Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-31-2008, 11:50 PM   #1 (permalink)
PAPADONELSA's Avatar
Bigger cooler
Intercooler
I have picked up a 6.0 intercooler to put in my 02 7.3. What all do I need to do to make the swap. Would like to have everything ready before I put my truck down.Thanks so much!! Don
2002 F350 7.3 4x4, cc, short box, auto, 373s,4" exh.,open air filter.
2002 F350 7.3 4x4, cc, short box, auto, 373s,4" exh.,open air filter. 6" lift,36/1550/16s muffler delete DPtunner.Open filter.True track diff.
PAPADONELSA is offline
Old 04-01-2008, 09:28 AM   #2 (permalink)
You will need new boots to make the swap as the two coolers are different sizes. One of the Sponsers has them in a kit.
2OOO F-250 4WD Crew Cab, 223,000K miles, replaced brakes, #1 injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella T, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 04-01-2008, 09:29 AM   #3 (permalink)
these
DIESELSITE.COM 6.0L Intercooler Swap Boot Kit for 7.3L
in my opinion i would look at swapping the tranny cooler for a v10 cooler since you will be right there. the 6.o tranny cooler is nice but cost more then your IC!!! the v10 does handle 90% of any cooling need...have a look at that when you look at the boots ..his proice is about the best i have seen on them. also since you would be messing with the tranny lines it may give you the opportunity to move them to fit the ic better.
just my two cents
there are a few write ups I will see if i can find them.
basically the only thing that may be a problem are the transmission lines going to the radiator. not sure if they hit or not ....I have heard of people having to lower the IC
one guy looked like he tack welded a piece of angle iron on.
others say they drop right in.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
Old 04-01-2008, 10:45 AM   #4 (permalink)
My Photos: (5)
Yep, you'll need to replace the trans cooler, or at minimum relocate it. The 6.0L intercooler will hit the lines on the top of the stock trans cooler.
Pocket is offline
