Boost Releif Valve??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-21-2005, 11:43 PM   #1 (permalink)
01yz426's Avatar
How do you install a Boost Relief Valve??? I got the Valve but no directions on what to do..... Do I need any extra hoses or clamps??? Any help would be great....
COWBOY UP!!!!
2002 Ford F-350 PSD Crew Cab, Automatic... 8inch FabTech lift, 4.56 gears, 38x15.50x18 Toyo M/T's on American Racing Teflon Mojave, Straight Piped, Garrett BB Turbo, AFE Stage II intake, DI 6-position chip, Auto Meter Carbon Fiber Gauges, Kc Light bar/w 4-Kc lights, 2-Piaa lights on bumper, Kc backup lights, Boost Relief Valve, Matrix 50.5x Security System.... Future plans include: , Edge (Donahoe Racing) 10.5inch lift kit and maybe some 39in PJ's... Front and Rear Dual Billsteins either 5100-7100 series... Well the list goes on and on as I get poorer and poorer. Check out a few of my pics: http://community.webshots.com/user/01yz426
01yz426 is offline
Old 03-21-2005, 11:53 PM   #2 (permalink)
Re: Boost Releif Valve???
Where did you get it?
It will go in the MAP sensor line, get some clamps, remove the plastic tubing around the hose, cut it, clamp it in. It should have an arrow that points toward the MAP sensor. Hope this helps!
Remember, this is the internet, where everyone's a diesel mechanic and has 500+hp/1000+lb/ft under the hood! Read up, form your own opinions, then do your own real-world testing!
'01 PSD F-250 XLT SC LB 2WD 6SPD 3.73LS, Alliant AC's,ARP Studs, Stealth Dual HPOPs, GTP38R, Forged Rods balanced, Fluidampr, South Bend CON OFE, 6.0L Intercooler, Volant Intake, 4" SS MBRP Exhaust, A-Pillar mounted Lunar Series Boost/Pyro Gauges,4 pos. Chip with Stealth burns from Twildman, playing with Minotaur Tuning software too, heated Racor 900FH 2 micron, Hutch mods, harpoon mod, DIY Regulated Return, 203 T-stat, coolant filter, AIH gone, CCV Mod, boost pressure relief valve, 100 gallon tank/toolbox combo...AutoEnginuity diagnostics for all Domestics
roosterdiesel is offline
Old 03-22-2005, 12:10 AM   #3 (permalink)
01yz426's Avatar
I got it from Nate Dwyer.... Yes it does have the arrow on it, but nothing for directions.... Thanks, I'll see if I can figure this out, doesn't look to complicated but when you haven't done it before it's nice to have directions... Thanks for the help.
COWBOY UP!!!!
01yz426 is offline
