dome/courtesy light overide switch
I want to add the dome/courtesy light overide switch on my 2003 Excursion 7.3. I followed a thread on the excursion forum for a 2001. When I got under the fuse box nothing looked the same. When I looked closer at the pictures in the right up my fuse box for a 2003 was totally different looking than the 2001. Does anybody know if the 2003 7.3 pickups have the same fuse box as the excursion. I am looking for any wiring info anybody has for the courtesy lights. What color code they are and the location coing out of the fuse box etc. I paid for a diagram on the net and it sucked. It says they are black with bluse stripe (same as 2001) and its right by gas pedal. No such thing by gas pedal. My owners manual does not even tell you what fuse or relay controls this feature. Any help much appreciated.
AJ
