Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-27-2007, 12:31 AM   #1 (permalink)
EBPV exhaust brake, which one?
OK guys, I am interested in adding an exhaust brake and I have found 3 different brands that do essentially the same thing. SPDiesel, Powerstroker, and Scorpion. It looks like they have quite the pissing match going on between one another. Which one should I go with? I would rather not cut wires. thanks for your help.
2000 250SD, 4x4, auto, supercab, LWB, K&N air & oil, Superchip 1705, airbox, 203T, boost, tranny, and EGT gauges, Bradford Built flatbed, Arrowcraft dually conversion, Rocking R Ranch replacement bumper, tranny cooler, wicked wheel. Upcoming mods: Dahl 100 fuel filter
260,000+ on the clock and still tickin'!!!
"Diesel Smoke Makes Me Horny!!!"
iowacows is offline
Old 01-27-2007, 09:27 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (42)
Re: EBPV exhaust brake, which one?
You left out the BD version of the so-called "electronic" exhaust brake.
If I were buying one today, I'd probably choose either the SP-Diesel with the torque-converter lockup option, or the BD BrakeLoc, also with the torque converter lockup included.
Here's the link to the BD:
http://www.dieselperformance.com/for...oc&tt=ford
Note that the one for the automagic tranny costs $395, but it includes the torque converter lockup stuff. The one for the stick shifters is half that price because it doesn't have to worry about locking up the torque converter.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is offline
Old 01-27-2007, 10:22 AM   #3 (permalink)
I'd be interested in something like this also. Does it add more wear and tear on the engine? Does it make a lot of noise? (I hope it does!) Also, how effective are these if you don't do a whole lot of towing?
Sorry if this is hijacking the thread...I don't think it is though.
Steve
Early 99 7.3 F250 4x4 6-speed 160,000 miles
DIY intake, MBRP 4" single exit, Isspro EGT and boost, DP Tuner 80 econo flash, Carbotech Bobcat front brake pads
Steve91T is offline
Old 01-27-2007, 12:17 PM   #4 (permalink)
no extra wear and tear, no excessive noise. We offer a 30 day test drive on ours by the way.
Email us with additional questions.
Proud to be a sponsor of thedieselstop.com
Test Fleet
2001 F350 Crew Cab 7.3L
2004 F250 Crew Cab 6.0L
2004.5 Dodge Ram Cummins
2006 Jeep Liberty CRD
2007 ML320CDI
Soon To Be 2007 Dodge Ram 2500 6.7L
http://www.spdiesel.com
"Can your Resistor do this?"
spdiesel is offline
Old 01-27-2007, 01:01 PM   #5 (permalink)
CSIPSD's Avatar
My Photos: (52)
The SP diesel one is the best on the market, with the best control and the best set up. It is all plug and play no cutting, no hacking. Had mine for two years with no issues.
05/01 F-250 PSD,170k, Zoodad, AFE Stage 2, CCV mod,Modded H2e, 6.0 IC,Water Injection, AIH delete,ITP Regulator,Swamp tuned,GTS Hybrid injectors, ITP Fuel system,Studs, 910 valve springs,Suncoast 4r100,MBRP T-409 duals,Aeroturbine, 6" tips, 16 Isspro gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
MY PICTURES
CSIPSD is offline
Old 01-27-2007, 02:02 PM   #6 (permalink)
Dont forget you can mod your EBPV to operate as one too!
wells
mtnbkr132 is offline
Old 01-27-2007, 03:00 PM   #7 (permalink)
CSIPSD's Avatar
My Photos: (52)
wells
Thats what we are talking about...
MY PICTURES
CSIPSD is offline
Old 01-27-2007, 03:33 PM   #8 (permalink)
Sweet! I didnt even know. How much is the SP unit?
wells
Old 01-28-2007, 01:20 PM   #9 (permalink)
what year is your truck...better yet email us...
sean@spdiesel.com with your truck info and I will get back to you with a quote. i am not allowed to talk price on the forum.
Test Fleet
2007 ML320CDI
spdiesel is offline
Old 01-28-2007, 01:24 PM   #10 (permalink)
I had one from puredieselpower.com when I had my old turbo, worked great.
2000 Black Excursion,PFC 2 piece rotors,Tipton tuned,BDP stage 2 singles, BDP H2E, AFE stage 2, Spearco 7.3, ITP Reg. return fuel system, Evans, BTS, 186,000 miles....And still goin' strong! Thanks Beansdieselperformance.com and Puredieselpower.com for all your help
BBBxcursion is offline
Old 01-28-2007, 04:57 PM   #11 (permalink)
what about the banks brake? They seem to make it sound like it is so much better than the others...not true?
2002 F-250 7.3 lariat cc/sb. Voyager Brake Controller. Boss Snow Plow. Rollaway bed cover. 4" Turbo back System w/cat delete, 5"tip. SP Diesel Stage IIe Module
114,000 miles
next:tymar intake. gauges+pillar mount.
Pulls a 24' Wilson Polished Alum. Livestock trailer completely loaded with options. To haul my show cattle around [img]/ubbthreads/images/graemlins/smile.gif[/img]
athomp_21 is offline
Old 01-28-2007, 07:18 PM   #12 (permalink)
SmokeyWren's Avatar
My Photos: (42)
There are two basic designs for an exhaust brake for our PSDs. The design we're discussing in this thread is the "cheap" kind of "electronic" exhaust brake that uses electronics to manipulate the exhaust back pressure valve (EBPV). When closed, the EBPV causes some engine braking effect. The plain exhaust brake costs around $200, and the torque converter lockup capability costs another $200, for a total of around $400.
The "expensive" kind of exhaust brake adds a butterfly valve to the exhaust system, right after the turbo, and doesn't use the EBPV. Those are made by Banks, BD, U.S.Gear, PacBrake and others. They cost over $1,000.
So yeah, the Banks is a good 'un, but it costs more than twice as much as the kind we're discussing.
BD makes both the cheaper BrakeLoc and the high-priced BD Exhaust Brake. So you can compare the two designs from the same manufacturer on the BD website at www.dieselperformance.com
Note that the BrakeLoc for '99-'03 7.3Ls costs $400, and includes the torque converter lockup controls. The BD Brake costs $899, plus another $405 for the TowLock torque converter lockup control. So about $1,300 to go with the best BD makes. I haven't priced the Banks Brake, but I'll bet if you get one for an automatic tranny that includes with torque converter lockup control, it will cost you at least $1,300.
Old 01-28-2007, 07:45 PM   #13 (permalink)
I love that I have a 6-speed. I gotta say, I really was hoping to get the "brap brap brap" sound that 18 wheelers make. I freaking love that.
Steve91T is offline
Old 01-28-2007, 08:09 PM   #14 (permalink)
with a 6speed you actually can control the performance a lot better since you have more direct control over the revs'...And yes you save some money. As for competing solutions, I would respectfully challenge any potential buyer to find as many conveniences and features for the money...Be it less or be it more money...
Test Fleet
2007 ML320CDI
spdiesel is offline
Old 01-29-2007, 09:45 AM   #15 (permalink)
afboone88's Avatar
My Photos: (22)
I have SPDiesel's too! Works great! I love towing with it. Truck and trailer coming down a hill it's nice to let the engine do the work not the brakes. My wife drives the rig on the long trips and she enjoys having the exhaust brake. She feels the truck is under control. I got pulled over by some local cop one day cause I had it set in a "NO Exhaust braking zone" [img]/ubbthreads/images/graemlins/mad.gif[/img] I told him I didn't have a exhaust brake. He said I was lying and that he heard me exhaust braking with the truck. [img]/ubbthreads/images/graemlins/shocked.gif[/img] He called another cop and they looked under the hood for 30 minutes trying to find it. [img]/ubbthreads/images/graemlins/smirk.gif[/img] Of course no external device on the exhaust so they had to let me go! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2000 F-350 4X4 PSD CC, Extang R/T, Lund interceptor, Line-X bedliner, Heated TT Mirrors, High pressure crossover line, <font color="red">SPDiesel Stage Ie "mini" & T/C&EBV Controller</font> Diesel Power Products tank mod , * ISSPRO Pillar Gauges
Tru-Cool Max trans cooler, FTVB, Amsoil ATF, MBRP exhaust
My truck
afboone88 is offline
