Check Engine Light - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-30-2008, 05:15 PM   #1 (permalink)
Check Engine Light
I'm a newbie to Diesels but just picked up the truck in my sig a couple of weeks ago. I've noticed when I have my bullydog 6 pack up on 100hp, when I get on it, the check engine light will come on. Its only on for a few seconds, usually until I let off the pedal.
My question is if it doesn't stay on, should I be worried? Could it have something to do with the Garrett turbo? I'm not 100% sure which one it is.
Thoughts or ideas?
2000 F-350 PSD 4x4 Crew Cab Longbed
- Garret Turbo
- Bully Dog 6 position tuner kit
- Banks Full Exhaust with Down Pipe
- Bank Trans Controller
- K&N Air Box and Filter
- Turbo Timer
- Gauges
- Transfer Flow 70 Gallon automatic transfer tank
- Buell Air Horns with 2 ½ Gallon Air Tank
- 4 inch lift with 32” Mickey Thompson ATZs
kooters is offline
Old 11-30-2008, 07:37 PM   #2 (permalink)
fulltimer50's Avatar
My Photos: (16)
Among other things over boost or low high pressure (injector) oil pressure are high on the list.
George
6/2011 F350 PSD Lariate, CC, 4x4, LB, DRW
06 Newmar Cypress 29KSRE 5th wheel/MorRyde IS, Kodiac Disc Brakes.
fulltimer50 is offline
Old 11-30-2008, 09:57 PM   #3 (permalink)
JimTJr's Avatar
My Photos: (20)
Your either over boosting, or the ICP is out of desired range. (The one that goes away after just a few minutes of driving is the Over boost light) Usually the ICP one just sets a code, with no light IIRC.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 11-30-2008, 10:29 PM   #4 (permalink)
So keep my foot out of the throttle when I have the 6 turned all the way up? Sounds easy enough...
- Garret Turbo
- Turbo Timer
- Gauges
kooters is offline
Old 11-30-2008, 10:41 PM   #5 (permalink)
I presume, you have a boost guage. If the boost exceeds about 20 psi, the map sensor trips the light, and defuels the motor. A boost relief valve should solve the problem.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
Old 11-30-2008, 11:04 PM   #6 (permalink)
My Photos: (6)
First, get some gauges.
Second ( I know i'm gona get flamed for this) get a code scanner that can read our trucks (extended OBDII). When you get a code, it will be held in the computer for several start/run cycles. This will tell you exactly what's going on. With that information, you'll have what you need to determine if it is something that can be ignored.
The other thing nice about the scan tool is all codes do not generate a SES light. Pulling codes once a week or so is a good start to how your truck is running.
I personally like AutoEngunity and pull codes once every two weeks (light or not) and have found some interesting things about my truck even with no ses light.
Happy Thanksgiving
DNR
01 250 PSD Lariat; Off Road; SB; Green; Beige Leather; Black Tube Steps; Tonneu Cover;
Reverse sensors; K&N Air Filter; ;Banks Six-Gun Tuner & Monster Exhaust; A-Pilar gauges; Rancho RS9000X; Marinco plug upgrade;Auto Enginuity Scan Tool (Laptop); Truckputer beta installed; Towing 01 Timberland 28FBS; Statpower 20+ charger; 1kw Inverter with auto transfer switch; Custom AV Systemhttp://photos.thedieselstop.com/showgallery.php?cat=998&thumb=1&si=dnr250
dnr250 is offline
Old 12-01-2008, 12:28 AM   #7 (permalink)
I do have Boost, EGT, Trans temp and even fuel pressure gauges. I will look into checking the codes and see what I can find. I just bought this truck a couple of weeks ago and still trying to figure out what I've got.
Thanks for the suggestions.
- Garret Turbo
- Turbo Timer
- Gauges
kooters is offline
Old 12-01-2008, 07:04 AM   #8 (permalink)
JimTJr's Avatar
My Photos: (20)
I believe the over boost sets at 25lbs, not 20. So watch them, see when the light coincides with the boost reading.
If you plan on working on your own truck often, AE is a great investment. I was one of the first 25 buyers of it of a group buy on here. I got a good deal, and learn every time I plug it in... The ONLY thing I wish it offered was a better explanation of the "Tests" it runs. Some of which are not as self explanatory as the "Buzz test" or CCT. The KOER, KOEO, I know how to RUN them, but it would be great if during these tests you know what is being tested when,, just to be a little more educational.
JimTJr is offline
Old 12-01-2008, 11:13 PM   #9 (permalink)
Jim,
Does SLAPS meet monthly? I know a guy in your club that is in my Jeep club. I'd like to hook up with some local folks and the club.
- Garret Turbo
- Turbo Timer
- Gauges
kooters is offline
