Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
OK ive asked in other ccv threads but never got an answer, drag racers use the exhaust system to pull a vacuume on the crank case, now why cant we do something similar on our trucks? I figure the hot exhaust gas's would burn all the oil vapor so the oil couldnt collect in the exhaust system? maintance free?
Currently Owned Vechiles
2005 Ford F-250 XLT CC, LB, 6.0, Auto, 4x4
Subman, Do you have a check valve on that exhaust connection? Looks like you would need one to keep exhaust pressure off the crank case under some conditions?
2002 Excursion Limited 4x4.Black,BTS Trans,ATS ported shroud,AIS,SCMT,SPA gauges,Magnaflow super tuner exhaust,Bilstein shocks,V codes,Hellwig swaybar,Radius Rods,AirDog,CCV3550,JNB fuel mods, Weld EVO Renegade 16x8,Nitto Terra Grappler AT 305/70/16 E Code=NQW5,ART brakes.
I thought about this too. I've had "block evacuation systems" on all my Vintage Pontiacs. On my truck, I didn't take it to the exhaust because of pressure. Majority of race cars aren't turbocharged, our engines have alot of air being pushed through by the turbo. When a race car does smoke, you don't see it being forced out like on our trucks. For me there is too much pressure to route the CCV there.
Remember, this is the internet, where everyone's a diesel mechanic and has 500+hp/1000+lb/ft under the hood! Read up, form your own opinions, then do your own real-world testing!
'01 PSD F-250 XLT SC LB 2WD 6SPD 3.73LS, Alliant AC's,ARP Studs, Stealth Dual HPOPs, GTP38R, Forged Rods balanced, Fluidampr, South Bend CON OFE, 6.0L Intercooler, Volant Intake, 4" SS MBRP Exhaust, A-Pillar mounted Lunar Series Boost/Pyro Gauges,4 pos. Chip with Stealth burns from Twildman, playing with Minotaur Tuning software too, heated Racor 900FH 2 micron, Hutch mods, harpoon mod, DIY Regulated Return, 203 T-stat, coolant filter, AIH gone, CCV Mod, boost pressure relief valve, 100 gallon tank/toolbox combo...AutoEnginuity diagnostics for all Domestics
actually i was thinking installing it on the down pipe and yes with a check valve. i guess i could drill a hole there and see if i get a vacuume or pressure??
How are you going to check at WOT under load? That's what I was worried about!
Checkvalve is not needed. I have had this Style CCV mod for quite a long time(04/27/03) and I do not have backpressure problems. This question comes up fairly often and someone commenting about too much pressure doing it my way of routing the CCV. The higher the rpm equals a higher velocity of exhaust passing by the venturi CCV exhaust port which pulls a higher vacuum to the crankcase. Maybe I just can't explain well enough, but I do not have a crankcase that gets pressurized by the exhaust.
2002 F-250 S/C LB, Auto, VDH5, 3.73LS, My Truck
Complete fuel mods, coolent filter, Heater Cutout Valve, Walker BTM, Gauges(Pyro,Water,Trans), Jody's Econo tuned PCM, Turbo LifeSaver, AIS Severe Duty Filter Kit, Dahl filter and CCV Reroute to exhaust pics. CCV to exhaust since 4/27/03.
Well I can't use your method. My MBRP exhaust is pretty much a straight shot. Where would you recommend installing the bung? [img]/ubbthreads/images/graemlins/confused.gif[/img]
Didn't Suns have a problem with oil leaks after doing his? Did he get it straightened out?
