Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
I buy the 3.5" Schedule 40 rigid PVC (cheap), it has an outside Dia of 4". Then all you need is some hose clamps. My 99 needed a 45 elbow but the 2000 just needed a straight union piece. I also remove all the OEM filter housing. So I don't lose the screws I took out, I put them back in the original locations.
Best Regards,
2K Excursion Ltd Burg Auto, 175k 2K F350 DRW Lariat 6spd CC White/tan, 248k Late 98 (04/98), WHT F250 Std Cab 6 spd, 356k miles
Engine Coolant Filter, fuel and hpop crossover Hutch in tank mod
open ccv
6637 air filter
looks like a muffler (looks can be deceiving)
DP stock, 80T, 80E, 140 Extreme (normally in extreme and still get 19 plus mpg)
fuel gauge on bowl and shimmed return $$$ Penny glow plugs at AutoZone Pics
I bought a 4" long section of 4" diameter exhaust pipe from a local truck shop and used that on my 2000 Excursion PSD. Worked great. [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Yep, go to a "BIG RIG" place, Peterbuilt, KW, ect... get a 4" 45* elbow, and the constant torque clamps. Map out what you need by laying the filter in, and figuring out where your coming from, or what your going to use.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
I just used a piece of 4" exhaust pipe that I had left over from putting my exhaust system in. I just used worm clamps I found that with the engine heat the rubber from the filter and the intake tube gets stuck on the exhaust pipe very well.
2001 F250 4X4 CC automatic, 3.73 open diff
DP Tuner 40 tow, 60 tow, 80 econo, 120 race
BTS Transmission, 6.0L 31 row transmission cooler
4" turbo back exhaust no muffler
Open element Air Filter, AIH Delete
ISSPRO gauges; EGT, Boost, Trans. Temp, Vacuum (for intake), Air Pressure(for upcoming onboard air).
Hutch and Harpoon mod with pre pump filter
Coolant bypass filter
Fumoto drain valve
'08 finned differential cover (all stainless hardware)
'08 Tow mirrors
Bulldog Deluxe 500 remote starter
285/75/16 Cooper Discoverer ST tires
Rancho RS9000XL Shocks
Air Lift front air springs
Blizzard model 810 Snow Plow
I have that same PVC 45 elbow. I wonder if the 3.5" inside diameter is very restrictive?
Early 99 7.3 F250 Extended cab 4x4 6-speed 200,000 miles DIY intake, MBRP 4" single exit, Isspro EGT and boost, DP Tuner 80 econo flash, South Bend clutch Carbotech Bobcat front brake pads, Door seal and Snowman mods...
Update....I installed my "DIY Tymar air intake". I used a piece of 4" exaust pipe I got from a big truck parts shop. I didnt need an elbow and I didnt omit the valve (the piece of straight pipe in the picture).Seems to work good. Thx to all here @ TDS...Im learning alot about my PSD!!
99.5 F-250 Super Duty w/7.3 Powerstroke
4X4 Short Bed/Crew Cab
Magnaflow 4" Turbo back SS Exhaust/5" Tip
DP-Tuner>No-Start,Stock,High Idle,60HP Tow,Decel,80HP Econo,120HP Race,Lope Idle
ATS Housing
HPX Crossover
AIH Delete
Autometer Ultralite Series Gauges(Boost,Pyro,Trans)
Bellowed Uppipes
Rancho RS 5000"s
DIY Tymar/6637
Custom/Spicer Driveline
B.T.S. Valve body
AIH Delete
OverBoost Annihilator
6.0 Trans.cooler
Under construction!
I didn't have to buy any pvc it worked perfect just really tight on the filter side... I'll try a link
I have an o3 F350, 6speed. Warranty is up in Feb! I use Rotella synthetic
My biggest complaint with the factory air intake is the 7K miles I get on the filter. Sucking air off the highway is a crock only some idiot in Ford could have devised. Well, the low mileage also..
I have looked at your photos and can only wonder about one thing. The filter sits under the hood in the engine room. What is being done to improve on the fresh air intake? I have thughts, but hate to re-invent the wheel.
Pulling a loaded bobcat trailer or sod grossing about 20K pounds, I still get 13-14 mpg. Empty about 15-16. It likes # 2 diesel a lot better than winter mix.
I am about to drop the muffler, the last thing I want to do is spend a bunch of $$ on a chip. Power is not a problem. My goal is to improve mileage. Open to suggestions.
John
The "HOT AIR" under the hood is not an issue. I believe it was SmokeyWren, (maybe someone else as highly respected on here, can't remember) who did some tests on under hood temps, sitting they were slightly higher, however while moving, much less. ALSO our intakes go through the turbo, (Air gets super heated, while compressed anyway.) then through the CAC, (Charge air cooler) and cooled back down. It is NOT a 1:1 ratio of temp in and temp out, (40* hotter air in, is something like only 3* warmer going into the heads.)
There was a link with all the math from some very hard working people on here! (explaining all the science behind compressed air...)
Get yourself a 6637 NAPA filter, 5 inches of 4" diameter exhaust pipe (from any exhaust shop or parts house, straight for late models and 45 degree for early models) and a couple of clamps and your done. Stay with the steel. Plastic is thicker and restricts the flow of air more than steel. Also do Guzzle's mod if you want the filter minder on it. Welcome to guzzle's 6637 Filter Restriction Sensor Web Page
2011 F250 Super Duty Lariat 4x4
Pro Comp Dual steering stabilizers
SuperGlide 5th Wheel Hitch
AirRide Helpers (I tow 14k)
REBORN 20 Over on 3/2/11- Pics in Gallary- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, ARI TC, JW VB, Walbro 392, TC Lock, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straigt piped and guages, 6637, 203T, coolant filter, 4" Lift on 33's.
I the forums could use a DIY sticky (kinda have one now but its incomplete)at the top that way threads like this are easily addressed in one thread...they seem to work well on other forums I belong too.
Just my $0.02,
Micah
'00 F250 7.3L, 4x4, 6-spd, SCT X3, ATTA 90 gallon tank/toolbox, Air Lift Loadlifter 5000 kit. WVO kit in the making...now if I could just finish getting the CANbus code written for that HE431VE.
'96 Impreza "WRX" coupe time attack car
I tried the pvc route first, needed more air as the vacume indicator showed on wo pulls
so I added another filter & i went with a 4" y dust collecter pipe , I had in my shop...(cleaned it first)
