Do I need to reset computer? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 12-17-2007, 09:48 PM   #1 (permalink)
lemans454's Avatar
When I do mods such as zoodad or anything for that matter do I have to disconnect battery to reset or what?
2002 F350 4X4 Short Box, Ext.Cab Welding Rig
Side exit Flowmaster, Red/Silver, Hankook DynaPro MTs, Foil Delete, Zoodad.
lemans454 is offline
Old 12-17-2007, 09:52 PM   #2 (permalink)
Re: Do I need to reset computer?
no....
2000 F350 CC SB SRW 4x2 7.3L
Work in progress...
DP Tuner 4 position chip Stock, 80e, 100p, 140e, 4" magnaflow turbo back, afe stage 2, 4R100 with shift kit/heavy duty clutches
and more to come...
Items waiting to be installed: BDP Stage III Hybrids, Beans Modded H2E
Future mods: BTS trans, fuel system, studs, PULSE HPOP
matthewd11 is offline
Old 12-17-2007, 09:54 PM   #3 (permalink)
lemans454's Avatar
A little off topic but if my mileage isn't as good as I thinkit should would it be beneficial to reset my computer?
Old 12-17-2007, 09:57 PM   #4 (permalink)
wouldnt hurt. Just disc the batteries for a bit.
Work in progress...
and more to come...
Old 12-17-2007, 10:22 PM   #5 (permalink)
why would you disconnect for a zoodad? its not like there is a mass airflow sensor to get confused or anything from the extra air from the hole that you cut in the grill support
1999.5 (5/99) F-350 SC, LB, ZF-6, 4X4: ATS Compressor Housing, BBH, K&N FIPK & Drycharger, DP Tunes 60T, Isspro Pyro & Boost, 4" MBRP & Delete Pipe, AD's (for now) ITP HPX, OBA & Reg Return, AIH Delete, Oil Guard, Couple Dongles
Oil Pan @ 133,000
PSN rocks my world [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
ITowBoats is offline
Old 12-17-2007, 10:26 PM   #6 (permalink)
JimTJr's Avatar
My Photos: (20)
I think he was just using it as an example. And really I doubt "Resetting" the PCM would help mileage any either. If your mileage is suffering some now, join the crowd. It will always drop considerably, (10% or so I bet) during the winter. (Winter blend fuel is not as efficent as summer blend I guess)
IIRC our PCM won't clear codes just from removing power. You need a good scanner, or one of the tuners that will read, and clear codes.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 12-17-2007, 10:30 PM   #7 (permalink)
codes are stored in the KAM i believe, if you remove power from them, you will lose that info, and reset all its parameters and will have to "relearn" those parameters..
Work in progress...
and more to come...
Old 12-17-2007, 11:07 PM   #8 (permalink)
oh god here goes the "learning" ability debate of the PCM again............
Oil Pan @ 133,000
Old 12-18-2007, 01:46 AM   #9 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: EMD_16_645_E5</div><div class="ubbcode-body">oh god here goes the "learning" ability debate of the PCM again............</div></div> [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 12-18-2007, 08:44 AM   #10 (permalink)
Mark Kovalsky's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: matthewd11</div><div class="ubbcode-body">wouldnt hurt. Just disc the batteries for a bit. </div></div>
Running two laps around the truck won't hurt it, either. It also will help the truck just as much as "resetting" the computer.
THE COMPUTER IN THE 7.3L DOES NOT LEARN. THE ENGINE PORTION DOES NOT LEARN AND THE TRANS PORTION DOES NOT LEARN.
"Resetting" the computer does give you a good chance to clean the battery cables and posts, so maybe it is a good thing.
Mark
Mark Kovalsky is offline
Old 12-18-2007, 08:46 AM   #11 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JimTJr</div><div class="ubbcode-body">(Winter blend fuel is not as efficent as summer blend I guess)</div></div>
Winter blend fuel does not have as many BTUs per gallon as summer blend, so to get the same amount of energy the engine has to burn more fuel. It's as simple as that.
Mark
Old 12-18-2007, 09:46 AM   #12 (permalink)
I have always figured that the poor milage in the winter months, had more to do with a number of things, extended warm ups(idling) longer time to peak engine efficiency, EBPV ,& EOT ...
Less BTU makes sense due to longer cold EOT ....(shrug)....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 12-18-2007, 10:26 AM   #13 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: action4478</div><div class="ubbcode-body">Less BTU makes sense due to longer cold EOT ....(shrug).... </div></div>
What's that mean? Lower BTU content means the amount of energy available by burning the fuel is less than summer blend. Since you get less energy per gallon, you must burn more gallons to go the same distance.
How is cold EOT related?
Mark
Old 12-18-2007, 11:17 AM   #14 (permalink)
Oilfield_Digger's Avatar
If you add some cetane booster to the fuel it brings it back to Summer quality.. And you will get better milage cause the air is cooler and more dense in the winter..
03 F-350 Lariat CC 4x4 LB
TN BB Turbo, AFE II w/ Progaurd 7, Quad Pod, Home made CCV.
Oilfield_Digger is offline
Old 12-18-2007, 11:37 AM   #15 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Oilfield_Digger</div><div class="ubbcode-body">If you add some cetane booster to the fuel it brings it back to Summer quality.. And you will get better milage cause the air is cooler and more dense in the winter.. </div></div>The cetane will accelerate the combustion of the fuel. While this makes it easier to start when cold soaked, it does NOTHING significant to increase the BTUs per gallon of winter blend fuel.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
