Best performance upgrades for stock turbo - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 07-14-2009, 08:10 PM Thread Starter
Browning01's Avatar
What are the best performance upgrades for stock turbo?
I am looking to improve my stock turbos performance until I can get an aftermarket one. What are the best ways to get some more SAFE performance out of it? Boost fooler, over boost annihilator, big boost? Thanks for the info.
2001 F250 7.3L White 4X4, Lariat Crew Cab, 7 1/2" Superlift, Mickey Thompson Classic lock Wheels wrapped in Dick Cepek 325/80/16 tires, 05-07 Grille and Headlights, wood dash kit, Pioneer Flip out DVD player, Cobra CB mounted under the 4x4 switch, DP-TUNER WITH STOCK, NO START, 80 ECON and 140 AGRESSIVE, DIY Intake with napa 6637 filter, IC Foil delete, new aftermarket tranny with sonnix shift kit and triple disc billet Torque converter, 4" Magnaflow Turbo back exhaust, Plantdrive wvo kit with 75 gallon external L shaped heated tank in the bed, Racor filter inline before the stock one, 146,000 miles
Browning01 is offline
post #2 of 9 (permalink) Old 07-15-2009, 09:35 AM
woodnthings8's Avatar
The items you mention do not improve the turbo or help with SAFE performance. They trick the MAP sensor into reading no more than a set psi for boost. Basically they are either pre-set at 24psi or less. So when you are hard on it the MAP sensor turns on the check engine light and the PCM defuels at around 24-25 psi. If you are running a DP-Tuner you get the check engine light but the truck does not defuel. With a fooler your PCM will not trigger a CEL. This can be bad as you may not pay attention to the gauges ( I don't see in your signature that you have gauges, which is a no no running a tuner).
Usually turbo upgrades consist of Wicked Wheel, Ported Compressor Housing, Wastegate actuator upgrade, and 1.0 A/R Exhaust Housing.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #3 of 9 (permalink) Old 07-15-2009, 09:55 AM
SmokeyWren's Avatar
My Photos: (45)
You said "safe" performance. So none of the above. With a stock turbo, you want to use 25 PSI as your red line. So use a tune and your right foot and your boost gauge to never exceed 25 PSI with a stock turbo. If your tune will provide more than 25 PSI, then that's why you have a boost gauge and a go pedal. Manage the go pedal so you never see over 25 PSI on the boost gauge.
You truck will also exceed the speed limit. But you don't change the tune to prevent exceeding the speed limit. Instead you use your go pedal and the speed gauge (speedometer) to prevent getting a ticket. Sam ting with the boost gauge. And with the pyrometer. Drive by the gauges.
The defuling won't happen until 27 PSI boost or slightly more, unless your tune changed that parameter. So there's no reason to have any sort of fooler to prevent the PCM from knowing you have done something that endangers your turbo if you keep the boost below 25 PSI. The foolers don't change anything but the message to the PCM informing the computer that some idiot is trying to blow up the turbo by exceeding the safe limit of 25 PSI turbo boost.
After you have a turbo (and other mods) that can live with more than 25 PSI turbo boost, then you might need a boost fooler if your tune still uses 25 PSI as the boost limit. But not with a stock turbo. And when you get the new turbo, you'll also want a new performance tune to match the turbo's specs. If your turbo and head gaskets and head bolts and other mods can handle more than 25 PSI, then tell your tuner to raise the boost limit in your performance tune accordingly.
SmokeyWren is offline
post #4 of 9 (permalink) Old 07-15-2009, 11:18 AM
Pappy19's Avatar
My Photos: (6)
An ATS ported turbo housing and an AFE intake system will do you the most good. With your existing mods, you are bound to have turbo surge and the ATS/AFE should eliminate any and extend the life of your turbo a good while longer.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
Pappy19 is offline
post #5 of 9 (permalink) Old 07-15-2009, 11:33 AM
westvandude's Avatar
Forget the wicked wheel, just get the ATS housing. Your diy intake should be sufficient.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
post #6 of 9 (permalink) Old 07-15-2009, 11:37 AM
One of the posts says running a tuner w/o gauges is a no no . Is my s/c flashpaq on 80hp setting aggressive enough to need gauges. I don't tow more than 5k, but I run in the mountains alot. thanks
tinkerr is offline
post #7 of 9 (permalink) Old 07-15-2009, 11:54 AM
To me any tune above stock should have a full set of gauges (if running an auto trans) to keep an eye on the mechanical health. If you run mountain roads on a 80 hp setting even with 5 k you are entering areas of high egt and trans temps. EGT's should be kept under 1300 and with a tune you may easily be able to get it there. When towing hills unless on a large highway or interstate you often slow down for corners. When you slow down the torque converter unlocks and begins to slip causing lots of heat. If you drive for long that way your trans temp will be beyond the 225* point where most say to pull over and let her cool down. If you have a factory trans temp gauge they are garbage. They sit at "normal" until the trans gets to 255* IIRC and enter the red when 275* IIRC. At that poiint the trans would be pretty much useless and the fluid would be cooked. I know the newer fluids should be able to handle temps better now but the gauge is more of an idiot light than a gauge.
Ken
post #8 of 9 (permalink) Old 07-15-2009, 11:55 AM
YEP. Its a
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @
TXANGLER is offline
post #9 of 9 (permalink) Old 07-15-2009, 02:50 PM
Gauges first! Pricey but fun to watch.
