BTS Valve Body ... Where? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-18-2008, 01:40 AM   #1 (permalink)
Deepsky3539's Avatar
I hear everyone raving about the BTS valve bodies but I have yet to find a place that sells them let alone does a good job of explaining why you need it. Anyone know a good site to read up on it and where one might actually purchase one?
________________________________
2001 F250 Extended Cab 4x4
Air Lift Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad w/trashcan screen
Magnaflow 4" Exhaust
Dieselsite Turbomaster Wastegate Controller
Dieselsite engine and intercooler boots
Pricol Optix gauges
DP Tuner= No Start, Stock, 80 Econo, 40 HA Tow, 140 Race
Lots-o-surge (Man I gotta Fix That)
Deepsky3539 is offline   Reply With Quote
Old 01-18-2008, 06:02 AM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
The Only Place to get a BTS valve body is from BTS
Brians Truck Shop
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline   Reply With Quote
Old 01-18-2008, 07:28 AM   #3 (permalink)
ShayB's Avatar
My Photos: (10)
Best thing to do is call Brian and ask him your questions.
Original Co-Founder of the Colorado Power Stroke Club.
Now beginning a new chapter with the Colorado Diesel Truck Club! www.coloradodieseltruckclub.com
Personal vehicle: 2000 7.3 Excursion 4x4 (BTS trans)
Work vehicle: 2009 Duramax 4x4 2500
Hubby's vehicle: 1997 F250 w/2006 Cummins (BTS trans)
shayb@coloradodieseltruckclub.com
ShayB is offline   Reply With Quote
Old 01-18-2008, 07:54 AM   #4 (permalink)
Brian can get way busy, if you have a hard time getting through call Rocky. Rock can answer all your questions and order up your BTS valve body.
Rockin' S Performance
97 PSD f250 4x4. 06 common rail conversion in the process.
<span style="color: red">cummins conversions by Rockin S performance </span>
AlanB is offline   Reply With Quote
Old 01-18-2008, 08:05 AM   #5 (permalink)
My Photos: (17)
Good point. I forgot about the few satellite BTS installers.
Old 01-18-2008, 09:16 AM   #6 (permalink)
I have one but honestly am not impressed with it.. I have had other valvebodies that performed better. I am gonna try a John Wood Valve Body in the spring along with a good aftermarket torque converter.
Ironhide is offline   Reply With Quote
Old 01-18-2008, 10:02 AM   #7 (permalink)
I have never heard of someone not impressed with the BTS VB. What didn't you like about it?
Also, why are you changing your VB so much?
- C
2002 Ford F-250 Lariat Supercab 4x4 7.3L Auto.
Under Hood: DP Tuner F5 (NS, S, 60T, 80E, 120R), BTS VB, TM Waste Gate Controller, BRV Plus, MBRP SS 4" Turbo Back Exhaust, BrightBox, Ford AIS, Auto Meter Guages(Pyro, Trans, Boost).
Under Everything Else: Hankook RT03 MT 285/75/16, 16x8 Wheels, Monroe Reflex Shocks.
Best line ever on TV: "I need more cowbell".
CamoFlogged is offline   Reply With Quote
Old 01-18-2008, 10:57 AM   #8 (permalink)
- C
The tranny is shifting way too soon, and not downshifting when it should. I have had Jody @ DP look at programming several times and made slight adjustments but its had not helped much..
As far as why I am changing VB, this is my second transmission.. The first one I lost reverse in it and had a Factory Tech VB it in.. The tranny was under warranty from Ford so they put a new transmission in it. I read about all the rave over BTS VB and so I ordered one and installed it. I like how my other tranny shifted, nice clean and crisp and shifted at the right times.. This one is in a brand new tranny too. Before installing the BTS just before you ask, it shifted just fine with none of the issues I am having so its not the transmission. I have called BTS a few times and they blame it on programming of course. But like I said, it shifted fine before I installed the BTS.
Similar Threads
bts valve body? LOGI Upgrades and Aftermarket - 99 & up 7.3L Engine 4 08-15-2006 12:57 PM
BTS valve body how much are they? Matt H Upgrades and Aftermarket - 99 & up 7.3L Engine 6 07-21-2006 03:41 AM
BTS valve body jorbin2 Upgrades and Aftermarket - 99 & up 7.3L Engine 17 06-17-2006 05:58 PM
BTS Valve body FionaThe02PSD Upgrades and Aftermarket - 99 & up 7.3L Engine 4 01-06-2006 03:37 PM
BTS VALVE BODY OR FACTORY TECH VALVE BODY? bldr018 Upgrades and Aftermarket - 99 & up 7.3L Engine 8 11-05-2005 05:45 PM
