compressor housing upgrade - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-17-2009, 10:42 PM   #1 (permalink)
just bought an 01 F 250 7.3 PSD auto and was wondering if there are any cheap compressor upgrades
JONBOY82 is offline
Old 11-17-2009, 11:25 PM   #2 (permalink)
CHILLLS's Avatar
im looking at getting the banks compressor wheel & the big head wastegate
Banks High-Boost Compressor Wheel
Banks BigHead Wastegate Actuator
02 7.3l psd 6 spd 4x4 cc lb srw
cut muffler
afe stage 2 pro guard 7
wicked wheel
superchips programmer
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
viair 480c compressor
5 gal. tank running 200psi
train horns
firestone bags
piaa supper white head lights
70 gallon in bed tank
warn semi hidden winch mount
warn 12,000 winch
piaa 4" smr fog lights
thats it for now but more to come
CHILLLS is offline
Old 11-17-2009, 11:27 PM   #3 (permalink)
CHILLLS's Avatar
o ya & dont forget this
Stage II Intake System
cut muffler
wicked wheel
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
train horns
firestone bags
warn 12,000 winch
CHILLLS is offline
Old 11-18-2009, 04:54 PM   #4 (permalink)
My Photos: (19)
Why?? Do you have surge?
If you aren't running a hot tune and pulling a trailer then you will not get any benifit from changing anything but a complete replacement.
What you are looking for is the ATS Ported Compressor Housing. Right now I think they are a bit tricky to get ahold of. Keep looking.
What the Banks Wheel is, is nothing more than the stock pre-00 (I think??) compressor wheel that has a staggered fin design. More commonly known as the Wicked Wheel.(WW) Some, I included, have reported a loss of performance when using the WW and stock housing. I pulled my WW and bought the ATS housing.
Do us a favor, fill in your signature so we know what your truck has so we can better address your questions.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 11-18-2009, 11:19 PM   #5 (permalink)
I've been hearing about the ATS housing, can you tell me whats involved in replacing it, are all parts included, and how much is it? I've had my turbo out before so I'm familier with that part of it. Does it come with a new wheel? My original is shot. What benifits does it give? More boost, or just control surge? Thanks!
2000 F250 7.3L Auto. CC 4X4 Lariat SB, 3.5 Fab Tech lift, 16X10 Typhoons 305/70/16 BFG's, AFE Stage2, Banks Big Head, Banks Exhaust, Bellowed up-pipes, Quadruple gauges, Wicked Wheel, Trans Go shift kit, Eaton TrueTrac, DP-Tuner F5, Stock, 60T, 60E, 80E, 120R.
JamieWS6 is offline
Old 11-19-2009, 12:55 AM   #6 (permalink)
CHILLLS's Avatar
what is this (WICKED WHEEL)
where can i read some specs on it
cut muffler
wicked wheel
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
train horns
firestone bags
warn 12,000 winch
CHILLLS is offline
Old 11-19-2009, 01:00 AM   #7 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Ron's turbo shop, he sells on e-bay, housing,wheel,complete turbos...
nice customer service and prices are not bad, you don't have to wait months for a ATS ported housing, he usually has it in stock and it comes with a new wastegate as well.
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 11-19-2009, 01:37 AM   #8 (permalink)
CHILLLS's Avatar
this is just a question & you dont get answers with out questions
why is the wicked wheel better than the banks or what is your opinion?
i like info to better make my decision on a purchase
feed back more than welcome
cut muffler
wicked wheel
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
train horns
firestone bags
warn 12,000 winch
CHILLLS is offline
Old 11-19-2009, 01:45 AM   #9 (permalink)
CHILLLS's Avatar
is it just the price that makes the wicked wheel the one of choice, are the fins at a better pitch, is there more fins than the banks or less than stock?
the reason i ask is im looking into doing the wheel & big head & i like read about something before i buy it...good or bad..
like i said you input is valued
cut muffler
wicked wheel
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
train horns
firestone bags
warn 12,000 winch
CHILLLS is offline
Old 11-19-2009, 01:54 AM   #10 (permalink)
From what I've been told, and researched, the W.W. and the Banks are the same compressor wheel. Banks just charges more for it. I bought mine for about $75.00, but can't remember from where right now. Hope that helps.
JamieWS6 is offline
Old 11-19-2009, 02:16 AM   #11 (permalink)
Deputy Diesel's Avatar
yea like everything that banks does they charge twice as much for little or no results. but you do get a bunch of stickers and everything is painted a pretty red!!!!
you can get the ww from almost anywhere and they are usually about $75-100 range.
as for the use of the wheel its going to stop your surge if you keep your truck fairly stock and you might pick up a little quicker spool good bang for your buck. the ats housing is ultimately a better upgrade but at a higher cost. and a aftermarket turbo again would top that
03, ext cab, dually, 4x4, lariat, 6 grip, 7.3L, DP Tuner 60tow 80econ 120race 140extreme, southbend con O, mbrp cool duals,afe stage 2, Custom PDR feed pipes, PDR Super GTP hybrid turbo, Custom drop front hanger and shackle leveling kit , 315/75/16 BFG Mud terrains, steel 2inch rear dually spacer, 10inch wide single front wheels spacer removed
1954 Dodge M43 Military ambulance, built 360, 4 speed, 39inch militaries
87, f250, d60 front, 6 inch lift, 37's on 20's, 5.9L cummins all the mods, nv4500, southbend fe, s300, 5inch exh.
97 suzuki tl1000s two bothers exh all the mods.
85 honda 250sx trike. 3 wheelin 4 life!!!!
Deputy Diesel is offline
Old 11-19-2009, 07:05 AM   #12 (permalink)
The WW and the Banks for that matter is just a wheel from a 99. I see no differance but more whistle from turbo, I think the ATS housing is the way to go.
2002 f250 7.3 lariet cc auto srw short bed 3.73 gears,16k reese slide hitch,reese brake controller,banks 4inch monster exhaust,autometer lunar guages tranny,boost,egt.aFe air box,sonnax valve and tri springs,magnefine,factory aic,led lights in running boards,TS 4pos chip,DR 4.5 lift
03 tt heated/signal mirrors,wicked wheel
94 Pace Arrow 33L Class A P30 454
04 custom ridgid chopper 120RWHP
http://community.webshots.com/user/oneHD
HDone is offline
Old 11-19-2009, 12:41 PM   #13 (permalink)
Feedback Score: 3 reviews
Actually a WW is a stock '95-early 99 wheel. Good mod is a 1.0 A/R NON wastegated Turbo Housing with adapter cheaper than the ATS and works great for stock or stage 1 Inj.s Use a WW with it.
Cary
caryt is offline
Old 11-22-2009, 10:26 PM   #14 (permalink)
so the WW can be used with the larger 1.0 A/R housing i plan to add a programer and an air dog before doing the compressor upgrade
JONBOY82 is offline
Old 11-22-2009, 10:51 PM   #15 (permalink)
knoweigh's Avatar
save yourserlf about $400 and do a 6637 filter.
Everyone has different opinions, but as for me. I suggest intake & exhaust, then gauges.
After that, IF you're going to chip it and/or pulling alot of weight, start messing w/ turbo....otherwise leave well enough alone. I've got the Wicked wheel (old style, banks, performance or whatever ya wanna call it) & turbomaster wastegate controller and it ONLY has improved my situation because of my chip (more fuel). If I turn my chip to stock mode,........LOL, my truck is a complete DOG! On the other hand, toss some extra fuel (chip) at it, and she'll pull hard all day!
IMHO if you're not running a chip, stick w/ stock wheel.
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
knoweigh is offline
