Does hi-flow outlet need non-EBV pedestal? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-08-2007, 06:46 PM   #1 (permalink)
ELLIOT02's Avatar
I have received my TN turbo from BWD and am waiting for the high flow outlet.Do I need to install a non-EBV pedestal?I would like to know ASAP since I am installing turbo Monday and need time to have pedestal shipped if necessary.Thanks in advance!
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. BTS tranny with 6.0 cooler,coated TN bb1.00 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P Tuner.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,PML pan,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods. Hawks and Powerslot cryo's
ELLIOT02 is offline
Old 02-08-2007, 06:59 PM   #2 (permalink)
ELLIOT02's Avatar
Re: Does hi-flow outlet need non-EBV pedestal?
Nevermind.I ordered a non EBV pedestal from Dieselsite.Bunting recommended it and I'm already this deep in. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
ELLIOT02 is offline
Old 02-08-2007, 09:41 PM   #3 (permalink)
Send a message via Yahoo to mlohaus Send a message via Skype™ to mlohaus
I like Bob's stuff but the Ford Remans are pricy plus there's a core. There are cheaper options out there. I'll let Brian know.
01 F350 CC SB 4X4
Slightly Modified
Powered by Oil driven my Madness
577 HP 951 Trk
mlohaus is offline
Old 02-08-2007, 10:26 PM   #4 (permalink)
If you want to sell your old one, send me a PM.
444-4D is offline
Old 06-25-2009, 06:57 PM   #5 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Anybody knows how much labor hours is involved in doing a ATS housing and the non ebv outlet+pedestal? my mechanic charges $80 p/ hour. Thanks guys!
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 06-26-2009, 04:27 PM   #6 (permalink)
If you are installing a higher flowing outlet (1.0 or 1.15 ar) you do not have to do the ebpv delete pedistal allthough there will probably be some flow efficiency gain by doing so. Many keep their EBPV and use it in conjunction with a TC lockup switch to make an exhaust brake.
If you are not towing heavy in mountain passes and want to maximize performance, go for it. You might want to hang on to your pedistal in case you later change your mind. The ebpv pedistals are about 3x the cost of the non-ebpv pedistals.
The hard part of the pedistal change from what I have heard (I have not done it) is the up pipe connections. My guess would be between 4 to 6 hours. Not sure about changing the turbo outlet but the Ported shroud intake is easy and will not really add to the time. Let me know how you like the upgrades as I was also thinking of doing the pedistal change when I do the ported shroud and turbo wheel replacement.
Work rig - 2000 F250 7.3 4x4 3.73 auto, 285/75 Michelin ATX, hpx, zoodad, hutch mod, 4" mbrp, 6637, isspro 3 pod, Trucool, ATS ported shroud (someday).
Farm rig - 85 6.9 xl t18 4x4 3.73ls, 88k orig miles, zig-style ram air, electric fuel pump, soup bowl delete, manual 12v glow plugs, Battery isolators, KISS principle generously applied.
Njellison is offline
Old 06-26-2009, 07:47 PM   #7 (permalink)
My Photos: (23)
Sure will let you know, I will soon receive the housing,cfm+ intake(red botton/grey inlet),pedestal and hi-flow outlet. I am ready to pay around 450 for labor for everything, but could be more....I am thinking of having it dyno before and after, for some real numbers of before and after gains, or if it all was waste of money. It should be a good post for many here thinking of the same.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 06-26-2009, 08:52 PM   #8 (permalink)
That would be great, Keep us posted.
Old 07-02-2009, 05:02 PM   #9 (permalink)
My Photos: (23)
OK, back at this again. Do we really need the pedestal changed to non-ebv, I mean do we REAAAAAAALLY.....if nothing will blow up or give me issues down the road than I might not do it. I have it, but I want to save on the labor and all.
I had the CFM+ inlet installed today and deleted the heater, it seems to help, really, and I also cut that plastic that is in front of the airfilter tube, I believe you guys named it "Zoodad". But what really helped was removing the vaccum tube from the waste gate actuator. That things was probably bad because I NEVER got the psi boost that I am getting now, not even close!
So, next will be the ATS and maybe the non-ebv outlet and pedestal, I am also trying to buy a IC from a 6.0.......we'll see.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-02-2009, 05:58 PM   #10 (permalink)
CFM + looks cool, of course now you have to do the foil delete and paint your IC tubes to match. Glad to hear the performance improved.
I don't think the pedistal change out really does that much for performance, but improved air flow is the name of the game and it will contribute more than most minor mods. Some people also choose to delete it as they hate the sound of it when it is running or they have oil leaks all over the top of the engine from the worn oil rings at the valve. I guess the time to make that call is when you have the turbo off anyway.
What did you mechanic charge for the CFM install or did you do it yourself?
ps: Careful with the wastegate tube delete, lifting the heads off the block from too much boost would be a bummer this summer.
Old 07-02-2009, 06:14 PM   #11 (permalink)
My Photos: (23)
Talking
Yep, it would be a bummer, I am not stomping it at all, I am not the type to be getting on it and every light, I gradually increase boost and I did see it around 20 psi after all the mods installed today, before I would be lucky to even see 12-15.
He charged me 75 bucks to do the CFM+ and the Zoodad, but I am a 18+ year customer too.
But even being a regular, it could not cost more than 85-90, because it was pretty simple. I did need to clean or better "dust" my engine compartment too.
I like the CFM, the red piece is so light compared to the original one, and after analyzing the original, I can see why it is better to separate the tubes, also the inside of the original is pretty rough, CFM is smooth.
I have the turbo master actuator so I will take it easy until I get my ATS housing and then I will have a safer way to boost it up to 20+ psi.
deleting the heater was also a good thing, that thing sticks out so much and it create a lot of air turbulence on that side of the engine I suppose and I'm in Miami !!
On the hwy it was cruising really nice and it would spool nice and easy, I was singing all the way home, or was it my turbo.......
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-02-2009, 06:18 PM   #12 (permalink)
My Photos: (23)
BTW, the foil delete will have to wait, because from what hear around here, with the WW and the ATS, that thing screams......so I will wait because I don't want to over do it, I did put two Magnaflow mufflers after one was still "loud"...lololol.....so you can see that I am not into too much noise....but I will try to buy one w/o and leave mine alone, so that way I can swap it depending on my mood.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-02-2009, 06:39 PM   #13 (permalink)
Sweeeet!
Good call.
I have thought about that one as well. Since I am in Western WA I do need some pre-heat aspect in winter and if I do the pedistal delete I will be leaving the AIH operational. On the other hand it is cheaper and easier to do the AIH.
Decisions, decisions.
Old 07-02-2009, 09:53 PM   #14 (permalink)
My Photos: (23)
About the warming up in cold weather, where you live you should maybe keep some form of heating element and get a 203 thermostat. I am not sure which one would be better to keep in cold weather, the ebv or the intake heater, most likely the ebv is the one to get rid of. If you think of the lower egt's alone it makes it worth it. The other one is not that bad, I mean it is not a valve that blocks air, but just a probe that heats up the air.
In South Florida not really necessary.
I know that I will not be going north in the winter anyways, not with my tires and in a 4x2.
It is cheaper to do the AIH now(money wise), but "cheaper" to do the EBV because your lower EGT temp and better exhaust flow will save you a lot of $$$ down the road.
In fuel and in parts, specially if you plan on towing.
How's your Trucool? I wanna lower my tranny temp and was looking at it on dieselsite.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-03-2009, 01:27 AM   #15 (permalink)
westvandude's Avatar
Put that boost tube back on the wastegate.... your hwy fuel economy will go to crap.
Yes, it builds more boost but that extra boost is wasted energy because it had enough stock boost to not smoke out the tailpipe. Watching the boost psi gauge is fun but ideally there is a balance between too low and too much boost for the fuel you have to burn to remain efficient.
Anyhow, you should be seeing 15-17psi stock. If less than that you've probably got leaks from your intercooler boots (also check the engine valley boots). I got new dieselsite boots because my boots looked real greasy... probably were cheese-cloth for letting boost escape.
140hp tune can run up past 25psi. That's the "old wives tail" mechanical psi limit for the OE turbo if you want it to last. Surge at that psi will kill it. Housing is best solution or if you're rich a GTP38R.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
