exhaust brake + PMR's = bad???? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-05-2009, 11:27 AM   #1 (permalink)
bryrylan's Avatar
My Photos: (11)
I have an 02 F-250 (see sig) I really want to put an exhaust brake on it however I'm scared that I'm going to brake a rod, I got the impression from being on here awhile it dosent take much past stock to stress these out? Can anyone on here tell me if there running a simular setup to me with and good or bad results? thanks.
Bryan
2002 F-250 3.5" leveling kit, 305-70-16 Procomp AT's,Eagle alloys 16" rims,Autometer procomp trans boost pyro gages, AIS, Coolat filter ELC, TS 6POS chip, Banks Billet torque converter, Transgo tugger shift kit, galaxy CB pumpin 20watts, Sirius radio,Kenwood cd player, kenwood door speakers, Infinity tweeters, 500 watt Pioneer amp, 10" Pioneer sub, Panelite LEDs, Custom back rack with LED lights, Bores guide poles, SHO-ME led warning lights, 4" exhaust, Grandrock 5" stack kit with bullhauler stacks,MBRP y pipe cover, 9Ft Fisher plow. Timbren SES
1995 30ft 14K Gooseneck flatbed.
10K winch
All LED lights
bryrylan is offline
Old 07-05-2009, 12:33 PM   #2 (permalink)
Sleeperstroke's Avatar
Me Blizzard is the same truck you have. I DIYd my EBPV brake, and have had no issues. What you are thinking of is this. PMR rods dont like any HP over about 350. Most name 400HP as the limit, but personally I would not push them even that far. The EBPV brake does not put any detrimental stress on PMRs as far as I know, its a good mod for the price, and helps greatly when traveling down long highway grades with a loaded trailer.
"Blizzard" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a "New" secret blend of Haul a$$ing mods and upgrades. Suffice to say, its not the fastest, but it quite possibly is one of the quickest.
Sleeperstroke is offline
Old 07-06-2009, 04:22 PM   #3 (permalink)
Feedback Score: 3 reviews
No problem using PMR's and a exhaust brake.
Cary
caryt is offline
Old 07-06-2009, 05:39 PM   #4 (permalink)
Only problem I have heard of (International) is possibly floating an exhaust valve when using exhaust brake on these motors. High rpm + high Load + Exhaust Brake = Motor Brokey.
PMR or Forged Rods make no difference if your valve hits a piston
Work rig - 2000 F250 7.3 4x4 3.73 auto, 285/75 Michelin ATX, hpx, zoodad, hutch mod, 4" mbrp, 6637, isspro 3 pod, Trucool, ATS ported shroud (someday).
Farm rig - 85 6.9 xl t18 4x4 3.73ls, 88k orig miles, zig-style ram air, electric fuel pump, soup bowl delete, manual 12v glow plugs, Battery isolators, KISS principle generously applied.
Njellison is offline
Old 07-06-2009, 09:26 PM   #5 (permalink)
How are you doing the DIY EBPV exhaust brake?
1999 F350 CC Dually, Bright Amber Red
2001 KTM 520 EXC
2008 KTM 530 XCR W
2009 INFERNO 3912 Toyhauler 42'
DRKnecht is offline
Old 07-07-2009, 01:34 AM   #6 (permalink)
CSIPSD's Avatar
My Photos: (52)
There is no worry with an exhaust brake, none what so ever. Its a great mod I ran until going to a H2e turbo.
05/01 F-250 PSD,200k,AFE2 ,Modded H2e, 6.0 IC,Water Injection, AIH delete, Swamp tuned, GTS Hybrid injectors, ITP Fuel system, Studs, 910 valve springs, Suncoast 4r100,MBRP Duals, 6" tips, 17 Isspro Performax gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
CSIPSD is offline
Old 07-07-2009, 01:02 PM   #7 (permalink)
I've never see anyone post of valve float on a PS, I used one for over 100k..a BD worked great!
Cary
caryt is offline
Old 07-07-2009, 02:00 PM   #8 (permalink)
Cowcop's Avatar
Smile
What Caryt said! Go for it!
99.5 F-350 S/C 4X4 - gone
2012 F 350 S/C 4X4 Lariat - stock as a rock for now...
Cowcop is offline
Old 07-07-2009, 02:01 PM   #9 (permalink)
Justin C.'s Avatar
The exhaust back pressure valve acts like an exhaust brake if you wire it to a switch where you can turn it on and off. Works great, and costs pretty much nothing. If you have an automatic you have to wire up the torque converter to lock also.
Justin
Justin
1997 F-250 Power Stroke
- 230k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
2005 F-350 Power Stroke (work truck) - 220k
ARP Studs, PHP 40 hp flash
Justin C. is offline
