disconnect wastegate red line - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 08-07-2008, 11:17 AM   #16 (permalink)
VinsonKing's Avatar
Send a message via Yahoo to VinsonKing
Never mind. I got it! Thanks bro.
2002 F-250, Banks compressor wheel and big head waste gate, 4" stainless strait pipe, edge attitude with juice, and afe stage 2 intake.
VinsonKing is offline
Old 08-10-2008, 01:31 AM   #17 (permalink)
Originally Posted by VinsonKing View Post
Do you have to cap off each end of the red line after you cut it?? I pulled the line off and my boost did nothing.
And what is the address to deiselsite?? I tried going there and it would not come up??
If you already have a banks Big Head you will have no benefit unplugging the red line. The Banks is designed to control the wastegate with the line connected. The problem with the stock actuator is the weak spring preventing blow off. Unplugging the line is just a cheap fix not a complete solution.
BIG DUTY is offline
Old 08-10-2008, 09:45 AM   #18 (permalink)
JimTJr's Avatar
My Photos: (20)
Originally Posted by 69mach1377 View Post
You can modulate this a bit with a plastic T setup which will bleed some but not all of the signal. Start with the T uncapped. If that doesn't lower it enough, try a cap with a small hole. Then increase the hole size.
Has anyone done this before or did I 'discover' it first?
Most put a small brass tube in there and drill a small hole in it, (New rubber hose about 1" long, brass tube, then the original hose.)
Called a "Boost tube" I ran one for a while, but really, HIGHER boost numbers do not mean higher HP, you can make more horse power with lower numbers if the volume of air is there...VOLUME is the key. More air More power. And contrary to popular belief, higher pressure does not always equal higher volume.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 08-11-2008, 12:46 AM   #19 (permalink)
westvandude's Avatar
Got that right. I played with it without the red tube for a while but saw no benefit besides higher boost on my gauge so I put it back on.... saving up for a DP tuner now.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
Old 08-11-2008, 02:00 AM   #20 (permalink)
i just pulled mine off and put some duct tape on the end of the red line to keep junk from getting into it. gained about 4 psi.
20 years old trying to build my first diesel machine...
2000 F250 red ext cab 7.3L PSD. 4x4 off road pkg. 6 speed manual. diy 6637 air intake w/ afe intake tube. 4" turbo back magnaflow straight pipe. 5" afe tip. DP Tuner F5 stock, 60t, 80e, 100p, 140a. 3 pos pillar pod autometer phantom pyro/boost gauges and DP control. extang trifecta tonneau. 34 in toyo open country m/t. bull bar with 2 6 in. KC daylighters.
Pray for our country.
1928 Ford Model A stake truck. 1931 Ford Model AA dually flat bed.
achowell is offline
Old 08-19-2008, 01:17 AM   #21 (permalink)
unless you want alot of crap in your vacume lines you may wana plug them up. sounds like common sence. what do you think?
oldfordratrod is offline
Old 08-19-2008, 10:22 AM   #22 (permalink)
I think you don't know those lines aren't vacuum lines.
444-4D is offline
Old 08-19-2008, 03:58 PM   #23 (permalink)
It's not vacuum. Something less than 5psi or whatever.
Old 08-19-2008, 08:50 PM   #24 (permalink)
i had mine plugged for a while when i turned my chip all the way up and put it to the floor it would set the engine light off. the turbo sure did whistle loud which i liked. i hooked it back up when i went on a trip just to make sure i had no problems. i don't have a boost gauge though i need one..
early 99 f-250 315/75/16 3.5 inch fabtech shackle lift,intake,4" exhaust 5" single stacked,DIY t/c lock, billet t/c and shift kit on a fresh rebuild,beans tunes ,4 hella lights, 05 head light, 05 chrome grill,red wire pluged, HID lights 200k
other toys
2008 ltr450
2002 440ex
blandproud is offline
Old 08-24-2008, 04:20 PM   #25 (permalink)
This mod did nothing for me but raise my boost numbers about 4 lbs. I couldn't feel even a minor increase in power. I'll be reconnecting the red tube shortly.
99.5 F-250, 4x4, Supercab, 6 Spd., AFE Stage 2, Wicked Wheel, MBRP 4" exhaust, Autometer Boost and Pyro, 265/75/16 BFG A/T
FILDO is offline
Old 08-24-2008, 09:25 PM   #26 (permalink)
PStroked444's Avatar
Pulling the red hose means more boost. Not more power.
99.5PSD, F250, 4x4, wht. CC, SB, Line-X, 200K+ , 6spd,LUK Ceramic Clutch, Warn Premium hubs, DP Tuner F5 stock/high idle/40T/60T/80E/100hp, Casserly STG1 sticks, DIY TYMAR, No EBPV, 08 Diff Cover, 4"MBRP S/S, Banks wheel*traded for stock wheel*, ATS Housing, HXLine, Zoodad Mod, CCV Mod, AIH removed, Shimmed fuel, Isspro Boost Guage & Pyro Guage, 2" Level Kit, Firestone Air Support Springs, BFG AT k/o, CB Galaxy DX949, DUAL Antennas, Lead Foot came stock
1998-F150 4x4, LB, K&N, No Kitty, 24LB inj, CB...Wifes ride.
94 Mustang GT, Red, Black Saleen rims, T-5, intake, exhaust, cam, 24LB squirts, tuned, last of the 302...
PStroked444 is offline
Old 08-28-2008, 05:07 PM   #27 (permalink)
Powerstrokin400's Avatar
My Photos: (18)
Boost & Foolin' the waste gate.
I know there are several ways to fool the waste gate actuation, from electronic "Boost Foolers" to homemade ideas. For what it's worth, this has been my experience. With my current set-up, I am running 25-27 psi, under load, using a Bully Dog Programmer @ 120 hp setting, and 4" Exhaust. Next, if you are able to turn the "turnbuckle" (some will, some wont) on the waste gate rod, you can delay the activation (extending the rod delays the activation). Be careful exceeding 30 psi without addressing the down-boot issues as previously mentioned. Next would be similar to the "T" idea, only splicing a small brass tube, inserted inline with the waste gate line. Here you drill a 1/8th inch hole in the brass tube, which can get you up to 31 psi, depending on your vehicle & set-up. This will also allow the waste gate to function if you have to dump the throttle suddenly, yet nearly elimintaes that annoying pulse/squeel while towing heavy loads up-hill. We had good results on a 2002 7.3L Super Duty 4X4, with this method, and my 2003 7.3L Super Duty 4X4 will receive the same Rx soon. Operating without the waste gate hooked-up is a gamble. Good Luck!!!
2003 F250 XLT 7.3L, Auto, FX4, Crew Cab, Long Bed, 6.5" Pro-Comp all spring lift & Firestone HD Rear Air Bags, BFG KM2 37x12.50x17 tires on Eagle 17x10 Rims, 4" Turbo Back Exhaust & muffler delete, Bully Dog Programmer @ 120 Hp setting ALWAYS, Machined & Bellowed International Up-Pipe Kit, Autometer Overhead Gauges (Boost, Pyrometer, Trans. Temp), Custom Pre-Filter Ram-Air with K&N filter, "John Wood" Custom Stage I Transmission, 6.0 Billet 3 Disk T/C, External T/C Lock-up switch, 6.0 Trans Cooler, Hughes Racing Deep Structural Pan, and a few more goodies. Now spinnin' AAM Rear & Dana Spicer Front 4.30:1 Gears with Warn Premium Locking Hubs.......I do a lot of towing.(13,000 lb 33' Toyhauler & 21' Ski Boat). 84,568 miles as of 11/09
So. Cal. Fireman
IAFF Local 2342
Other Rides:
2006 BMW 330i Sport
1992 Camaro RS 5.0L, 25th Anniversary
1990 Mustang LX 5.0 Sport, 5spd., 25th Anniversary
Powerstrokin400 is offline
