ccv mod question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 08-06-2009, 07:35 PM   #1 (permalink)
ccv mod question
i did this mod about 5 months ago, just ran the 3/4 tube striaght out by the rear bumper. the question i have is can i put a bong into my exhaust and have it run straight so it will be sucked out by the exhaust or will that hurt anything
jcashtrucking is offline
Old 08-06-2009, 07:47 PM   #2 (permalink)
RIStroker2000's Avatar
Send a message via AIM to RIStroker2000
interesting.. good question.. and if possible/okay.. theory being the exhaust would burn the oil/fumes up??
2000 7.3 Extended Cab Long Bed Lariat.... Van turbo (1.15ex.), Casserly stage 1's, DP tuned [()], IH uppies, 07 grille & lights, dieselsite boots, autometer gauges, 6637, walker BTM, CCV Mod, Oil X over, ITP boost anialator, Foil Delete, Add a leaf HD rear springs, leveled, 285 Nitto's, 200 gal. spray tank, 8' Fisher plow winged, 2.5 yard sander.
(waiting for reasonable answers on reasonable questions)
1999 Maxima- 3.5 swap turbo. runs low 12's 1/4 mile
2008 Subaru Legacy (STI swapped)
RIStroker2000 is offline
Old 08-06-2009, 08:22 PM   #3 (permalink)
knoweigh's Avatar
yes many have done just that;
welded a bung in the exhaust near the rear and let er blow!
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
knoweigh is offline
Old 08-07-2009, 02:41 PM   #4 (permalink)
I would just let it be. Or possibly adding a canister if the smell bothers you.
With the exhaust bung you run the risk of increasing the backpressure on your CCV system and turning your engine into a gusher. I've never understood why people feel the need to run it into the exhaust. You basically end up with a risky and unnecessary set up.
2000 F-250 Ex-Cab Shorty - 4x4 - 7.3l - Auto - CAT ELC - 203* - Dieselsite Coolant Filter - AIH Delete - ITP HPX - Bilsteins - Walker BTM - Ford Severe AIS - CCV Canister - SCMT 1700 - Harpooned Tank w/ ITP Pre-Pump Kit - 321k
My truck pics
Check out my 1964 Toyota FJ40 Build
tjsulli790 is offline
Old 08-12-2009, 01:54 PM   #5 (permalink)
deathwishracing's Avatar
If the bung is welded in at an angle, the exhaust actually pulls the vapors out, not pressurizes the ccv. It works great, I have had mine like that for a couple years now. I didn't like the smell and smoke at drive thru windows.
00 black cc dually, auto,6.0 cooler, homemade tymar, AIH delete, boost tube, overboost annihilator, 18k adj, PS2000 propane kit, 4inch exhaust,itp in-tank mod, garrett bb turbo,DPTuner F5 chip(60tow, 80econo, 140extreme),stage 2 split shot 160 injectors,ccv mod,dieselsite 203 thermostat, adrenaline hpop from dieselsite, airbags, lowered 3-5 with DJM kit, Alpine in-dash 7 inch dvd player, 15 inch ceiling monitor for rear, Katzkins leather seats,A-pillar gauges(boost, pyro, airbag pressure, trans temp) Autometer sport-comps, 05' grille,bumper,and headlights with HID's, cowl induction hood, all lights are l.e.d. , 24.5 Alcoa Freightliner wheels cut to 24's with 295/40/24 tires, Red's custom adaptors, new shortblock at 93,000 under warranty.
deathwishracing is offline
Old 08-12-2009, 02:36 PM   #6 (permalink)
aklim's Avatar
I think that on another forum a guy call Eugene hooked up a bunch of gauges and found that somehow there was more pressure in the system with the exhaust hookup.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 08-12-2009, 02:52 PM   #7 (permalink)
Send a message via Yahoo to treytroxell
IMO your better off just letting it go the way you have it.
I have mine ran up and over the master cylinder and then back along the frame rail. Been like that for 2 years with no issues.
1999.5 Ford F-250 7.3l 4x4 PSD With some extras
treytroxell is offline
