DP Tuner with Drive Thru - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-20-2009, 06:06 PM   #1 (permalink)
seelow's Avatar
I was looking to get a DP tuner for my 2002 7.3 and was interested in the drive thru setting. I was just curious as to how it works and if you can drive a slow speed with it on? thanks
seelow is offline
Old 01-20-2009, 06:44 PM   #2 (permalink)
I have it, and don't like it. Yes, quieter, but you can only leave it there for 10 or 20 seconds before it starts smoking and smelling real funky. No way can you drive the truck with it.
2003 F-250 7.3
4x2 Crew Cab SB
Garrett Ball Bearing Turbo
40HP injectors
D-P Tuner F5 chip
Ford AIS, with foam shroud and side intake
4" MBRP T-409 Exhaust Turbo back
Vegetable Oil Conversion
1997 F-250 7.3
4x2 Super Cab
D-P Tuner "econo tune" PCM
over 340k miles and countin'
PreservedSwine is offline
Old 01-21-2009, 05:15 PM   #3 (permalink)
KMT
I have it and I LIKE it! I only use it when placing my order; then I turn it off and drive up to the window. It works great. No, you can not drive around with it on.
The very first time I used it was at Wendy's. When I pulled up to the Pay Window, the Girl said, "Wow, I can't believe that I could hear you over that diesel engine". I replied, "Yeah, I have a way to make it quiet."
I use it all the time. I do not have to kill the motor anymore when placing an order. Other people in the Truck think its cool also.
2002, F350, PSD, Lariet, Crew Cab, 4x4, 4 inch SuperLift, Bilstein Shocks, 18x10 Eagle Alloys, Nitto 325/65R/18 Terra Grapplers, TruSpeed, 3.73's, Limited Slip, Manual Hubs, Spray In Liner, A.R.E Topper, ITP Regulated Fuel Return, ITP Over Boost Annihilator, ITP HPX, Banks 4" Exhaust, Banks Big Head Actuator, Garrett GTP38R Turbo, Ford AIS, DieselSite Engine Boots and Intercooler Boots, AMP Research Power Steps, DP Tuner with Gauge Mount Switch (Stock, Lope, Drive-Thru, 40T, 60T, 80T, 80E, 120R), BTS Valve Body, Mobil 1 ATF.
KMT is offline
Old 01-22-2009, 01:45 AM   #4 (permalink)
dtsthx's Avatar
i to like it and i leave mine on from the start to the finish of drive thru and when i wont to drive thru camp grounds quiet
i have not towed with it on
but i have drove in the neighborhood and it quiet but not at all powerful
2001 F-350 larait c.c. s.b. 4x4 auto, keenwoodkvt915 in dash dvd 7inch screen ,1 alpine Rtype 12 woofer 1500 watts,pheniox gold mono block class d amp, scorpion BOX, level kit,mr taillight foglight highbeam kit, stock ford 18's on contie's, rancho 9000ES shocks ,6.0 transcooler, derale trans pan ,ccvdiy mod ,zoo dad , powerstrokehelp.com FUEL mods , hood insulation delete ,foil delete , high presure oil x pipe, DP tuner F-6 = 900rpmEBV, drive-thru tune ,EBV Engine brake tune,40tow ,60 econo, 80econo , supersmoke (use with OD) , 100hp, 120race 140agrresive, 3 pilier pod , pyrometer, 2trans temps inside tranny/outside ,boost,diy cold air6637 & 45 degree 4 inch alum.8"x8" , JEG'S 4" downpipe to 5" exhaust flopro 6"tip , dfuserA.I.H.plug, Extreme diesel Xwheel , (commin soon banks technicooler )
dtsthx is offline
Old 01-22-2009, 11:49 AM   #5 (permalink)
rednck21's Avatar
i thought about getting it when i got my F5, but didnt have the coin for it. still dont, but ill have it when funds allow
2000 F-250, reg. cab, 4x4, XLT, 7.3, 4R100, built 6/00-forged rods!, DP Tuner F5, AFE stg. 2 w/PG7, MBRP 4", Autometer Ultralight boost/pyro/trans temp gauges, 285 BFG's
2002 F-150, reg. cab, 4x4, XLT, 4.6 auto, daily driver
ECBR
PICS
WEBSHOTS
rednck21 is offline
Old 01-22-2009, 12:56 PM   #6 (permalink)
They must have made some changes between your "drive thru" tune and what they're selling now.
Driving with it is out of the question. Contemplating towing with it defies reality. And leaving it on from start to finish at the drive through would get you arrested for the copious amounts of funky smelling smoke you're flooding everyone behind you with.
I'd like to hear more people that have it. Maybe mine is the odd duck. I've had the drive thru setting for about a month.
2003 F-250 7.3
4x2 Crew Cab SB
40HP injectors
D-P Tuner F5 chip
1997 F-250 7.3
4x2 Super Cab
Old 01-23-2009, 06:30 PM   #7 (permalink)
Justin C.'s Avatar
I have it, and it doesn't really work. It idles my truck down some, but doesn't quieten it up that much. CSIPSD I think had a video of his truck with it and it worked great, huge difference. I have no idea why mine doesn't work that well though. I turned my chip to it one time by accident while driving and the truck drove fine, just sounded funny and was weak.
Justin
Justin
1997 F-250 Power Stroke
- 230k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
2005 F-350 Power Stroke (work truck) - 220k
ARP Studs, PHP 40 hp flash
Justin C. is offline
Old 01-23-2009, 10:52 PM   #8 (permalink)
dtsthx's Avatar
i think its your injectors !!
jody told me with there truck he has to defuel it alot because of his injectors
i have only had my dp for 4 months
but ya i can drive with it ! no balls at all i think is shuts down a couple of cylinders but it sounds like you have lope idle
i hope i don't have to pay for all new tunes when i get stage 2 injectors????
dtsthx is offline
Old 01-23-2009, 11:17 PM   #9 (permalink)
Justin C.'s Avatar
If you're going from split to single shots you've pretty much got to. Otherwise you don't have to, but you're not getting all you can out of your injectors at all unless you do.
Justin
Justin
- 230k
463 hp - 7-9-09
Old 01-23-2009, 11:32 PM   #10 (permalink)
My Photos: (15)
I believe the price is lower if you have to re-do the tunes compared to new tunes.
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, 9 tunes from DP Tuner including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3 installed by Beans Diesel, BTS tranny
mtnbiktn is offline
