Boost numbers - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-05-2006, 11:37 AM   #1 (permalink)
Boost numbers
I read some of the other post and hear guys talking about 40psi all the time and my truck only makes around 28-29psi. I check the parts list from these people and it looks about the same as mine so I have been wondering if I have a problem. Should my numbers be higher then what they are?
1999 F350 XLT DRW CC auto 373 gears 4x4.
cold air intake
4" strait SS exhaust
ATS housing
W Wheel
Turbo Timer
manual waste gate
boost pop off
dual tranmission cooler
no exhaust valve
tripple phantom gauges
dieselsite 6 position chip
oil cross over line
transmission valve body
Billit Torque converter
crowhater is offline
Old 05-05-2006, 12:53 PM   #2 (permalink)
Banned
My Photos: (38)
Re: Boost numbers
NO.
Your stock turbo is out of its efficiency range at anything above 25psi and you're hurting it to run it higher. Now that may change a little with the ATS housing you have -I don't know- but I don't think it changes much.
40psi is most certainly with an aftermarket turbo, and usually some injectors to light it. [img]/ubbthreads/images/graemlins/cool.gif[/img]
gregrob is offline
Old 05-05-2006, 01:22 PM   #3 (permalink)
bigrpowr's Avatar
Re: Boost numbers
BIG injectors to light the big turbo? who has a similar setup that's running 40 psi?
2000 F350 4x4 almost fast
12.27 @112.89
12.80 @ 114.48
727.7 hp (NOS)
bigrpowr is offline
Old 05-05-2006, 03:46 PM   #4 (permalink)
Re: Boost numbers
The ATS housing you have moves the surge line further left and the choke line further right. You can go above 25 psi safely without generating excessive heat. Should be fine up to 30-32 psi, but I wouldn't go higher than that.
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body ||| LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions, aux backup lights in bumper ||| Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
My Truck Pics
NorCal Powerstrokes
ryaneverk2 is offline
