Re: Best place to buy AIS replacement filter
Where's the best place to buy one?
I think this place has everyone beat. They have the Donaldson filter. Donaldson makes the filter for Ford. If you order 6 filters (mix and match) shipping is free.
Buy Filters Here
[/ QUOTE ]The Donaldson filter is white. The filter Donaldson makes for Ford is blue. The Donaldson guy on the forums confirmed that the white filter does not filter as well as the one they made for Ford. So if you need the better filtration for the environment you drive in, go with the Ford for about $10 more. I was planning to buy my next one from www.powerstrokeshop.com but only if it is true blue. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
