Clutch master/slave cylinder - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-14-2006, 06:34 PM Thread Starter
Clutch pedal went to the floor and stayed there today. After searching this forum I suspect the master/slave cylinder needs replacement. Found some posts saying this was a quick and easy job when replacing with the pre-bled kit from ford but found no instructions.
Any help would be appreciated. Looking for tips or detailed instructions on this job.
2001 F350 7.3 Lariat CC
keithwolak is offline
post #2 of 6 (permalink) Old 05-14-2006, 06:45 PM
Re: Clutch master/slave cylinder
First check and make sure the clutch master pushrod did not fall off the pedal. If it didn't, then it sounds like the hydraulics are bad. The master & slave cylinders remove by pushing in and turning 1/4 turn CCW then pull them out. The pre-bled kit number is 2C3Z-7C522-CA and was about $110 when I picked mine up.
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
post #3 of 6 (permalink) Old 05-14-2006, 08:49 PM
When you replace them make sure and get the pre-bled kit and the replacement pushrod for the master cylinder- its almost impossible to get the old one out. Take the slave out first, push in and 1/4 turn ccw, pop the line out of the retainers/clips, then disconnect the master cylinder from the clutch pedal (the little plastic clip will probably break). Under the hood pop the reservoir off the truck (leave the hose connected) and pull the master cylinder (1/4 turn ccw). Same thing in reverse to reinstall everything. If this doesn't fix your problem its time for a new clutch.
Ben
2000 F550 XLT CC 2wd Black, custom flatbed w/ GN, ZF-6, SB Con-OFE clutch, 5" exhaust, big intake, DP chip
KC8IHF
Stroked550 is offline
post #4 of 6 (permalink) Old 05-14-2006, 09:48 PM
Before taking the slave cylinder out make sure that the clutch pedal is off the floor, It will still have some pressure and is hard to get push it in and turn a 1/4 of a turn with all the pressure. [img]/ubbthreads/images/graemlins/wink.gif[/img] Been there done that.
99.5 f250 4x4 6spd
ole_blu is offline
post #5 of 6 (permalink) Old 05-14-2006, 10:53 PM Thread Starter
Thanks for the info, will be parts shopping tommorrow
post #6 of 6 (permalink) Old 05-15-2006, 08:50 PM Thread Starter
One trip by the stealership and 15 minutes in the driveway and I am back on the road...shifts like new. Thanks again for the info, especially picking up the extra pushrod...it was definetly required.
I have been a wallflower on this site for months now and have learned a ton but this was my first time posting anything, you guys are great.
