Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
just installed it with the T in the line. idle it shows nothing which i believe is normal? but under acceleration it doesnt really move unless i Really get into the pedal. only saw 15 psi. also when cruising its at zero
2000 f 250 4x4. ccsb
just hit 206,000
38R with Turbo Master
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
remote start.
AIH cut off
bypass oil system
running on WMO!
I would carefully look over your gauge install for a loose or leaky sensing line before looking for boost leaks. Make sure both ends are tight and the line is not kinked, pinched, or chaffed/cut open.
Then its time to hunt down boost leaks.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
If its not accelerating different or you're not feeling any loss of power than from before you put the gauge in then you've probably got an ongoing low boost problem that existed before installing the gauge and now you're just able to note it. Could simply be a leak somewhere....you hope. Or, if it has lost power and acceleration since putting in the gauge then you probably got a problem with your gauge installation or the gauge itself.
Regardless, its a good thing to check for boost leaks throughout the whole turbo system...from the turbo inlet, through the CAC tubes and related boots all the way to inlets on the heads and also check at the MAP sensor hose connections. Also check the up-pipes to see if your losing exhaust pressure at their gaskets and connections to the turbo.
You can make yourself a boost leak detector pretty cheaply (under $20) to put about 15 PSI into the system to listen for leaks or buy one of the available ones online...dieselsite.com has one.
ok sounds good. how do i make the kit? is it easy to make?? also how could i tell if the up pipes are leaking? soot deposit?i have also noticed the boots at the intercooler are covered in gunk
just hit 206,000
remote start.
AIH cut off
bypass oil system
running on WMO!
I replaced all my boots with the ones from dieselsite. Just under $200 if I remember. Thats both intercooler boots and the boots in the engine valley. The OE boots on your 01' like my old boots are probably like cheese cloth for holding the boost in. If that's your actual boost with your mild programmer it's a touch low. You should be in the 15-17psi range stock. I hit about 24lbs the two higher tunes.
As has been said, make sure the connections on the hose are all ok and no kinks, etc.
Zero on the gauge at idle is normal, zero on flat ground and a light pedal is normal too. There is a pretty big range in total boost from year to year and lot number to lot number. My truck is ALWAYS cranked, so 26+ psi is very common, even unloaded @ full throttle. However, my valley seals are pretty new, new International bellowed & billet machined up-pipe kit, good intercooler boots, & only 86,000 miles.
2003 F250 XLT 7.3L, Auto, FX4, Crew Cab, Long Bed, 6.5" Pro-Comp all spring lift & Firestone HD Rear Air Bags, BFG KM2 37x12.50x17 tires on Eagle 17x10 Rims, 4" Turbo Back Exhaust & muffler delete, Bully Dog Programmer @ 120 Hp setting ALWAYS, Machined & Bellowed International Up-Pipe Kit, Autometer Overhead Gauges (Boost, Pyrometer, Trans. Temp), Custom Pre-Filter Ram-Air with K&N filter, "John Wood" Custom Stage I Transmission, 6.0 Billet 3 Disk T/C, External T/C Lock-up switch, 6.0 Trans Cooler, Hughes Racing Deep Structural Pan, and a few more goodies. Now spinnin' AAM Rear & Dana Spicer Front 4.30:1 Gears with Warn Premium Locking Hubs.......I do a lot of towing.(13,000 lb 33' Toyhauler & 21' Ski Boat). 84,568 miles as of 11/09
so when accelerating slowly zero is normal? because i accelerate rediculously slow lol. if i accel a little faster itll move up to about four PSI
just hit 206,000
remote start.
AIH cut off
bypass oil system
running on WMO!
when i travel down the highway at 65mph my boost sits at 4or5 psi and my pyro sits at 700.
Somedays its just not worth chewing through the restraints
2011 F350 CC lariat ultimate dually with nav, line x, more mods comming
Y2K 4x4 250 PSD Xcab, auto, way too many mods to list Broken March 2011, written off due to collision
ok i did two or three full throttle runs....boost never went over 16PSI. how do i make the kit to check for boost leaks?
just hit 206,000
remote start.
AIH cut off
bypass oil system
running on WMO!
I'd just attach the air compressor adapter (far right side in his "exploded" view photo) directly into the metal reducer on the cap (far left side in the photo) and use my compressor to monitor and maintain the pressure. Take this setup and attach it directly to your turbo inlet with a rubber hose (Ace/Home Depot/Lowes plumbing section) securely fastened with good t-bone hose clamps (or you may end up with hearing loss or a sore head when if it pops off while under pressure). Pump it up to about 10-15 lbs of pressure and start listening for leaks. If they're there you'll hear them. Some guys spray soapy water around on the connections, too.
thanks! what size hose do i need to get? Where do i get the pipe? what do i specifically ask for? also on the turnpike today i was going 65 with the gauge showing just under 1 PSI
just hit 206,000
remote start.
AIH cut off
bypass oil system
running on WMO!
Hardware stores, Home Depot, and Lowes are good sources. The turbo outlet is 3" on yours so you need to get that size hose and PVC Sch 40 bushing with NPT threads on one end to allow for screwing in a air nipple connection. Pretty simple.
16 psi is not terrible for a stock or low tune truck. Not saying you don't have a leak, but you're not in bad shape. A lot of times, you won't see max boost unless you are towing a substantial load with heavy throttle, or pulling a good grade with heavy throttle. However, you should get to know your trucks normal readings (Boost, Trans. Temp., Pyrometer). Every truck is a little different. By knowing "normal" for your truck, you'll know when there is a change or deficit occuring.
