code P1249 eappearing ?? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-28-2007, 09:40 AM Thread Starter
ELLIOT02's Avatar
I am getting the P1249 code(wastegate fail steady state test).I have cleared the code and it reappears AGAIN.I have a new turbo and actuator arm and have checked my green and red vacuum lines for cracks and fitment.SES light does not come on,but SCT 1705 reads this code repeatedly.Boost will reach 28psi WITH leaky uppipes.WHAT,WHY,WHERE? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] What else should I look for?Thanks.
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. BTS tranny with 6.0 cooler,coated TN bb1.00 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P Tuner.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,PML pan,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods. Hawks and Powerslot cryo's
ELLIOT02 is offline
post #2 of 8 (permalink) Old 02-28-2007, 10:00 AM
Strictly Diesel's Avatar
Feedback Score: 3 reviews
Re: code P1249 eappearing ??
I don't know what the MAP MAXIMIZER is, but it's apparently allowing the PCM to see that you are making too much boost. Here is the official description of the code you are getting from the Ford diagnostic manual.
DTC P1249 indicates that the PCM detected the turbo was overboosting.
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Strictly Diesel is offline
post #3 of 8 (permalink) Old 02-28-2007, 11:28 AM
I agree with Dennis, your MAP MAXIMIZER isn't working properly.
Master Certified Diesel Tech
1999 F-350 4 door long bed 4x4. 4in lift, deaver springs, fox shocks, dynomite injectors on the way, dp tuner F5, dual 7.3 fuel pumps, Spearco retrofit intercooler, custom regulator return kit, ceramic coated IH up pipes, 5in mitre cut stacks, custom front bumper. Terminator High Pressure Oil!
<font color="red">Black Widow Diesel exclusive Turbonetics Towing Compound turbo kit-In testing. More info available soon at
</font>
sanddrag69 is offline
post #4 of 8 (permalink) Old 02-28-2007, 01:59 PM Thread Starter
ELLIOT02's Avatar
It still throws the code when in stock and reaching only 20 p.s.i.. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
ELLIOT02 is offline
post #5 of 8 (permalink) Old 02-28-2007, 02:33 PM
Take out the MAP device and see if the code goes away.
post #6 of 8 (permalink) Old 02-28-2007, 02:36 PM Thread Starter
ELLIOT02's Avatar
OK. I will try that.
ELLIOT02 is offline
post #7 of 8 (permalink) Old 02-28-2007, 02:37 PM
NorCalDiesel's Avatar
Take the Maximizer out and plug the stock map plug into the MAP and see what you get. If you still get the SES light get a scan tool to look past the DTC codes. It may just be the MAP itself.
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
Super Heavy Duty / Triple Disc 4R100 built by Jim Galatioto at ATO Transmissions in Sacramento.
NorCalDiesel is offline
post #8 of 8 (permalink) Old 02-28-2007, 03:56 PM Thread Starter
ELLIOT02's Avatar
First run was 20psi and read code p1249,second run 10psi and no codes.Both without Maximizer.SES light does not come on but does throw code.I inspected Maximizer and both end look to be in tact.I cleaned MAP connections and various other harnesses with electric contact cleaner.I will try some other combinations with boost and maximizer to see if Map Maximizer is the culprit. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
ELLIOT02 is offline
