Dino's regulated return - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > '99 & up Upgrades and Aftermarket - 7.3L Engine
Old 10-16-2009, 08:22 PM   #1 (permalink)
bigb's Avatar
Has anyone tried the $199 regulated return kit from Dino Fuel Alternatives?
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 160K, BFG Rugged Terrain 285s, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, ELC, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Red Head steering gear, Battery Tender & 2 Marincos.
bigb is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 03:46 PM   #2 (permalink)
I havent tried it or seen it till your post but the price is good. I am curious about this also
2002 F250 7.3l Lariat
4'' MBRP turbo back straight pipe,Tymar,Superchip Flashpaq 1855,Boost,EGT,aih delete,wicked wheel
brc51m is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 09:54 PM   #3 (permalink)
ajohansson's Avatar
I have not used the dfa one but I have the ITP kit built into my veg system and it is top notch.
1999.5 F-350 CC-SB 4x4 - 7.3 liter
2003 Excursion 4x4 - 7.3 liter -
ajohansson is offline   Reply With Quote Quick reply to this message
Old 10-19-2009, 01:14 PM   #4 (permalink)
aklim's Avatar
Probably will cost more when you count the cost of the fuel pressure regulator with the DFA one does NOT have.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline   Reply With Quote Quick reply to this message
Old 10-19-2009, 01:30 PM   #5 (permalink)
olddieseldude's Avatar
My Photos: (16)
I don't think this is correct...per the product description:
"...The kit will include EVERYTHING needed to do the job except the tools. This kit is adjustable but comes preset to ~65psi and is applicable to 1999-2003 7.3..."
Probably just an adjustable check valve spring though.
RickN
White '99+ F250 SD XLT 4x2 SRW, 7.3PSD, 6spd, SuperCab, Short Bed
(mods listed in comments under photo in above link)
olddieseldude is offline   Reply With Quote Quick reply to this message
Old 10-19-2009, 01:53 PM   #6 (permalink)
aklim's Avatar
Dino Fuel Alternatives | Product Detail
I don't see a fuel pressure regulator in the pic.
Old 10-19-2009, 02:05 PM   #7 (permalink)
My Photos: (16)
I suspect the long hex part on the near left of the picture is an inline regulator
RickN
Old 10-19-2009, 02:09 PM   #8 (permalink)
hugestroke's Avatar
looks cheap
2000 f 250 7.3 liter auto. Started as a xlt truck has been up graded to a lariat. 8 inch fabetek lift. 20 inch eagle alloys painted black. 41/14.50/20 super swamper irocks.05 head lights with 10,000k hid's. Turbo back 4 inch into two 6 inch stacks under bumper. edge juice with attitude. k&n cold air. ready for dp and ingectors.
hugestroke is offline   Reply With Quote Quick reply to this message
Old 10-19-2009, 02:15 PM   #9 (permalink)
aklim's Avatar
Originally Posted by hugestroke View Post
looks cheap
OTOH, when you have the ITP kit, it looks so professionally made and fits like it was meant to.
Old 10-19-2009, 02:23 PM   #10 (permalink)
My Photos: (16)
Agreed! But, if it works, there's a $300 difference to consider.
I guess it's just a beer or champagne decision.
RickN
Old 10-19-2009, 02:30 PM   #11 (permalink)
aklim's Avatar
$270 difference. By the time you consider a real regulator which is about $140 and a gauge that is about $25, you have about $100 of difference. That "regulator" is a pretty cheesy looking unit when you compare it with the Aeromotive A1000-6 unit.
Old 10-19-2009, 03:02 PM   #12 (permalink)
My Photos: (16)
I'm just comparing with what they are offering.
If you want to make a direct feature for feature comparison, it's probably more expensive than the ITP unit. Including what you've pointed out the ITP unit uses better and more expensive hoses and fittings. The fuel line and barbed fitting provided can't cost much. But again, if it works as advertised and doesn't end up dumping fuel all over the engine after a few years, it's like comparing guages to an idiot light, depending on the end user the cheaper unit may be sufficient.
RickN
Old 10-19-2009, 06:44 PM   #13 (permalink)
hugestroke's Avatar
not to mention it dosent come with bradied lines. just cheap rubber.
Security Question
*Required, this field is not shown to others. "While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of. "
Insurance
Please select your insurance company (Optional)
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
