Hey I have an Autometer Ultralite Water Temp guage I'm hooking up, is there a port that would be good for the 1/8-27 NPT sendor or 3/8 & 1/2 NPT adapters? Thanks in advance!!
That plug on the water pump is only good if you don't have a coolant filtration system on the truck. I was going to pull one of the drain plugs on the back side of the block but it broke my ratchet when trying to remove the plug.
If you don't have a coolant filter, follow the upper radiator hose from the radiator to the motor. Under the thermostat housing, right side, is a plug that you can remove and put the sensor there.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
