Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Favorite Upgrade To Increase Engine & Drivetrain Longevity
Thought it might help some of the newbies and even some of us "oldies" if we each posted our one favorite upgrade/mod to increase the longevity of our 7.3L engine/drivetrains to make them last longer. I will start:
Mine is the Ford Severe Duty AIS intake system!
Mike
2002 2WD XLT CrewCab, 3.73 Limited Slip, Assembled 08-09-01 in Cuautitian, Mexico. BTS Tranny with 6.0L Cooler, KC reverse backup lights with separate on/off dash switch, Undercover Bed Lid, Bilstein shocks, Gentex K-21 auto dimming/temp/compass mirror, Michelin LTX/MS tires, Factory Aluminum Wheels, Door Seal Mod, Ford Severe Duty AIS w/Zoodad, Royal Purple 75W-140, Fleetrite ELC Coolant, Billet Aluminium Thermostat Housing, Ford Factory Bed Liner, Sylvania Silverstar Ultras.
You guys hit it right on the head already. Clean oil and clean air. For those who don't know better, do NOT install a K&N air filter. They don't seal down properly in the stock air box and suck dust around them wearing the engine totally out in no time.
Three years ago there were some reports of bypass oil filtering setups being too agressive and causing added wear, so do your homework.
I also agree that gauges should be one of the first mods, with EGT and tranny temp gauges being necessary even on a stock tuned truck. Start fooling with boost and you need a boost gauge, because you are going to exceed the parameters of the stock turbo, which looks neat on the boost gauge but in fact means you are pre-heating the air and reducing the number of O2 molecules in a given volume.
I also like the idea of running straight piped exhaust and did on my excursion because it didn't require a cat from the factory to meet emissions in 2000.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
Ok, I am a newbie here... the above statement just made the hair on the back of my neck stand up.
I have been running a K&N for 60K miles.... Is there any way to validate a poor seal? Is there a way to clean up the mess that might have been caused, or am I screwed?
You might find trace amounts of dust in the rubber tubes between the filter and the turbo. Sometimes it depends on how dusty the roads are where you drive.
Be aware than not all K&Ns leak, but it's not worth the risk. K&N advises that users apply a sealing material to the gasket on the filter ("special" K&N grease).
I trashed my K&N after 25K miles. There are plenty of alternatives that work far better. I went with an AIS, others use a Tymar, and others have engineered their own. The stock setup is not bad if you don't modify the truck.
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
M
Get an oil analysis. If the filter is leaking you will have high silicon and iron. But in the meantime, relax. Most of the people who talk about leaky air box with K&N filters don't know the source of the rumor. If you have the correct filter in your truck, there is a better than average chance it isn't leaking. But if you drive in a dusty enviroment you should be using a Ford AIS system.
subscribed. As a new I'll be intereseted to see everyone's favorites
'00 F250 7.3L, 4x4, 6-spd, SCT X3, ATTA 90 gallon tank/toolbox, Air Lift Loadlifter 5000 kit. WVO kit in the making...now if I could just finish getting the CANbus code written for that HE431VE.
Great thread! For newbs like myself this is a blessing. I purchaced my 97 last summer, and it came with a K&N in the stock airbox although it didn't look very old. Now I have full justification to purchace the Cold air intake I've had my eye on. NOT A K& N
You know I've heard not so good things about the K&N on my motorcycle too. Most people say to keep the stock filter on that compairativley.
The guages will come soon. I have an auto tranny and I was wondering how many miles you can typically get out of it. I know there are alot of factors. My truck has 180K and I don't think it's ever been rebuilt. Anyway keep up the info. It's great.
M
A quick look at your turbo's blades should be in order as well. Pull off the intake hose to the turbo, grab a good light and have a look at those blades. If you've got nice clean, straight edges then you are probably getting the filtration that you need. If you see worn, chipped or rounded edges then you've probably not had the air filtration that you should have.
