Donaldson Air Intake system - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 12-06-2006, 08:33 AM Thread Starter
My brother has the early 1999 F350 Superduty with the Donaldson Air Filter upgrade that you can buy from Ford. I know that this is probably the best filter for the truck and I have told him that but he was wanting to know if there is any type of filters that will fit into this air kit from another manufacturer for a little better performance (more airflow). I think the Donaldson is the best for filtration but restricts some of the airflow. Please let me know what you have experienced.
I have a 6.0 Liter so I am usually on the other part of the forums so I don't know if this has been discussed before or not.
2006 F350 Lariat Dually Crew Cab 6.0 Liter 4.10 gears, SCT Excalibrator 2 with tunes from Innovative Diesel--these guys are awesome to deal with. AFE Stage 2 enclosed air intake with new part to fit the 2006 model trucks. SIRIUS SAT RADIO, Garmin 2610 GPS, Cage off road leveling kit, 5100 Bilstein Shocks, B&W gooseneck hitch, LINEX bedliner, CAMLOCKER toolbox, MBRP SINGLE 4" EXHAUST.
powerstroke6lite is offline
post #2 of 15 (permalink) Old 12-06-2006, 09:06 AM
haul_n_horses2's Avatar
My Photos: (17)
Re: Donaldson Air Intake system
The only filters available for that box are Motorcraft and Donaldson. The Donaldson (white version) holds less dirt and does not filter as well as the Motorcraft (blue). I do not know if that translates to increased flow or not. The snorkel on this box restricts airflow more than the filter. Check that the rubber dam near the radiators does not partially obstruct the inlet to the snorkel. Other options:
1. Consider performing a Zoodad mod to allow direct airflow from the grill to the snorkel inlet.
2. Consider cutting a hole in the side of the box to allow the use of a fender sleeve.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
post #3 of 15 (permalink) Old 12-06-2006, 09:29 AM
Send a message via Yahoo to mlohaus Send a message via Skype™ to mlohaus
Amsoil sells the filters also. They also sell the kit. Powerstrokeshop typically has the best prices on those filters. Something like 70 plus shipping.
01 F350 CC SB 4X4
Slightly Modified
Powered by Oil driven my Madness
577 HP 951 Trk
mlohaus is offline
post #4 of 15 (permalink) Old 12-06-2006, 02:28 PM
NCHornet's Avatar
Use the Ford filter and do the Zoodad mod, if you really need more air do the fender sleeve mod.
Which filter does powerstrokeshop sell with their kit? If I remember it was the white filter and this is the first time I have heard about the blue unit filtering better. Where do you get the facts for this statement?
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #5 of 15 (permalink) Old 12-06-2006, 02:36 PM
NChornet, when the Ford severe duty AIS came out in 2003, we had an engineer at Ford or Donaldson post and note, in convincing detail, the filtration differences between the white and blue. I think I got mine then from powerstrokeshop with the blue, and replaced it early this year [after nearly 50k miles] with another blue from them. Sorry, can't point to the posts; maybe haul_n_horses2 will chime in with a link to that now-ancient history ...
2002 F350 Supercab Lariat 4x4 7.3L 6 spd. B&W gooseneck, Prodigy brake controller, PAC exhaust brake, WARN manual hubs, Ford AIS, Bilsteins, Michelin LTX, Line-X bedliner, 203F t-stat, Cat ELC coolant, by-pass coolant filter.
Wife's Ride: 2006 Mercedes Benz E320 CDI
Riggodeaux is offline
post #6 of 15 (permalink) Old 12-06-2006, 02:41 PM
My Photos: (17)
[/ QUOTE ]The kit comes with a blue Motorcraft filter. They sell both filters and the Motorcraft (blue) is about $10 more expensive. The statement about the filtering ability and capacity of the two filters comes from JFlagstad:
Hello Folks,
Jordan here again from Donaldson. I think that some of you are trying to make an "Apples to Apples" comparison of these 2 filters, and that is not possible.
The filters are made using 2 different medias. Going from the blue media to the white media, you will sacrifice dust efficiency and filter capacity. I guess you need to ask yourself if you want to change the filter more often, sacrifice efficiency and save a few bucks? Or, change lest often, sacrifice nothing, and get the utmost protection for the vehicle you paid a lot of money for?
I guess it all goes back to a lesson we learn over and over again as consumers, and that is we get what we pay for.
Thanks Guys,
Jordan Flagstad
Senior Automotive Engineer
Donaldson Company
post #7 of 15 (permalink) Old 12-06-2006, 04:03 PM Thread Starter
I think I will just tell him that he needs to get a new intake system if he wants more airflow. I think the best aftermarket kit out there is the AFE with the proguard 7. What do you suggest if he decides to go this route.
Thanks for the responses....Also, what exactly is a zoodad mod. I think I know but just to make sure. We cut some of the rubber material at the grill when we installed the kit to let air go directly into the inlet.
post #8 of 15 (permalink) Old 12-06-2006, 05:35 PM
Cool_Canuck's Avatar
My Photos: (12)
Trim the snorkle and you'll get all the clean cool air you need.
The Zoodad Mod is cutting out the fiber plate at the side of the rad to allowing ram air to enter snorkle.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/
; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED;
Cool_Canuck is offline
post #9 of 15 (permalink) Old 12-08-2006, 06:53 AM
NCHornet's Avatar
Hello Folks,
Thanks Guys,
Jordan Flagstad
Donaldson Company
So a employee of Donaldson is telling us the Ford filter is a better filter and we are waisting our money on the Donaldson?? Interesting, I wonder if this guy still works for Donaldson?
Thanks for the info. I have been on here awhile now and don't remember hearing this before.
NCH
NCHornet is offline
post #10 of 15 (permalink) Old 12-08-2006, 07:01 AM
Powerstrokeshop.com has the Motorcraft FA1757 element for the AIS for $57.57 right now...
1999 F-350 - CC/LB, gauges, 40K trans-cooler & external filtration & drain, 203 t-stat mod, Mag-Tech Trans & Diff. cover, AIS filtration, zoodad, HPO x-over, Jody Tipton 40HP tow PCM, Hutch mod and harpooned, Baldwin prepump fuel filter
"Better to be judged by 12, than carried by six!"
nlemerise is offline
post #11 of 15 (permalink) Old 12-08-2006, 08:29 AM
Raymondb's Avatar
When did it go on sale?
I just ordered that yesterday and it was $70.81 - is there a promo code or something that I missed?
prt
'99 F250 7.3L SC SB
Powered by
No more cupthrowers!!!
Next - ITP fuel system and Stage 1's
Raymondb is offline
post #12 of 15 (permalink) Old 12-08-2006, 12:26 PM
NCHornet's Avatar
That's a good price!!
NCH
NCHornet is offline
post #13 of 15 (permalink) Old 12-08-2006, 01:31 PM
Raymondb's Avatar
Yeah, but I'd sure not complain if I could've gotten it for $57 & change!
Would you?
prt
'99 F250 7.3L SC SB
Powered by
Raymondb is offline
post #14 of 15 (permalink) Old 12-08-2006, 07:56 PM
Whether you buy a blue motorcraft filter, or a white donaldson one, donaldson makes money; they manufacture both of them. Maybe they make a little more margin on their own branded one, but that's probably minor.
Andy
2002 F250 XLT PSD Auto CC SB 2WD. Owned since new.
265/75R16E Bridgestone Dueler AT Revos
Ford AIS Intake w/ Motorcraft Element
Optima 34/78 Red Top Batteries
Fleetguard LF9027 Venturi Oil Filter
22" Wiper Blades
BigJakeJ1s is offline
post #15 of 15 (permalink) Old 12-08-2006, 08:39 PM
ptanner3's Avatar
i'm trying to decide whether to spend $400+ on stage 2 afe or whether to go to an s&b or volant, which look interesting, and cheaper too. right now i have stock. is any intake i choose better than the plain stock one i'm running now, which is not ford ais? or save my pennies and buy the stage 2 in a couple months?
'02 f-250 cc srw 4x4, auto, 4" exhaust, pillar pod w/ post and pre turbo egt, trans temp and boost, black brushguard/bumper, chrome step tubes. bully dog trans kit, ts performance 6-pos chip, stock, high idle, 50, 75, 100, 140, volant air intake
'08 f-350 cc drw 4x4, auto, mini max, 5" downpipe back exhaust. black ranchhand bullbar bumper, S&B intake.
both trucks bought in texas.
ptanner3 is offline
