Blue Cps Tested - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-20-2006, 07:11 PM   #16 (permalink)
Re: Blue Cps Tested
Jody did cylinder pressure testing on my truck Thursday and Friday with a new Black Motorcraft CPS and a new Blue International CPS.
This thing can now be laid to rest as I left with a black CPS in my truck.
Here are the hard facts.
Idle efficiency is 44.4 percent with the blue and 55.4 percent with the black.
Cylinder pressure at idle is 553 psi at 9 degrees ATDC with the blue and 572 psi at 8 degree with the black.
Combustion duration was only 35 degrees of crank rotation with the blue and 51 degrees of crank rotation with the black.
Torque at idle was 4.7 foot pounds per cylinder with the blue and 4.3 per cylinder with the black.
The testing was also done on the road and was along the same lines as the idle testing. It just compounded the numbers with RPMs. So there it is tested and graphed.
When you read the graph, the blue CPS doesn't have a clean curve. The black CPS gives a nice rise and fall on the graph with a nice rounded top. The blue CPS gives a rise sooner but has a divot in the top of the curve then falls off sooner.
FOMOGO
[/ QUOTE ]Great data! I am very impressed to see a 9% increase in torque using less fuel with the Blue CPS. It's also good to see that this holds true in the road test as well. The lower cylinder pressure and shorter duration using the Blue CPS should also help to lower EGTs slightly.
2001 F-250 Crew, long box, 4x4, Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Ford AIS air intake with foam sleeve, Monster exhaust, Aeroturbine, exhaust Guide, 6.0L intercooler, Di-Pricol Optix gauges, IHC CPS, Premo Oil Refiner, Banks Exhaust brake, SmartLock, Banks Quick Turbo, Six-Gun.
2000 Excursion PSD limited, Banks Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Banks Transcommand, UNI 2-stage foam air filter, 4" aluminized exhaust with 4" down pipe and 2 Aeroturbines.
97 F-250 Powerstoke 4x4 Banks Power Pack etc.
2006 VW Jetta, PD TDI, not modified yet[/i]
carnut57 is offline
Old 02-21-2006, 09:30 AM   #17 (permalink)
Re: Blue Cps Tested
Great response too. Would you consider being Hilarys Press Secretary when she is elected President?
I was surprised that after all the pages of discussion about advancing or retarding timing we didn't get the answer. If it can be determined how many crank degrees the combustion process consumes, I don't see why it can't be determined where the crank is when it starts. Or perhaps I'm expected to use that peak pressure position as the answer.
444-4D is offline
Old 02-21-2006, 09:46 AM   #18 (permalink)
Re: Blue Cps Tested
FOMOGO
No Dave, the <font color="blue"> BLUE CPS </font> is retarding timing and the PCM is ADDING fuel to maintain the desired idle speed.
Retarding timing increases EGT's while lowering cylinder pressure.
hamhock is offline
Old 02-21-2006, 09:51 AM   #19 (permalink)
Re: Blue Cps Tested
[/ QUOTE ]What did you expect? The data as presented without questioning the process of collection or how it is presented seems to be positive for the Blue CPS verses the stock CPS. But I think what we are really looking at here is how the PCM reacts with the Blue CPS verses the stock one and how it effects how the engine runs.
[/ QUOTE ]I have to assume this was done on a scope and since it has been mentioned so many times in the other thread that the siganl from the CPS is digital and is read by the PCM on the fall. The more square the curve and the straighter up and down it is indicates to me a more precise signal to the PCM than a sloping curve.
Of course their will be many different takes on what this data means based on how is has been presented, but from what I can glean from it, the Blue CPS simply works better.
carnut57 is offline
Old 02-21-2006, 11:14 AM   #20 (permalink)
Strictly Diesel's Avatar
Feedback Score: 3 reviews
Send a message via ICQ to Strictly Diesel Send a message via AIM to Strictly Diesel Send a message via MSN to Strictly Diesel Send a message via Yahoo to Strictly Diesel
Re: Blue Cps Tested
Dave,
1. This was not done on an O-Scope...it was done with ACTUAL CYLINDER PRESSURE TESTING EQUIPMENT! Jody wasn't looking at the electrical signals, he was looking at the actual combustion event, the cylinder pressure in the combustion chamber, temperature in the combustion chamber and the actual combustion timing.
2. The Blue CPS RETARDS the timing...PERIOD!
3. Retarded timing causes a slight DECREASE in Horsepower, an slight increase in Torque...but at the cost of higher combustion chamber temperatures which lead to higher exhaust gas temps.
4. DRMILLER100 said it correctly, the BLACK CPS burns 11% less fuel than the blue at idle. Plain and simple, the BLACK CPS is more efficient...PERIOD!
5. FOMOGO mentioned the curve on the blue CPS not being "clean". I'll try to describe what the curves look like and represent.
<ul type="square">[*]On the BLACK CPS, we see the Cylinder Pressure (CP) rising as the piston reaches TDC with the valves closed (looks like a standard bell curve on the left side of TDC). At about 4-5° ATDC we see the combustion event begin, represented by another rise in CP. Max CP (572psi) is reached by 8° ATDC and by 10° ATDC the curve is on its way back down. PEAK Cylinder temperatures peak at 572°C @ about 11° ATDC and last for roughly 3-4° of crank rotation.[*]On the BLUE CPS, we see the CP rising as the piston reaches TDC...just like with the Black CPS. By about 3° ATDC there is a NOTICEABLE dip in the CP as the piston is already starting to move downard and the combustion event has not yet started. At about 5° ATDC we see the beginning of the combustion event represented by another rise in CP. Max CP (553psi) is reached by 9° ATDC and by 11° ATDC the curve is on its way back down. PEAK Cylinder temperatures peak at 580°C @ about 13° ATDC and last for roughly 5-6° of crank rotation.[/list]Simply put, the combustion event with the Blue CPS is starting later (retarded) and starting with less CP in the cylinder to begin with. While this may result in a bit quieter event, less CP and delayed combustion result in a loss of power and higher temperatures (cylinder and exhaust).
I'm sorry Dave, but this data CAN NOT be twisted into making the Blue CPS look better than the black. This has nothing to do with electrical signals or magnet strenght or anything else, we're simply looking at the effect on the actual combustion event...and the effect is not positive.
Dennis Schroeder - Strictly Diesel
Phone :: 623-582-4404
E-Mail :: sales@strictlydiesel.com
Main Website :: www.strictlydiesel.com
Web Store :: shop.strictlydiesel.com
Race Truck :: 5500# / 422hp+ / 12.66 @ 105mph / Best 60' of 1.67 ... on 226k Mile PMRs!(PMR engine retired)
Race Truck :: 5800# / ???hp / 11.94 @ 114mph / Best 60' of 1.76 ... with "Built" Race Engine
Strictly Diesel is offline
Old 02-21-2006, 12:17 PM   #21 (permalink)
Re: Blue Cps Tested
Thank you for explaining the data presented. I have no experience with this type of testing equipment and will be the first to admit I may have misunderstood the data. Also I cannot make any comments as to how data at idle relates to running down the road or towing or what the CPS actually does or effects it may have on the PCM. However the real world results most of us have seen using the Blue CPS do not seem to agree with this data. My mileage is up 1.5mpg using the Blue CPS, the truck pulls a load better, smoke is visibly reduced and I cannot see any change in EGTs. The truck runs quieter and I enjoy the way it runs. So for me, and I would guess most that have tried the Blue CPS, we are keeping them regardless of the data. Besides it won't be long before the fuel savings alone pays for it.
carnut57 is offline
Old 02-21-2006, 02:10 PM   #22 (permalink)
Re: Blue Cps Tested
Thanks Dennis, For testing/compareing the two CPSs and shareing the results. Very interesting, to say the least.
I did a bit of Shadetree testing myself, this past weekend. I have no test equipment to hook up to obtain any printable data, just my SOTP test gear.
Last Friday morning I R &amp; R'd my Blue CPS with the Black one (new) I carried as a spare. Hooked up my FW, went on a 150 mile (one way) trip. Sunday Morning I swapped them back out, Topped Off. Headed home Monday.
This trip was on mostly flat, normal freeway type highway with a few minor hills. It's to a place we go often, I'm very familure with the road and terrain.
My SOTP data was: My truck (as Mod'd) Runs a bit better with the Blue CPS. In an "Over All" kinda way. Smoother, with a bit more Pep. EGTs were about the same. MPG's were 10.7 on the Black, 11.8 on the Blue. 95% Cruise Control.
Just one trip, on just one 7-3, pull'n a 11-12K FW. Just one opinion.
After all this Back'n Forth..... I think what we have here is... An Alternate CPS to use. The choices of which one to use (?) are up to the individule owner. One may be better than the other, depending on application based on need.
JOE
2K, F-350, XLT, XCAB, 2WD, DRW, 6 Spd, 3.73LS, 4 Pod pillar mnt, EGT, Boost, Trans/Engine temp, Fuel press. guages, Quadzilla 50/75/120,ES AIS w/fender mod, Shimmed FPR, Dahl pre-pump filter, HX Mod, Racor (Mod'd) CCV, Premo oil Refiner, W/Wheel with both TAGs, Banks W/gate actuator, DT466 CPS, 6.0 Intercooler, Banks I/C tubes & DPP boots, 25psi BPRV, Full 4" exhst, AeroTurbine w/exhaust guide, MagnaFlow, Intake Heater Delete, Heater core bypass, 203* Thermo, Coolant Fltr., "Hutch" Tank & Fuel system Mods,fill pipe fix, Mag-Hytec Dif cvr, Fumoto, Bilstiens, SafeTplus Steering Dampner, Centramatic's, Ride Rites, SilverStars, Clear APC Head/Tail/Corner & all Marker lights, 2 850cca Optima's, Ultra Boards, Burlwood Dash, XM radio, Billit Grill (Black). TTMs/C-beters. Pull a 32 ft Montana FW. 102K
BIG JOE is offline
Old 02-21-2006, 02:33 PM   #23 (permalink)
Re: Blue Cps Tested
BINGO! [ QUOTE ]
Like has been said here MANY times, our trucks are different and will respond to differently even with the same items.
Just my take.........
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 02-21-2006, 02:41 PM   #24 (permalink)
Re: Blue Cps Tested
I ABSOLUTELY CAN'T TAKE CREDIT FOR THIS! Jody and Doug did the testing, I'm just reporting the results after lengthy conversations with Jody and looking at the data the testing generated.
Old 02-21-2006, 03:33 PM   #25 (permalink)
Re: Blue Cps Tested
MY BUST !! Sorry 'bout that Dennis.... Thanks to Jody &amp; Doug then [img]/ubbthreads/images/graemlins/wink.gif[/img], for the Testing..... but a Thanks to you for reporting it...
I was only on my 2nd cup'a Coffee [img]/ubbthreads/images/graemlins/grin.gif[/img]
JOE
BIG JOE is offline
Old 02-21-2006, 05:08 PM   #26 (permalink)
Re: Blue Cps Tested
i have not done any testing other than seat of the pants and MPG. but wiht the blue it is a bit quiter and has more pep. it seem to like the cold weather ALOT better than the black.when i start it when it is below 0 it sounds like it is already warmed up.(which it is'nt) it just seem more plesent to drive, cold or warm.(temps)
i like this mod period!
01 f-250 with 7.3, ex-cab short box, 4x4, 3:73's, custom paint job, DP-tuner Stock, 40 tow, 80 econo and 120 race, High idle, FPR shimed to 68ish with DI FPR shim kit, diesel site HX line, boost relief valve, sonnax and tri spring shift kit, magnafine tranny filter, boost tube, 4" exhaust, blue CPS, autometer guages, tymer intake "zoodaded", CCV mod, heater intake plug delete, fabtech preformance dual shock 5.5in lift with 315-70-17's, on helo max 8's. pioneer 9200 head unit, with JL componet 5x7's all the way around, 2 JL 10" W0's. and kicker 700.5 amp. and as alway PMS is setting in and need other goodies, just dont know what.
van turbo soon to come.
been through the hypertech tuner, superchip tuner (1705), edge ez, and various 10K's. ditch'em and got a real "tune"!!
preddy08 is offline
Old 02-21-2006, 08:15 PM   #27 (permalink)
Re: Blue Cps Tested
Ok, this isn't directed at anybody but at the thread in general. Dennis explained it as clearly as it can be explained. There is a lot of speculation about driving down the road and how the CPS is performing. Well I don't tow anything bigger than a car trailer so it wont compare to the guys with the big loads. The first post I made said everything including the fact that all parameters were compounded with RPMs. Yes going down the road at a steady cruise it retarded the timing and it did not make more power. And my truck did pick up 2 full MPG on cruise at 78 MPH. It ran quieter and seemed to have an overall better feel. But when you ride down the road and watch the timing backing out of the motor as you accelerate it wasn't what I had hoped for. We spent about 6 hours installing and removing this equipment and that doesn't include the time we spent running the multiple test on a 20 mile loop. Idle figures were only used as a sample, to show you what it was starting out as. We would have to write a book to show or explain all of the events. The CP testing equipment can only save 30 seconds of info at a time. In that 30 seconds it records 75,000 samples per second, per sensor. At idle a single file is 32 MEG at cruise a single file is 48 meg. So I hope you can understand why this cant be posted with any more detail than it already has. The motor does not make more horse power, a little more torque, yes but at the expense of combustion efficiency. Its just my opinion but this mod falls in the same file as the K&amp;N panel filters...
FOMOGO
2001 F-250 Lariat, Black, CC, SB, 2WD
304 hp and 627 tq on Dunbars Dyno
2001 F-250 XL standard cab, beater, hauling trash... Stock except for a 60 horse flash...
304hp and 617 tq on Dunbars Dyno
2001 F-250 Xl Standard cab, project truck...
Custom Tunes by DP-Tuner, Custom Fuel System by ITP Diesel, Custom Trans by BTS
Ford Makes It - International Shakes It
Dubco1 is offline
Old 02-21-2006, 09:52 PM   #28 (permalink)
Re: Blue Cps Tested
what is the difference in the blue and black cps where do you buy a blue and black. what would be used for truck pulling?
2002 F-350 4wd psd. hx 48 turbo, single shot injectors, dual stage nitrous, 4 inch duals, 3 pos custom tuned dp chip,ccv mod, aih delete mod,itp regulated return, oil crossover line, sp diesel 10 level kit, afe stage 2 cold air kit, and many other mods and inventions made to engine. monstorbox tranny,triple disc tq, ladder bars, 4 inch susp lift, dick cepek tires on american racing rims and beadlocks, Ford AIC, Auto Enguinity.Billet Badges, custom badges.F-444 Gettin' Stroked
White 2-180 3208 cat
Massey Ferguson 35 3 cyl perkins
Massey Ferguson 6180 6 cyl perkins
Massey Ferguson 255 4 cyl perkins
Massey Ferguson 65 4 cyl perkins
Agco LT-75 4 cyl Cummins
Case 1845C Skid Steer 4 cyl cummins
Case 580 construction King Backhoe 4 cyl case
1986 F-250 6.9 IDI 4x4 265,000 miles *sold*
1994 4wd f-250 ext cab psd
2180 is offline
Old 02-21-2006, 10:14 PM   #29 (permalink)
Re: Blue Cps Tested
Most drivers have reported that the blue CPS did not run well when first installed. Was this considered during the testing? Was the truck run for a few hundred miles before testing? I know that this adds some other variables and other sources of error in the results (fuel quality between tanks, weather, OAT, etc...) but I think that the "break in" of the blue CPS should be considered.
I am not on one side or another, just want to understand...
SOLD: 2000 F-350 Crew-Cab Lariat 4x4 SRW
Tymar intake, ART rotors, SS HX Crossover, Magnaflow exhaust, ISSPRO gauges, DP-Tuner 6-Position chip, Wicked Wheel, Non-EBV pedestal and exhaust outlet, John Wood transmission with billet torque converter (it ROCKS!!)
Elephant is offline
Old 02-21-2006, 10:31 PM   #30 (permalink)
Re: Blue Cps Tested
The blue CPS had 2500 miles on it when it was tested. First I have heard of breaking in an electrical part. I always thought they worked or they were broke. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
FOMOGO
Dubco1 is offline
