best mods for 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 03-17-2009, 10:34 AM Thread Starter
best mods for 7.3
I own a 2002 7.3 and already have put on a k&n intake and a magnaflow dual exhaust, i had been using my dads superchips tuner for a while but he wants it back now, i was wondering what everyone thinks are the best mods to do now? i heard the edge evolution was a good programmer. also looking at injectors, waste gate actuator, bigger turbo
any suggestions?
7.3 stroker is offline
post #2 of 20 (permalink) Old 03-17-2009, 05:47 PM
Maintain's Avatar
STOP! do not start thinking injectors, turbo etc... until you understand that you have PMR's in that motor and unless you want to pull it to put better rods in... it's best, cheaper, and easier to just stick with a chip.
Anything is pretty much more powerful then that superchips... DP Tuner, Swamps, Tony Wildman, Diesel Innovations, Elite, Innovative etc all offer better custom tuning then that superchips.
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline
post #3 of 20 (permalink) Old 03-17-2009, 07:48 PM
tattoocharlie's Avatar
My Photos: (5)
id agree go easy,you do have pmrs,my truck has a bts chip,tymar intake exhaust,a few small mods.it runs great.i have considered stage one injectors,but if you play you might have to pay.so id say call cale at bts(brians truck shop)he can get you a chip that will wake up your 7.3,i promise.
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #4 of 20 (permalink) Old 03-17-2009, 11:05 PM
westvandude's Avatar
Get rid of that K&N air filter. There's plenty of stories with dusted motors running that air filter. The K&N flows lots of air because it's full of big holes if you look closely. Those don't stop dirt.
Get a good programmer like DP Tuner, upgrade the exhaust, put a shift kit in, tranny cooler, tymar or other intake, gauges, etc. Get what I got, you'll be pretty happy with it.
My next step will probably be replacing the HPOP with a pulse pump or something slightly better than the OE one. Then you'll have more top-end rpm pull on such settings as 120race and 140aggressive. Even the 80Econo setting would benefit from more injector oil pressure on WOT.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
post #5 of 20 (permalink) Old 03-18-2009, 12:21 AM
Send a message via AIM to blizzardwarrior7
If you have a full K&N intake system you should be fine....The problems are with the drop in filters, which don't seal correctly in the box, thus dusting your turbo...I had it happen once myself:).
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
post #6 of 20 (permalink) Old 03-18-2009, 01:09 AM Thread Starter
thanks for all the info guys, i have the complete K&N intake, but i have heard before that people have had issues with it. my main problem is picking a chip/tuner, everyone i have talked to has recommend a different one
2002 f-250 7.3 180,000, K&N Intake, Dual Magnaflow exhaust, 4" exhaust turbo back, 5" stainless steel tips, muffler delete, Pyrometer and boost and Trans Temp gauges, bts chip high idle, 40 tow, 80 econo, 120 aggressive, 120 smoke, wicked wheel, AIH mod, leveling kit, BF Goodrich 315, LED Lights all around
2000 f-350 7.3 55,000 dump truck, super chips tuner
2005 f-350 6.0 50,000, SOLD!!!
2008 f-550 6.4 45 miles also stock for now, still have to assemble
1972 Mustang runs like a champ, but needs a lil body work
post #7 of 20 (permalink) Old 03-18-2009, 01:11 AM Thread Starter
what do u mean by PMR's?
post #8 of 20 (permalink) Old 03-18-2009, 01:52 AM
powderd metal rods. They are weak. The early 7.3's came with forged rods which are much better...
"Patrick Built" Engine is done.
99 F-350 6 Speed: Terminator HPOS, Scan Gauge, Custom Cam, R&R Rods, WOP Fire Rings, Fluid Damper, Balanced, Girdle, DI B-Codes, Reg Return, DI IC, DI Up-pipes, Southbend Con-FE, AFE Stage II, Autometer Sport Comp II, Garret 38R, H-11 Headstuds, FASS, Crower Valve Springs, Lots of Powder Coat, 35X12.50 Nitto Mud Grapplers.
Rockrunner86 is offline
post #9 of 20 (permalink) Old 03-18-2009, 08:04 PM
The chip tuners with remote-mounted switch like DP tuner are the only ones you can shift programs on-the-fly while driving vs most OBD tuners where you have to stop on the side of the road for a minute and upload a new tune (yes, there are some exceptions to that rule). Instant program changes are great for changing from economy to race mode at the light. Also, starting the motor when it's cold in the morning keeps it cackling a lot quieter on stock tune vs performance tune. Easier on the motor till she warms up. So... very useful IMHO.
post #10 of 20 (permalink) Old 03-18-2009, 08:16 PM
x2 on the DP tuner. Great, nothing bad to say about it, and much more power than any canned tunes.
post #11 of 20 (permalink) Old 03-18-2009, 09:11 PM
woodnthings8's Avatar
I also have a '02. I had a superchips tuner but i sold it because they do not support the customer. I have heard nothing but great things about DP Tuner. I have emailed Jody and he offers complete answers and lots of options. I am ordering an F6 in a week or two. BTS also has excellent customer service and they also have a chip that has many options. You need to get a full set of gauges if you don't already have them. If you have the 4r100 auto I would also get a 6.0 cooler. Get a trans temp gauge because the factory one in the 02 and later is a joke and will not tell you anything until you need to replace the trans due to overheat!
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #12 of 20 (permalink) Old 03-18-2009, 09:34 PM
My Photos: (5)
correct....bts or dp is the best way to fly!!!!!!!!!!
knock on wood....
4" exhaust no muff
post #13 of 20 (permalink) Old 03-18-2009, 09:58 PM
I used to have the superchips flashpaq, and I also had the microtuner, and the difference between either of those and the DP is night and day.
post #14 of 20 (permalink) Old 03-19-2009, 10:40 AM Thread Starter
I've narrowed my decision down to the BTS or DP, but if go with the DP should i only got to 120hp as my highest setting? and whats up with the whole 120hp with codes or just 120hp?
post #15 of 20 (permalink) Old 03-19-2009, 11:41 AM
Here is the infrom from DP-Tuners site. Basically the codes tunes don't throw the BS codes when you romp on it. It will give you codes when something is failing like a sensor. Also it will flash the SES light when you go beyond 23-25 psi which normally the truck will de-fuel and you will loose power until it gets below 24 psi or so. The SES light will go out in a mile or two once you let off, If this is annoying to you put in a boost fooler before the map sensor(easy and cheap)
DP info
120 hp Race- recommended for a stock Super Duty as the highest hp level with stock injectors. To utilize the full potential of the tune it is highly recommended to make some modification to the Exhaust, intake, and fuel system. Can be used with OBS trucks with some exhaust modifications but it is highly recommended to modify the injectors, fuel system and adding an intercooler to see the full potential of program.
120 hp Race Codes- Same as above but with 3 SES codes, P1211(icp<>desired, P1249(Turbo Overboost) P0478(Exhaust back pressure) preset parameters in the PCM are relaxed so the SES light is not tripped under normal driving conditions. All of the codes listed are for sensor codes. If there was an issue with the sensor or the part itself the SESĀ light will still be triggered.
Ken
