Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Ok, this is'nt directed back at you FOMOGO But, I think it would be incorrect to group this into the on-going Debacle of Air Filter, Oil Filter brands.... It would be Mis-information based on Conjecture, if we condemn it to that "File", based on ONE set of test data. We get enough of that on the Nightly News. [img]/ubbthreads/images/graemlins/wink.gif[/img]
All this Blue CPS is, is an alternative CPS to >concider< if/when one fails.
Looking at the data from Jody and Doug's testing, it appears there ARE some losses and gains. (there's allways a trade-off) But it also appears that the losses and gains are not That significant when compared to what the long term (to date) practical application shows, in creature comfort, SOTP results.
To see Less Smoke. To have a Smoother, Quieter idle. To feel a bit more pep. To gain a bit of MPG ?.... for the same price as a tank of fuel ?.... it's worth a Shot.
I have had my blue cps in for three tanks now (about 1000 miles) and the truck cold starts better and runs smoother and quieter. I have lost fuel milage though. I used to get about 320 miles on a tank of fuel and since I put in the blue cps I have yet to break the 300 mile mark. Its been more like 280-290. I have not done an exact milage calculation but I have lost fuel milage. I did not do any other mods to my truck since the install of the blue cps. either the cps does not like my truck or something else went wrong at the exact same time I put the sensor in. Kind of a bummer cuz I really like how it runs now.
TRUCK-2000 F250,cc,sb,4x4,3"lift, 33"tires
MODS-Gauges,Ts 6 Pos,Afe2,HTT turbo, 5" Summit exhaust, Turbo master waste gate,Zoodad, Ccv mod to downpipe, Bypass filter, Amsoil throughout, overboost reg, Aih plug, Gutted ebpv/non-ebpv pedestal, Monster box, xternal trans filter, A/C mod. 300rwh with e-brake on (oops). 15.29 best 1/4 (Several mods ago).
Blue/Black CPS, what about a third? Is there still another CPS alternative that has yet to be made public? I thought I read somewhere in the CPS bible thread that a new more reliable CPS was in the works by one of the sponsors, vendors, joe smow, etc? Anybody have any input on this?
Thanks for the effort in getting some science in this debate. I'm assuming ( very dangerous to do by the way) that this testing was done in stock mode. I put in the Blue CPS about 3000 miles ago and found a perceptable difference in stock mode. The truck felt more like it had a chip in, that is a little more positive response. However, using my tow or performance mode of my chip I haven't noticed a perceptable change. As for milage, I calculate my mileage at every fill up and always fill to the brim. Note to self: Do Harpoon Mod as it takes forever to get the last 3.69 gallons in! Anyway I have seen a decrease in milage. Now it may have to do with the difference in winterblend fuel and temperatures. I happen to put this mod in when the temperature finally dropped to our winter conditions. I will reserve judgement on milage until we get to a more suitable test period with consistant temperatures.
Just my observations.
'99 F350 SRW.3:73 Gears TTS CHIP,SPDIESEL EXHAUST BRAKE,AFE MAGNUM FORCE AIR INTAKE,FORD REPLACEMENT TORQUE CONVERTOR,DIESEL INNOVATIONS FUEL REGULATOR SHIM KIT, REMOTE START, NEW FORD CPS, BLUE IH CPS as SPARE ,BLACKCLOUD DIESEL HX OIL LINE.
I think that using this BLUE cps will have different results depending on each engines biological makeup, ie, what modifications have been done to the engine and sensors, fuel supply, etc... So it would give completely different results depending on what you start with. Apples to Oranges as they say. One step forward may be a step back for others and so on. As one poster said, "try it, if you like it, keep it". [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Bud
1997(12/97) F250 SC XLT PSD 4x4 150k 4.10LS,5spd, 1998 BMW 323i conv, 1987 Mercedes 300D Turbo 175k, Mods include:Luk SM flywheel kit, Hypermax downpipe, no kitten, gutted ebpv, shimmed regulator, Donaldson open element air filter, add-a-leaf front.
The blue CPS will not have different results on different trucks. Plan and simple it mechanically pulls timing out of the motor, period. Now different trucks with different PCM programs and different aftermarket items will all perform differently. No disagreement on that here. But facts are facts. Timing is mechanically retarded by the blue CPS.
I have already stated that my truck had better idle qualities. Better fuel mileage but it made it smoke heavily while running the Blue CPS.
Jody had already done live tuning on my truck in my town and had the smoke down to almost zero in my 120 horse program. Only a slight puff when you first open the throttle. Then it cleared up and ran strong. Changing to the Blue CPS caused lots of smoke in the 120 horse program and it never cleared up.
For those of you that are asking all the testing was done in Jody's 80 horse economy program. With a PMT1 based program.
FOMOGO
__________________ 2001 F-250 Lariat, Black, CC, SB, 2WD
304 hp and 627 tq on Dunbars Dyno
2001 F-250 XL standard cab, beater, hauling trash... Stock except for a 60 horse flash...
304hp and 617 tq on Dunbars Dyno
2001 F-250 Xl Standard cab, project truck...
Custom Tunes by DP-Tuner, Custom Fuel System by ITP Diesel, Custom Trans by BTS
My question is; Will the blue cps have a negative effect on the long term life of the engine? If you are changing the combustion temperatures by retarding the timing will this cause the engine to fail quicker? I'm not that concerned about making my 7.3 sound more pleasant to my ears if that was the case I would have bought a V-10. But to get 1 to 2 more mpg at the cost of fuel gets my attention, but not at the cost of premature engine failure.
Early 99 F250 XLT, 6 spd, Luk Clutch-Kevlar bushing, 4" MBRP Exhaust, Turbo Master Wastegate Controller, ITP Overboost Annihilator, KCM S.S. HPX Line, DiPricol Optix Gauges, DP Tuner F5 Chip with 60T,80E,100 Perf, Superchips 1805 Flashpaq (used for code reading only), Firestone Airbags, 203 degree t'stat, AIS/w fender sleeve, CCV Mod, Hutch In Tank Mod, Harpoon Mod, 6.0 Intercooler, 315/75/16 on 16X10 Eagle Wheels, Ford 08 and above rear differential cover, Royal Purple Gear lube, 2007 Grille and Headlight Mod.
I have to agree with you that, THAT, is what was going through my mind. I understand different strokes for different folks and I really do appreciate everyones efforts in testing and coming up with conclusive answers. I classify this as similar to the Tymar vs. AFE Stage 2 argument.
I guess the deciding factor for me is whether or not the blue CPS has detrimental long term effects on the engine. I know some have ran it for quite some time without any problems, but has anyone tested this thing for 50-60K and/or over a years period or more? [img]/ubbthreads/images/graemlins/phoney.gif[/img]
2002 F-250, LB, CC, AFE stage 2, Magnaflow 4" SS turbo back, Donahoe 4 1/2" lift, 35" BFG's, and DP Tuner 4 pos chip, ISSPRO gauges on the A pillar, AIH delete, Performance turbo wheel, ATS housing, Bob Riley's Intercooler boots and CCV mod
There is no "nice" way to arrest a potentially dangerous, combative suspect. The police are our bodyguards...our hired guns. We pay them to do the dirty work of protecting us; the things we're too afraid, to unskilled or too civilized to do ourselves. We expect them to keep the bad guys out of our businesses, our cars and houses and out of our face. We want them to "take care of the problem."
WE JUST DON'T WANT TO SEE HOW IT'S DONE.
Charles Webb, Ph.D.
CSU, Long Beach
Many chips advance timing and some of them advance the timing excessively.
If your timing is overly advanced by your chip than the "Blue CPS" will offer an improvement in mpg as it retards the timing a bit.
If your timing is stock, you will likely experience a decrease in mpg going to the "blue CPS" as the timing will become overly retarded. Smoke will likely increase as will egts very slightly.
If your engine has custom programming w/ CP testing your timing can NOT get any better and changing the CPS to the differing model will only make it run worse.
The CP scans that were described are very consistent w/ slightly retarded timing. There are 2 CP peaks. One represents the volume of the injection event itself and the other represents peak combustion vs. volume in the cylinder at that moment. (I'm not 100% sure on these truly being the reasons it's just my best guess of what I have theorized after looking at CP graphs) Good programming should make these humps just touch each other creating a nice steady combustion hump that does not peak to high. If the timing becomes too retarded the heat to ignite is less resulting in a longer diesel delay resulting in a delayed 2nd CP spike that of course will fall off sooner as the piston is quickly moving away at this point.
Maybe the "blue CPS" has a sharper signal but that is another issue that may or may not improve how the engine runs assumming the timing factor has been removed from the occasion.
Clear as mud?
Early '99 7.3 Superduty. Built 3-98
Built motor. Homemade "Big Oil", GT42R Big frame turbo. Rods and junk to keep it all together.
I will chime in here. My CPS shut me down at 60,000 miles. Started back up and got me home. I researched this post last week and thought I would try the blue one as it is the same price as the black. My results are unimpressive. The throttle feels "soggier", no decrease in noise, no better cold weather starting, same boost and EGT's. As well, my fuel mileage is in the toilet on this tank. I am going to run more fuel through it to see if it was a fluke as I have been getting on it to try it out on this one. So far, I wish i would have stayed with the black one. Have 115 miles on it.
03 F150 SCREW 5.4 305 BFG's, American Racing wheels, MAC CAI, Magnaflow
91 Mustang GT 302 with solid roller cam, Pro Topline heads, Typhoon intake, 4.56's, 5 speed, full power, AC
[Sarcasm on] How can that be? Did you forget to disconnect the battery cables when you installed the CPS? Did IH tell you the special incantation you have to say over the CPS before it was installed? [Sarcasm off] Why would you want to undo some of the programming you paid a reputable tuner to perform?
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
