EGT's at an idle - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 09-28-2009, 04:55 PM   #1 (permalink)
Ryanspowertroke's Avatar
EGT's at an idle
Just wondering what some guys egts at idle were. I just installed set of glowshift gauges (price was right free) just want to come pair temps. It runs 250 when engine is at operatin temp.
2000 F-250 7.3L
8" Lift with traction bars
325/80/16 ProComps
DP Tuner High idle,60t,80eco,120r,140ag
DIY Tymar Intake
4" MBRP straight piped
foil delete, zoodad mod, 10K mod, aih delete
Glow Shift guages they suck but they were free
Ryanspowertroke is offline
Old 09-28-2009, 09:33 PM   #2 (permalink)
fulltimer50's Avatar
My Photos: (16)
Mine runs about 300 pre turbo
George
6/2011 F350 PSD Lariate, CC, 4x4, LB, DRW
06 Newmar Cypress 29KSRE 5th wheel/MorRyde IS, Kodiac Disc Brakes.
fulltimer50 is offline
Old 09-28-2009, 09:58 PM   #3 (permalink)
LTFFNREMTP's Avatar
225-250ish once warm, pre turbo.
'99 F250 CC-SB 4x4, AFE Stage 2 intake with Pro-Guard 7, Dieselsite coolant filter, DiPricol Full gauges, AIC, On board air + Buell emergency series air horns, Striker turbo timer, Striker I module, Cyclops anti-theft module, TC lockup and 6.0 trans cooler. Powerslot Cryro'd rotors and Hawk LTS pads.
LTFFNREMTP is offline
Old 09-28-2009, 11:08 PM   #4 (permalink)
westvandude's Avatar
About 325-350 measured in the up-pipe 5" from exhaust manifold pre-turbo.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
Old 09-29-2009, 02:20 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
My thermocouple is in the up pipe (pre-turbo). My TTM is set for 300°, so the engine dies at 300°. That usually takes about 60 seconds when unloaded or two to three minutes when towing at highway speeds (74 MPH unloaded or 62 MPH towing). If I don't turn off the key, mine will very slowly cool off to around 280°. If I crank it cold and immediately let it idle, it begins at about 275° but slowly warms up to about 280°.
SmokeyWren is offline
Old 09-29-2009, 02:36 PM   #6 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Around 370-400 post turbo after idling for a while...
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
