Couple of DP tuner questions - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-11-2009, 10:54 AM   #1 (permalink)
jfdfire2's Avatar
Ok the DP tuner chip is in and working...the change in my truck is incredible!!. I do have a couple of questions. in 80 Econo I have notice that the tranny is shifting way different as a matter of fact it seems like it now has a 5 speed rather than the 4 that I know it is. What is it doing and is it normal?
secondly, I have noticed the truck shifting down alot. Is this something that normally is there and is just more noticible with the 80 econo tune than the others?
and finally it is cold here and I have been starting the truck in the stock setting. I have been waiting for the engine temp gauge to hit the lower mark on the gauge before going to a dp tune is that good enough? I dont want to blow up anything.
Other than these questions I am really happy with the DP chip so far, should make the 5th wheel pull much easier.
2000 F-250 Crew cab, BTS transmission,
AIS with Zoodad Mod
Marinco mod, Walker BTM, Autometer gauges
DP tuner with stock, 80E, 1100 hi-idle, 60 tow, decel, 120 race
08 rear diff cover, 07 harley headlights, diesel site coolant filter, 08 center console, LED tailight upgrade
Kenwood 5120 DVD/NAV, 285 TOYO AT's
Gone with the wind 31.5 Jayco BHDS rip
jfdfire2 is offline
Old 01-11-2009, 04:42 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Normal.
You're probably feeling the torque converer lock up. Engine RPM will fall about 200 RPM when the torque converter locks up at around 37 MPH (unless Jody changed the speed at which the torque converter locks up). Plus it will shift into overdrive, before or after the torque converter locks up, depending on your right foot.
80-E is not meant for towing. If you tow more than a rowboat, then switch to a towing tune, which will downshift much less frequently. In fact, with the 40-tow program, mine won't downshift except for really major grades. But with 80-E it will downshift for smaller grades.
Much ado about nothing. Whether 80-E, 80-T, 60-T or 40-T, you can crank the engine and warm up the truck while driving with one of the milder tunes - less than 100 HP. Just baby it until the coolant temp gets up to normal, regardless of tune installed. Mine is almost always in 60-T, even for unloaded cruising. I never change tunes just because of cold weather.
But then I never use 100 or more performance tunes, either.
SmokeyWren is offline
Old 01-11-2009, 04:50 PM   #3 (permalink)
415_dezl's Avatar
Yes everyting smokey wren said HAHAH. Gotta love that TC lockup feeling..especially when you're hooked to a very heavy trailer. My old lady was sleepin i n the fifth wheel and when it downshifted she called me on the celly...saying....*what did you just hit? *
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
2005 40' Weekend Warrior 5er, SLC 3905
1977 Tahiti 21' / Berkeley Jet Daycruiser/ 455 Olds.
2000 Sandcars Unlimited / Turbo VW 2275
1988 Ford Thunderbird Turbocoupe 2.3
415_dezl is offline
Old 01-11-2009, 04:58 PM   #4 (permalink)
jfdfire2's Avatar
Originally Posted by SmokeyWren View Post
Normal.
Ok but I have not towed anything yet. The down shifting accures as I am slowing for a traffic light, stop sign, traffic, etc.
and I tried out the 120 race tune after I installed the chip....it scared me a bit, it is diffentantly more tune than I want/need, wont be using it again any time soon.
AIS with Zoodad Mod
jfdfire2 is offline
Old 01-11-2009, 09:19 PM   #5 (permalink)
fxdwgi's Avatar
I run mine in 120R setting almost 100% of the time. No problems...
Just make sure your engine is FULLY warm before hankering down on the pull-me-over pedal.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 01-12-2009, 12:44 AM   #6 (permalink)
I'm curious about the downshifting when slowing as well.
Mine downshifts when slowing in every program I have, 40 tow, 80 econo, and 120 race.
It's a little irritating when in traffic around 43 mph, and the truck keeps downshifting.
2003 F-250 7.3
4x2 Crew Cab SB
Garrett Ball Bearing Turbo
40HP injectors
D-P Tuner F5 chip
Ford AIS, with foam shroud and side intake
4" MBRP T-409 Exhaust Turbo back
Vegetable Oil Conversion
1997 F-250 7.3
4x2 Super Cab
D-P Tuner "econo tune" PCM
over 340k miles and countin'
PreservedSwine is offline
Old 01-12-2009, 02:18 PM   #7 (permalink)
aklim's Avatar
I wouldn't tow with the 80E. The shifts are quicker and NOT as friendly towards whatever you are towing. In my case, WGAS? The trans is covered. Problem is that whatever is inside my Toy Hauler might not like a flight from the shelves to the floor.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 01-13-2009, 09:58 PM   #8 (permalink)
Does the DP tuner make quite a bit of smoke on the 120 race level? I have always wanted to be able to blow a little black smoke here and there.
dieselman33 is offline
Old 01-14-2009, 01:03 AM   #9 (permalink)
415_dezl's Avatar
mine makes plent of smoke in the 80 e mode..at 2500 ft here especially
415_dezl is offline
Old 01-14-2009, 07:38 AM   #10 (permalink)
aklim's Avatar
My 140 was bought specifically as a smoke tune. It will dump ungodly amounts of smoke. Perfect for giving somebody the finger without giving them the finger.
aklim is offline
Old 01-14-2009, 10:03 AM   #11 (permalink)
fxdwgi's Avatar
The 120R makes some smoke, but get the 140X setting.
It is great for rollin the coal on the foreign car behind ya.
fxdwgi is offline
Old 01-15-2009, 11:25 AM   #12 (permalink)
Does anybody know what kind of torque increases are with the 60T and 80E modes?
Fin
2002 F250 SRW CC 4x4,diy intake, BTM muffler, gauges, zoo dad, DP Tuner60tow, 80econ, sonnax, AIH delete,ATS Housing,
finman is offline
Old 01-25-2009, 10:57 PM   #13 (permalink)
DP tuner and shifting
I have a 2001 F250 with a SCT Tuner with 40/80/120 tunes. Mine does the same thing on the 120 tune. Right at 43 it will upshift if slight acceleration, and when coasting, it will downshift at 43-42 as soon as I just touch the go-pedal.
My 80 tune is pretty good but seems to upshift too early. I have heard that is necessary for the econo - getting into a higher gear earlier, but it is a bother at times.
I havent used the 40 enough to remember but will do some driving with it too.
Bruce & Carolyn Wittmeier
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, DP-Tuner 40/80/120HP, Chrome Step, Line-X bedliner, Jordan Ultima 2020, AirLift 5000 Airbags, DiPricol gauges
wittmeba is offline
