DIY Tymar Air filter system - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-11-2008, 10:48 PM   #16 (permalink)
2002 Install
Originally Posted by parkerx View Post
Get yourself a 6637 NAPA filter, 5 inches of 4" diameter exhaust pipe (from any exhaust shop or parts house, straight for late models and 45 degree for early models) and a couple of clamps and your done. Stay with the steel. Plastic is thicker and restricts the flow of air more than steel. Also do Guzzle's mod if you want the filter minder on it. Welcome to guzzle's 6637 Filter Restriction Sensor Web Page
On the 02' did you use straight pipe or a 45?
dtcjem is offline
Old 02-11-2008, 11:42 PM   #17 (permalink)
usually a 45 but some get away with a traight as the oem has some flex.
.. imagine a big coffee can on the end of your stock pipe that might help line it up.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
Old 02-11-2008, 11:51 PM   #18 (permalink)
TNDEERHUNTER's Avatar
Southmike what type of filters is those and how much a piece for them.
TNDEERHUNTER is offline
Old 02-12-2008, 03:01 PM   #19 (permalink)
first let me say ..are my the filters a cheap pile o junk ,
that i am not sure yet, they look good to me ,
and the pipe stays clean, so for now they are good.
but they are new and I never really heard of the brand .
my filter parts from the turbo map sensor out are"
heavy duty dual 4" rubber hose clamp from Lowe's. 5$ ( one with the smooth metal plate in between not the corrugated one)
I cut my original rubber pipe in half..slightly more actually, I stuck it on the oem spot a good 2" and clamped down tight
fitting is a delta 4" dust collector y pipe 6.00
pep boys specter filters $30~40 something like 36 i believe
each w/10 year 100k warranty washable then oil etc...
they come with their own clamps .
..I tossed the inside reducers out presumably they are for imports with 3" pipes fitting wise they are tight
now there is less then a 1/2" of space by the IC pipe, battery etc..
I cut my stock battery box down a little, but my early 99 has a fender sleeve so I left it there to help w airflow.
so total cost prob $80 ish, originally it was $45, see below.......
Here is the deal on why i did them
...my check engine light came on and went out
nothing on the codes my stock filter was a lil dirty so I cleaned it off..
POS tabs broke so I needed anew filter asap...so i went to napa and they quoted me 60 bucks for the reg tymar..with my apparently worthless AAA discount . I thought for a filter that gets dirty and thrown out...ha
I laughed at the guy and left.
So on the way home I stopped by boys and bought their filter.
and a 3" pvc 45' elbow from lowes total cost about $45 . I thought that was it , until I installed my air-minder in the elbow.
..at wide open throttle it would suck the yellow all the way down
...so I bought another filter , and stole the pipe off my dust collector in my shop cause nothing else fit easily
...filter minder doesn't budge now. I have two serviceable -filters that look way better to me ,
then that shop vac lookn, canaster napa jobbie .
work in progress
Old 02-12-2008, 04:28 PM   #20 (permalink)
It difinately looks alot better than the big Napa filter. I like the idea. Do you notice any performance difference. I might try to do this mod instead of the big whit napa job.
Old 02-12-2008, 04:52 PM   #21 (permalink)
Also how did you get your'e IC pipe so clean I took the aluminum wrap off the other day and can't get all the insulation off it.
Old 02-12-2008, 09:21 PM   #22 (permalink)
that was the easy part...early 99's did not have the wrap
performance wise it seems to flow better at high end..
well so far the big woosh sound you get when you let off really quick is much louder...
you can hear the wicked wheel some what slightly better,
though light cruising sounds more like a quiet high pitched radio buzz.
i don't have any real gauges yet to say any other diffs, yeah yeah lame I know ..
I keep changing my plans....that and lack of funds.
one part i didn't mention is the filter minder is almost imposible to get out of the oem housing ,
i should have cracked the housing to get it out since it was broken anyhow.
work in progress
Old 02-12-2008, 09:26 PM   #23 (permalink)
ron68coug's Avatar
My Photos: (5)
I don't about all this pvc stuff. I guess its functional. I just couldn't do it.
01 F-350 CC DRW 4x4, bright red, 7.3 stock, 44k miles, leather heated seats , alum. headache rack, new Toyo M/T 315/75R16's x 6, 6" Superlift lift kit, Pro Comp traction bars, bilstein shocks, Fred Goeske 2" pilot hub wheel spacers, Viair 480C compressor, and Nathan train horns.
ron68coug is offline
Old 02-12-2008, 11:09 PM   #24 (permalink)
NorCalDiesel's Avatar
Go to a reputable automotive paint supply store and buy a can of 3M Adhesive Remover. It is sometimes sold as Automotive Wood Trim Adhesive remover, Take your IC pipe off and use the adhesive remover and elbow grease. Mine came off completely and it left a uniform aluminum finish. If you want it shinier use Flitz or NevrDull.
With all the negative feedback on the K&N Clean and Oil elements, make sure that those filters on that dual tymar--ish system perform as required.
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
Super Heavy Duty / Triple Disc 4R100 built by Jim Galatioto at ATO Transmissions in Sacramento.
NorCalDiesel is offline
Old 02-13-2008, 09:51 AM   #25 (permalink)
the delta dust collector is abs, plastic i actually used black abs,( looks like pvc) the first time...
even the great afe2 and the ais ...are plastic.
I agree with you though, the intake I used used to like looks wise was the AEM chrome pipe.
hard to find and expensive for the 7.3. Itp sells an expensive but nice custom pipe for an afe2 to h2e turbo.
work in progress
Old 02-13-2008, 10:08 AM   #26 (permalink)
i can get the napa filters for about 48$ but i order them from a different parts store. i have gotten 50k miles out of one filter before with out a decrease in performance and not a spec of dirt in the intake pipe.
2001 F350 SuperCrew Long Bed Dually.
7.3L turbo Diesel, automatic transmission, goose neck hitch, fifth wheel hitch, stainless steel back rack, 315/75-16 BFG A/T's, AUX back up lights, euro-lite driving lights, upgraded fog lights, dp-tuner, turbo master wastegate controler, dieselsite boost relief valve brv+, auto-meter ultra-lites, 5in stacks no muffler, whelen towmans light bar, DIY tymar intake, DIY coolant filter, 2M ham rig, DIY AIC,
( egauges )
My truck pic's
cdacaraudio is offline
Old 02-13-2008, 10:56 AM   #27 (permalink)
50 k isn't bad
though. .... Rhode island doesn't have any dust.
It is not big enough.....
work in progress
Old 02-13-2008, 01:27 PM   #28 (permalink)
well that's with towing a 10k trailer to and from MA to CONN/NY line 12 or so times a year and hauling landscaping equipment 1 or 2 times a week. also i travel to NH about 5 or 6 times a year 2 of them being in the winter when there is lots of sand/salt around. i put around 25-28k miles a year on the truck. funny part about hauling for people is i move a lot of trucks for people at least 1 or 2 a month and 90% of them are Chevy's go figure
( egauges )
My truck pic's
Old 02-13-2008, 03:38 PM   #29 (permalink)
my3wags's Avatar
I get about the same out of mine (50K). You could stretch it a bit more with a dry wrap. here is mine.
Big E and family of Three
2002 F250 4X4 CREW CAB PSD 4" LIFT
4" turbo back exhaust*custom tymar*DP tunes*Polished ATS housing*6.0 intercooler*Chromed intercooler pipes*DC Power Inc. 190 amp
Alternator*Dieselsite boots*203 thermostat*40K Trucool*tugger kit*tripple TC*Manual TC lock-up*EBPV brake*AIH delete*boost Annihilator*Custom CCV*ITP/KCM (HPX)*Coolant filter*08 diff cover*DI fuel shim kit .055 @68 psi*engine mounted fuel gauge*custom engine cover*triple gauge*((XM))
2004 Keystone Sprinter 297fwbhs 5th wheel
with most of the goodies
my3wags is offline
Old 02-13-2008, 08:19 PM   #30 (permalink)
aaggieh08's Avatar
this might be a stupid question but are the tymar filters reuseable and where did you get that dry wrap, all of the ones ive found are too small.
aaggieh08 is offline
