Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Well it's been awhile since I have posted a question... so here it goes.
I am currently getting ready to do another tour in the desert and figured i would do a little traveling before I take off for the big sand box. My truck performs fairly well double pulling a 5 er with an atv trailer on the back.
What are my options as far as turbo upgrades ? I hear a lot of good things about Beans Dominator 66. From my understanding that is pretty much the only drop in option for the Early 99 ? Would I see a big improvement in performance for the 1450.00 price tag ?
Anyone out there have any experience with the D66? Anyone out there know any other options ? Anyone have an Dominator 66 they would like to sell? I know i am fishing now!!! LOL ! Thanks for your time!
Early 99 F250 XLT, 6 spd, Luk Clutch-Kevlar bushing, 4" MBRP Exhaust, Turbo Master Wastegate Controller, ITP Overboost Annihilator, KCM S.S. HPX Line, DiPricol Optix Gauges, DP Tuner F5 Chip with 60T,80E,100 Perf, Superchips 1805 Flashpaq (used for code reading only), Firestone Airbags, 203 degree t'stat, AIS/w fender sleeve, CCV Mod, Hutch In Tank Mod, Harpoon Mod, 6.0 Intercooler, 315/75/16 on 16X10 Eagle Wheels, Ford 08 and above rear differential cover, Royal Purple Gear lube, 2007 Grille and Headlight Mod.
Great upgrade, esp when used with a custom chip...your SC leaves alot to be desired.
For the price you'd probably see more going to a DP Tuner chip or similar like Caryt above said. You might really want to look into switching out the whole turbo setup to the later 99 and up system and getting a turbo for that setup.
I tried Garret's bal-bearing tubro on my early '99...WASTE OF MONEY! BD uninstalled it soon after. The parameters on the early '99 are different than late '99+. Jody @ DP Tuner has told me he can rewrite the programming and make it comporable or better than later models. You just need to swap out everything that makes it an early '99 (heater plug, manifolds, intake, etc.).
early '99 F-350 LB CC 4x4 w/ '01 7.3
10" lift
38" M/T toyo's
4.56 w/ Detroit locker w/ Mag-Hytec cover
Dynatrac free-spin conversion kit w/ Warn hubs
Lifetime ball-joints
Bushwacker cut-outs
BD 4R100 tranny w/ remote filter & Mag-Hytec pan
Tru-Cool Max cooler
Amsoil dual by-pass oil filtration system w/ pre-luber & Ea filters
Amsoil front to rear
140 gal. aux. tank
Twin Odyssey 65 series 1750 amp batteries
250 amp H.O. alternator
AFE stage II intake
Edge programmer
Big Woof turbo
4" down/5" exhaust
Evans waterless coolant & 0 pressure cooling sys. w/ 203 thermo
coolant by-pass filter
Autometer gauges (tranny, pyro & boost)
Digital outside thermometer good to -100, though I've only gotten it to -84
A.R.T cryo-treated brakes and pads (front & rear)
SS brake lines
Oasis XD4000 compressor
TWIN (2 seperate/2x3=6) train horns
dual-burner HID headlights
HID driving lights
4 Hella HID 8" lights
In-dash Pioneer nav
1,500 watt power inverter
Uniden scanner
blacked-out windows
Turbo hasn't anything to do with the PCM differences...programing isn't going to change the limitations of the early 99 PCM.
A D66 is a great option and a great bang for the buck.
