best filter set up for a 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 01-10-2008, 10:57 PM Thread Starter
My Photos: (5)
I want a filter for my truck and i was wondering what yall thought about them. My truck is all stock except for smoke stacks. I dont have a chip, i just want a intake to help the milage a little. Im leaning toward the k&n pod style filter.
thanks!
2002 7.3 powerstroke diesel lariat, automatic, crew cab, long wheel base F-350 SRW. 35" mud brutes, 6" procomp lift, custom tool box, 5" smoke stacks, brush guard and an oil leak <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
yamahajo is offline
post #2 of 12 (permalink) Old 01-10-2008, 11:24 PM
Re: best filter set up for a 7.3
If you mean AIR filter, probably the best is the Ford AIS. You can get it for $200 at http://www.powerstrokeshop.com who is also a sponsor of TDS. Much more air, much higher / finer filtration.
You can also make one yourself with the right Baldwin filter and some fittings. Look up the do-it-yourself "DIY intake" or "DIY Tymar" or "Tymar setup" with the SEARCH feature on this site. It'll run you about $50.
After that, you'll have to go with the aFe Stage 2 with the good filter (can't remember the name), and it will run you $400-500. Don't get the cheaper setup of the Stage 2 with the lower quality filter.
Tailgate
1) 2000 Excursion PSD Ltd, 4x2, Dark Green, DP Tuner, Autometer gauges, AIS w/ Zoodad, ITP HP/X, Walker BTM, Dahl 100, Coolant Filter, 203 Tstat, Billet Tstat Housing, AIH delete, Hellwig swaybar, KYB shocks, Amsoil Bypass / fluids, Hutch Mod
2) 2000 Excursion PSD Ltd, 4x2, Chestnut, BTS Tranny, DI 4-Way Chip, AutoMeter CF gauges, AFE intake, Magnaflow 4" turbo back, Wicked Wheel, HP/X Crossover, KYB shocks, Hellwig rear swaybar
3) 99.5 F250 CC SB PSD XLT, 4x2, 3.73 LS, aFe Stage 1 intake, Zoodad mod, 4" turbo back exhaust, Amsoil
Tailgate is offline
post #3 of 12 (permalink) Old 01-11-2008, 12:06 AM
OOPstroker's Avatar
You can get the Donaldson filter through Amsoil for less than $40, I've got 2 PVC fittings and the filter and don't have any complaints other than it's a little noisy in the cab, a little noise suppression cloth stuff should take care of that.
OOPstroker is offline
post #4 of 12 (permalink) Old 01-11-2008, 12:07 PM
Feedback Score: 3 reviews
Never use a K&N. Bets is either a Tymar or Fords AIS period. All the rest are second and just add bling and lighten your wallet.
Cary
caryt is offline
post #5 of 12 (permalink) Old 01-11-2008, 02:44 PM
hands down afe Stg. II with the dry filter!
96 obs c/c l/b suncoast billet auto DP chip afe stg 2 afe 4" isspro gauges adrenaline hpop 6"lift 37" boggers clear head/tails/3rd brake/apc clear cab lights
01 s/c l/b 4x4 6spd. DP chip afe stg.2 afe 4" centerforce dual friction
smokerstroker is offline
post #6 of 12 (permalink) Old 01-11-2008, 03:50 PM
2U2Z9K635AA Each $198.19
7.3L Power Stroke Diesel AIS Severe Duty Filter Kit FA1759
http://catalog.powerstrokeshop.com/p...&siteid=214083
If you want the absolute best that you can get for your application, then Ford AIS part# FA1759 is what you want.
The AFE costs around $400 and would only be any advantage at all if you have lots of modifications to make around 400 or more hp.
If you can't afford $198 for the AIS, then some type of diy tymar is the next best thing.
http://rides.webshots.com/photo/2427...89393685lCUeep
Here is a series of photos that show a simple way of doing it. There are a lot of variations on exactly how to do it.
Here is the filter that you use. Order from fleet filter.
Wix # Napa # Description Price
46637 6637 Air Filter $27.33
http://www.fleetfilter.com/SearchResults2.asp
You can use PVC pipe or exhaust 4" pipe plus a couple of clamps.
Don't use K&N filters. They have been tested and found to let in tremendous amounts of dust that quickly destroy your turbocharger.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 170,000 miles, repairs so far: starter, batteries, cps, brakes, tires.
DonWarkentin is offline
post #7 of 12 (permalink) Old 01-11-2008, 06:15 PM
Ford AIS
Early 1999 F350 SC XLT
2/98 Build
SRW, 4x4 ESOF, 6 Speed,
DP F5 Tuner 60 Tow, 80 Economy
Ford AIS, DiPricol Gauges
6.0 Intercooler
EBPV Delete
NCHornet's CCV Mod
ITP Fuel Tank/Pre Filter Kit
ITP Regulated Return Kit
KCM SS HPX Line
Power Slot Cryo Rotors
Hawk LTS Pads
4" MagnaFlow Stainless Exhaust
2004 Headlights/Corner Lights
Monroe Reflex Shocks
Michelin LTX/MS
B&W Turnover Ball Gooseneck
37Driver is offline
post #8 of 12 (permalink) Old 01-16-2008, 07:26 PM
Send a message via AIM to Bobby77ss Send a message via Yahoo to Bobby77ss
Before I came on here and learned of why not to use a K&N filter, I had the K&N FIPK system. The air box that comes with it and the tube that it provides to replace the rubbery flex tube stock garbage are second to none, if you can find one used on ebay, do it then do what I did and get the Napa 6637 Filter like the DIY or the Tymar, that way you get the best of both worlds. My system will outflow the tymar and still won't sandblast the turbo like a K&N
1996 F-350 7.3 2WD Crew Cab Dually. 128,xxx miles, 2nd owner, PO was Lead Diesel Tech @ a ford dealer with flawless maintainence records.
K&N FIPK2 Cold Air Intake - Now with Napa Paper Filter, no more sandblasting my turbo wheel!
Diesel Turbo Lifesaver
Brite Box
4" MBRP with Missing kitty, no muff and 3" downpipe
Upcoming:
EGT, Boost, Trans Temp Gauges
99-03 intercooler *acquired*
with GTS or banks install kit
CCV Mod
EBPV into DIY Jake Brake
Custom Chip
D66
Built Trans
Bobby77ss is offline
post #9 of 12 (permalink) Old 01-16-2008, 07:34 PM
fxdwgi's Avatar
Originally Posted by 37Driver View Post
Ford AIS
I 2nd that.....
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
post #10 of 12 (permalink) Old 01-16-2008, 07:46 PM
demoes4x's Avatar
Another vote for AIS
EARLY 99' F350 7.3 CC 4X4 LB. DRW. FABTECH 3.5" LIFT - AUTOMETER BOOST, PYRO, TRANS, WATER, OIL TEMP, FUEL & AIR PRESSURE - WW2 - AIS INTAKE - 4" SS MBRP TURBO BACK - JOHN WOOD TRANS - RIFFRAFF BOOTS - 6.0 TRANS COOLER - CCV MOD - PROVENT 200 - DP TUNER NO TART, STOCK, 40T, 60T, 60E, 80E, 120 RACE - DIEHARD PLATINUM BATTERIES - 35" BFG A/T - FOX RESEVOIR SHOCKS - UPGRADED POST 99' 10MM HUB ASSY'S - SLOTTED BRAKE ROTORS - EBC YELLOW STUFF PADS - MAG-HYTEC TRANS PAN & DIFFERENTIAL COVERS - ITP SS HP-X - ITP REGULATED RETURN - HEATER BYPASS VALVE - AIRDOG - DIESELSITE COOLANT FILTER - DIESELSITE 203* TS WITH BILLET HOUSING - DIESELSITE EXTERNAL TRANS FILTER - FUMOTO VALVE - DC PERF 190 AMP ALTERNAOR - ONBOARD AIR - HORN BLASTERS - AND LOTS OF 08'-13' LARIAT UPGRADES.
demoes4x is offline
post #11 of 12 (permalink) Old 01-16-2008, 07:59 PM
ponyboychris's Avatar
And another one...
2002 F350 XLT, 7.3L, 4x4, LB, SRW, Crew Cab, 3.73's, BTS Trans "BTS BUBBA" , 6.0 tranny cooler, DP Tuner
NS, stock, 60HP tow, 80HP econo, Autometer Ultralites on pillar & cubby, Ford AIS w/Zoodad, '08 Aluminum Diff. Cover, 4" MBRP Exhaust, Heated Tow Mirrors, Warn Premium hubs, AIH Delete, Go's Headlight Harness, IC Foil Delete, Homemade CCV mod. The Silver Bullitt
2006 33' Courgar 5'er W/4 wheelers in tow
2003
Explorer XLT - Mom's Taxi
1990 Honda - the 27 MPG daily beater
1967
Mustang FB on blocks - my other toy
ponyboychris is offline
post #12 of 12 (permalink) Old 01-16-2008, 11:30 PM
westvandude's Avatar
The Donaldson 6637 or Napa wasn't easily available, had to settle for the Fram CA6818 and it said "Duralite" on it. This old post TheDieselStop.Com Forums: Are all Tymar style replacement filters created equal? YES!!! seems to point out that whether this particular filter model is Wix, Baldwin, Fram, Donaldson... they're all the same one.
Anyway, I installed the Fram today (I'm no fram fan, haven't used their junk oil filters for years) and can't say I see any more boost or more noise as some people say but I just burned up the hill from my house. Haven't taken it on the hwy yet. Just a quick shakedown run.
Unfortunately Lordco Auto Parts - Home Page autoparts ripped me to the tune of $57cdn for it. Rip off artists. $1.69 for the 4" diameter white plastic pipe piece, $3 for clamp. Just cut the pipe piece to side and chamfered the edges a bit. Was a b*stard to get the pipe into the hard plastic/rubber of the filter. Had to hammer it in with a board on top. Real tight.
Prob my imagination... seemed to spool a tiny bit faster.
Anyone know what the wastegate actuator is set to open at (psi)? From what I've been reading it's adjustable. Which way is more, which way less?
Edit: After a good drive to work and back... the sound under boost isn't any louder than stock. But if you're on it for a while WOT and then snap the throttle pedal closed the turbo stall sound is incredible... it's probably 3 times as loud as OE air box. Sounds like a blow off valve. :-)
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
