Boost pressure relief valve - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-07-2006, 08:40 PM Thread Starter
Was speaking with a buddy of mine about putting a boost pressure relief value on my truck - a valve to stop the the truck from throwing codes if boost pressure gets to high. He was saying that with his truck (a d-max) the valve wasn't necessary as he can turn this 'feature' off with a programmer. I'm wondering if anyone knows if it's possible to do this on a 7.3, or if it's purely mechanical and cannot be turned off with programming.
2001 Excursion 7.3L 4x4 XLT
, and "Powerstroke Diesel v8" stickers.
sleepies is offline
post #2 of 8 (permalink) Old 04-07-2006, 08:43 PM
Banned
My Photos: (38)
Re: Boost pressure relief valve
To my knowledge, it can't be turned off with programming. The MAP sensor takes a mechanical reading and sends the data to the PCM, I think the only way to disable defueling would be to disable the MAP sensor. There are some 'electronic' plug-ins that keep the MAP sensor from throwing the code, and supposedly work well.
It just make sense to me though, to never let the MAP sensor see excess boost.
gregrob is offline
post #3 of 8 (permalink) Old 04-07-2006, 09:24 PM
an Overboost eliminator from us will cure that issue and your install will take about 10 seconds.
Proud to be a sponsor of thedieselstop.com
Test Fleet
2001 F350 Crew Cab 7.3L
2004 F250 Crew Cab 6.0L
2004.5 Dodge Ram Cummins
2006 Jeep Liberty CRD
2007 ML320CDI
Soon To Be 2007 Dodge Ram 2500 6.7L
"Can your Resistor do this?"
spdiesel is offline
post #4 of 8 (permalink) Old 04-08-2006, 01:00 AM
I am using it and it works perfect. Easy install, clean setup.
2003 7.3 PSD, TERMINATOR HPOS, DP LIVE TUNED, ITP Reg. Return, Spearco, DI up-pipes, PI coverter & TransGo tugger, AFE-II, 4" MBRP, Duramax fuel cooler, 20K on the clock
JMS1 is offline
post #5 of 8 (permalink) Old 04-08-2006, 05:13 AM
Here are 2 different in-line relief valves.
http://www.itpdiesel.com/store.php?c...on=show_detail
http://www.dieselsite.com/index.asp?...&ProdID=31
Im looking toward the BRV+ as you can use this to connect your Boost gauge to one side of the valve.
I assume you already have gauges - this just goes in the line where you are tapping for the sensing anyway. Consider the relief valve as if you ever want to change programs you wont have to worry about whether you can get the parameter in the tune/program.
Bruce & Carolyn Wittmeier
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, DP-Tuner 40/80/120HP, Chrome Step, Line-X bedliner, Jordan Ultima 2020, AirLift 5000 Airbags, DiPricol gauges
wittmeba is offline
post #6 of 8 (permalink) Old 04-08-2006, 09:59 AM
I just bought a small air preasure regulator off of ebay I think it was $6.00 delivered and it does the same thing. I guess I'm cheap [img]/ubbthreads/images/graemlins/phoney.gif[/img]
2000 F-250 ext. cab 4x4 lariat auto, <font color="green">F-5 60tow,80eco,120Get'R'Dun</font>,AFE Stage 2 PG7,MBRP 4" turbo back,<font color="blue">BTS-VB</font>,ITP Crossover,203*T-stat,<font color="red">CAT EC-1</font>,Isspro Overhead Pyro,Boost,Trans.Gauges
[*]The fact is that the average mans love of liberty is nine tenths imaginary, exactly like his love of sense, justice, and truth. He is not actually happy when free.,He is uncomfortable, and a bit alarmed, and intolerably lonely. Liberty is not a thing for the great masses of men, it is the exclusive possession of a small and disreptuable minority, like knowledge, courage, and honor. It takes a special sort of man to understand and enjoy liberty and he is usually an outlaw in democratic societies. H.L. Mencken 1923
Jimmy3336 is offline
post #7 of 8 (permalink) Old 04-11-2006, 09:31 PM Thread Starter
Thanks for the responses guys. I'm wondering if I would need to do the mod at all. Don't get me wrong, I've got no problem spending 50 bucks, or whatever, and doing the relatively easy install.
My question is related to the PCM and custom tunes. A buddy of mine has a newer d-max and a custom tuner (I guess 'sniper'is a similar product in the ford market). In his world, he simply lets the sensor tell the PCM (chevy calls it an ECM I'm told) that boost is too high, and he tells his EMC to ignore the sensor. It free, assuming you've paid for the programmer, and no cutting on the truck.
I'm wondering if the PCM on my truck is capable of ignoring the sensor, and if so, do any of the tuners on the market tell the PCM to do so? If I had a newer 6.0, I would expect to be able to ignore the sensor, but I'm not sure what to expect from the computer on the 7.3.
sleepies is offline
post #8 of 8 (permalink) Old 04-11-2006, 10:35 PM
Kanman's Avatar
The answer is NO. Read above for the solution.
Kanman is offline
