, but you are receiving better filtration compared to the stock intake.
The Tymar Intake will allow lower restriction levels and lasts approximately 15K miles in a restriction range LOWER than stock. If you want to go with longevity of filter, you can continue using the same filter and will simply not experience the positive benefits of lower than stock restriction levels.
The problem with heat shields and routing air through intake boxes is that whenever you direct air flow, you increase restriction. Low restriction is the goal, so using a filter that has the ability to flow large masses of air and then enclosing it in a box yields very poor results. Heat shields do literally nothing. Air flow under the hood is dynamic and not static. It is moving all the time. Hot air will move right around a heat shield at the same temperature and be ingested and the only thing you have caused is turbulence.
Aside from impeding minimal radial clearance and isolation of engine vibration, a serious cause for concern is placing the filter, especially a 6637 element, under a rain drip channel for the hood. Beyond the ambient moisture that will cause restriction as it is absorbed into the non-hydrophobic media, you will be directing water towards the filter anytime the rain drip channel flows more rain than it can hold or spills over the retainer during left turns.
caryt is offline
post #9 of 29 (permalink) Old 05-17-2011, 03:05 PM
IIRC, the stock engine requires 450-500 cfm to run. If a heat shield is properly sealed, how does hot air move around it? With air moving at that rate, I don't see how the heat from the engine bay could have a significant air temperature affect the the intake. Do the zoodad mod and its pretty "dynamic". And filtration is what mainly restricts air flow, so its only 1/10 difference in filtration? And I've heard of several people that run the AIS with aftermarket tuner that say the filter gauge does not get sucked down.
post #10 of 29 (permalink) Old 05-17-2011, 05:13 PM
This thread inspired me to do a little experiment, I took my AIS off and reinstalled my DIY (with the hydrophobic Donaldson), I have to say I don't see how the AIS is outflowing that open element without modifications to the AIS. I don't have a zoodad or fender sleeve mod, just a stock AIS, and it has been just great, but my truck seems a little chippier with the open element. I guess it's possible it's placebo, but the SOTP dyno says otherwise. I may do the fender sleeve mod and see if that makes any difference, but I'm still on the fence.
I have noticed a tiny bit easier starts on hills in first gear with the DIY back on in place of the AIS, and I am now planning on running 4 full tanks through with the DIY and then back to the AIS for 4 more full tanks to see if there's any difference.
Either way, the AIS or DIY/Tymar are great setups as long as the open filter is the correct one, I wouldn't just use a Napa filter that doesn't resist water, but that's me and I live in a rainy climate.
JasonL is offline
post #11 of 29 (permalink) Old 05-17-2011, 05:16 PM
Henry Bowman's Avatar
I went with the Ford AIS about 40K miles ago (at 102K now) and have been happy with it. Turbo vanes on the intake side are pristine, no dust in the intake, and with a moderate tune running (DP Tuner 80E) I can romp on it all I want and the filter gauge never moves. Plus it is no louder than stock. Some people like loud, I am not one of them. The only downfall I can see is that when it is time to replace the filter element, it will cost about $100. Ouch.
If I were to spend a bunch of $ on a high performance HPOP, injectors, bigger turbo, etc. in the pursuit of more ponies, I would probably get an AFE stage 2. I would also not expect the engine to go 400K miles either.
2008 F250 4X4 crew cab, 6.4 PSD, 3.73 limited slip, King Ranch, coolant filter, Gearboxz DPF-R+ 4.0
RIP: Totaled 8/17/16. Best truck I ever owned: 2003 F250 Lariat 4x4 crew cab, 7.3 PSD, 3.73 limited slip, auto, oxford white and Arizona beige, 4" turbo-back stainless Magnaflow, Ford AIS, coolant filter, 3 gauges in overhead pod, CAT ELC coolant, ATS ported compressor housing, DP-Tuner F5 (decel, 65 tow, 80E)
The Toys:
Rage'n 2930-5GLX fifth wheel toy hauler (GVWR 13.5K)
Circle J bumper pull horse trailer
3 horses of questionable parentage
Henry Bowman is offline
post #12 of 29 (permalink) Old 05-17-2011, 05:38 PM
I have posted the numbers, that were provided by the Donaldson Engineer that did the testing, many times. You have seen those numbers yet you keep posting just the opposite. You can find it in the TSD archives or you can call Donaldson and ask them.
Perhaps you have some data that shows Donaldson doesn't know how to test their own filters, lets see your data. Or perhaps you are just making stuff up to be the way you want it to be because of what you sell.
Maybe you could sell both items then it would be easier for you to grasp the facts. BTW a Tymar isn't a cold air intake.
444-4D is offline
post #13 of 29 (permalink) Old 05-17-2011, 06:01 PM
I have a Jobeperformance Jobe Performance - Home Page and I love it. With a banks bighead on the stock turbo and a dp-tuner set at 80econ. and banks 4 inch exhaust I get 27-30psi. of boost. They use a S&B filter thart flows 1100 cfm. Matt
Matthew Harris is offline
post #14 of 29 (permalink) Old 05-18-2011, 07:31 AM
I think this is one of the problems. I don't see too many other vendors on here pushing their product on to buyers. I understand the wanting to make a buck and get your name out there, but I like to hear customer reviews vs a sales pitch. Is there a "best" filter/CAI? Sure...just depends on who's buying it.
I have an AFE stage 1.When I took my 1.5yr old turbo off to install the WW, the stock wheel had chips in the blades. Thats why I'm wanting to go to a batter filter. And I think you can get the filters from Tonsley (spelling?) for $60.
post #15 of 29 (permalink) Old 05-18-2011, 02:43 PM Thread Starter
Thanks for all the input. I'm going to do some research on the Tymar intake. Honestly I haven't heard much about them. Thanks again Mat
M.Vespie is offline
Closed Thread
