Cam Sensor - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 04-11-2006, 11:22 PM Thread Starter
Cam Sensor
Can anyone tell me the part number for the blue international cam sensor, i need one for my 02 superduty? Thanks!!! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
88 250 4X4 7.3 C6 MARK II RAM AIR & STAINLEES EXH.
racesidner is offline
post #2 of 9 (permalink) Old 04-12-2006, 11:10 AM
Re: Cam Sensor
take out the black one that is in there now. write down the part number. put the old one back in and drive to international and get the black one with the same part number. you do not want a blue one.
1999.5 (5/99) F-350 SC, LB, ZF-6, 4X4: ATS Compressor Housing, BBH, K&N FIPK & Drycharger, DP Tunes 60T, Isspro Pyro & Boost, 4" MBRP & Delete Pipe, AD's (for now) ITP HPX, OBA & Reg Return, AIH Delete, Oil Guard, Couple Dongles
Oil Pan @ 133,000
PSN rocks my world
ITowBoats is offline
post #3 of 9 (permalink) Old 04-12-2006, 11:15 AM
Re: Cam Sensor
Why do you want a blue one??? The correct sensor for our 02's is the black one, part no: 1825899C93
Cheers,
Chris
2002 F350 CC 4x4 SB Lariat Blue & Silver, General AT2 295/75/16's on 16x8 Panther Rims, KYB Monomax Shocks, Euro Style Tail Lights, billet fuel door, Putco chrome handles, Autometer Z Gauges & Pillar Pod, Billet Grill, Bullbar, JVC KD-AR870 head unit, Sirius, MEI Reference Series 600 Watt amp with 6.5" Alpine DD Drive F17C components front, 6.5" Jensen components in rear, Better Built truck box, auxiliary backup lamps, acetoned badges, blacked out lower weld seams, Dodge auto-dimming rearview mirror, Avital alarm system, heater by-pass mod, in-tank, harpoon and pre-pump mods, 5" SS exhaust tip.
2002 Acura el (only available in Canada)
2002 Fleetwood Wilderness 31G
1988 Campion Allante, 19.5' w/ Merc 5.7 litre
Roadfrog is offline
post #4 of 9 (permalink) Old 04-12-2006, 03:36 PM
My Photos: (22)
Re: Cam Sensor
take a peak in the "for sale" section of this forum.
Hammer
Check out what I recently bought:
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red">
</font>
Get Your Tuning Here:
and your Fuel kits here:
TheHammer69 is offline
post #5 of 9 (permalink) Old 04-12-2006, 04:44 PM
olddieseldude's Avatar
My Photos: (16)
Re: Cam Sensor
Scroll down about half way on this link...
Blue CPS
RickN
(mods listed in comments under photo in above link)
olddieseldude is offline
post #6 of 9 (permalink) Old 04-12-2006, 05:36 PM
Banned
My Photos: (38)
Re: Cam Sensor
Hammer
You need to buy the one from Hammer, it's gauranteed to make your truck run faster just becuase he has touched it. [img]/ubbthreads/images/graemlins/wink.gif[/img]
gregrob is offline
post #7 of 9 (permalink) Old 04-12-2006, 06:03 PM
Re: Cam Sensor
The number is IHC#1807339C92 and we have them in stock http://www.dieselpowerproducts.com/ford
2001 F-250 Crew, long box, 4x4, Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Ford AIS air intake with foam sleeve, Monster exhaust, Aeroturbine, exhaust Guide, 6.0L intercooler, Di-Pricol Optix gauges, IHC CPS, Premo Oil Refiner, Banks Exhaust brake, SmartLock, Banks Quick Turbo, Six-Gun.
2000 Excursion PSD limited, Banks Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Banks Transcommand, UNI 2-stage foam air filter, 4" aluminized exhaust with 4" down pipe and 2 Aeroturbines.
97 F-250 Powerstoke 4x4 Banks Power Pack etc.
2006 VW Jetta, PD TDI, not modified yet[/i]
carnut57 is offline
post #8 of 9 (permalink) Old 04-13-2006, 12:52 AM
Re: Cam Sensor
Am I missing something? I just Googled the number I provided (as per my invoice from International) and it comes up as a CPS from International. Your number is completely different... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Cheers,
Chris
Roadfrog is offline
post #9 of 9 (permalink) Old 04-13-2006, 11:08 AM
Re: Cam Sensor
[/ QUOTE ]The reason the number is different is that the number I provided and we have been using is actually listed for a DT466 engine not our 7.3L applications. However this part works really well in most trucks, mine included.
I discovered this CPS when trying to chase down a very slight miss under light load conditions ie: crusing on the highway empty. Had the truck to Ford several times and could not find a cause, so I lifted the valves covers and installed the plastic clips on the injector plug, no change. Next I tried changing the CPS with another Ford CPS, still no change. Finally installed the blue CPS for the DT466 and problem solved. My mileage came up about 1.5mpg, the truck runs quieter, smoother and pulls better towing. I like what the blue CPS does for my turck. It is not a part listed by International for our engines, but it works great for me.
carnut57 is offline
