Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
You could do it yourself no problem in a day. I yanked my turbo the first time and put it back on in about 3 hours. Its not that big of a deal. There are lots of free how to do on the internet with lots of pics.
here is how to pull the turbo. You will need to replace the pedestal with a non ebpv pedestal and replace the flange on that holds the ebpv butterfy valve on the turbo with a one that does not have the valve in it.
I did it so it would never leak again and I have better airflow.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
