Dumb Question...... What is shift flare ??????? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 08-01-2006, 03:39 PM   #1 (permalink)
remedm's Avatar
Sorry I not a tranny guy [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2002 CC F-350 SB SRW 4X4 TOREADOR RED
DP-TUNER NO-START, MOD STOCK, HIGH IDLE, DRIVE THRU, 40 TOW, DECEL, 60 TOW, 60 ECON, 80 ECON, AND RACE
BTS TRANNY (NUFF SAID) ; 6.0 COOLER
DIESELSITE BOOST RELIEF VALVE, 203^ THERMOSTAT AND HOUSING, MAX A/C VALVE AND COOLANT FILTER
ATS TURBO HOUSING, FORD A.I.S., OILGUARD BY-PASS, 4" MAGNAFLOW STRAIGHT PIPE, SIDE EXIT,
NCHORNET'S CCV MOD, POR-15 OIL PAN
ISSPRO A-PILLAR PYRO/BOOST/TRANS, ISSPRO ENGINE, OIL TEMP AND VOLTS OVER MIRROR
MARINCO MOD, LED ID BAR, HEATED SIGNAL MIRRORS, LED BRAKE AND TURN SIGNAL BULBS FRONT AND REAR
RHINO BED LINER, SIRIUS RADIO ,
AMERICAN EAGLE WHEELS WITH 305-70-16 NITTO TERRA GRAPPLERS WITH A 2" DONAHOE LEVELING KIT
TRUCK BUILD DATE 1/8/02
BTS BUILD DATE 1/8/07 AT 41K
My Truck
remedm is offline   Reply With Quote
Old 08-01-2006, 05:03 PM   #2 (permalink)
Re: Dumb Question...... What is shift flare ???????
Watch your RPMS when shifting from second to third and third to fourth. You will see the shift and then watch the rpms slowly drop until the TC lockup fully occurs. It is about a 3-400 rpm swing. You are still accelerating, but the TC lockup disks are slipping and creating heat, all the while wasting fuel.
DD 2010 Ford Fusion Sport
relegated to garage duty
U.S.N. Paradise BB91904
'99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
ACD2 is offline   Reply With Quote
Old 08-02-2006, 06:49 AM   #3 (permalink)
Shift flare is when the RPM briefly increases on an upshift. RPMs should always decrease on an upshift.
Casey_1 is offline   Reply With Quote
