Favorite Upgrade To Increase Engine & Drivetrain Longevity - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-11-2008, 10:18 PM   #16 (permalink)
Sure glad this post is helping some of our newer members. Keep'em coming.
Never know who might just need the help and are hesitant about asking for help.
Mike
2002 2WD XLT CrewCab, 3.73 Limited Slip, Assembled 08-09-01 in Cuautitian, Mexico. BTS Tranny with 6.0L Cooler, KC reverse backup lights with separate on/off dash switch, Undercover Bed Lid, Bilstein shocks, Gentex K-21 auto dimming/temp/compass mirror, Michelin LTX/MS tires, Factory Aluminum Wheels, Door Seal Mod, Ford Severe Duty AIS w/Zoodad, Royal Purple 75W-140, Fleetrite ELC Coolant, Billet Aluminium Thermostat Housing, Ford Factory Bed Liner, Sylvania Silverstar Ultras.
TooCoolTwo is offline
Old 02-11-2008, 10:34 PM   #17 (permalink)
ron68coug's Avatar
My Photos: (5)
The first thing i noticed when I bought my truck is that the air filter barely has any squish from the top cover to make the seal it needs. an intake is on the top of my list.
01 F-350 CC DRW 4x4, bright red, 7.3 stock, 44k miles, leather heated seats , alum. headache rack, new Toyo M/T 315/75R16's x 6, 6" Superlift lift kit, Pro Comp traction bars, bilstein shocks, Fred Goeske 2" pilot hub wheel spacers, Viair 480C compressor, and Nathan train horns.
ron68coug is offline
Old 02-13-2008, 04:11 PM   #18 (permalink)
Originally Posted by mjmoor2 View Post
Ok, I am a newbie here... the above statement just made the hair on the back of my neck stand up.
I have been running a K&N for 60K miles.... Is there any way to validate a poor seal? Is there a way to clean up the mess that might have been caused, or am I screwed?
M
The previous owner of my truck was a K&N fan. If I had done my home work, I never would have bought the truck. The turbo compressor wheel was beat to hell. Hopefully, I won't have engine problems later on. IMHO, K&N sucks!
Early 1999 F350 SC XLT
2/98 Build
SRW, 4x4 ESOF, 6 Speed,
DP F5 Tuner 60 Tow, 80 Economy
Ford AIS, DiPricol Gauges
6.0 Intercooler
EBPV Delete
NCHornet's CCV Mod
ITP Fuel Tank/Pre Filter Kit
ITP Regulated Return Kit
KCM SS HPX Line
Power Slot Cryo Rotors
Hawk LTS Pads
4" MagnaFlow Stainless Exhaust
2004 Headlights/Corner Lights
Monroe Reflex Shocks
Michelin LTX/MS
B&W Turnover Ball Gooseneck
37Driver is offline
Old 02-13-2008, 04:37 PM   #19 (permalink)
K&N filters are good but not for these trucks...the fitment is poor as hell...I found out the 250 I bought had a K&N filter in it once I got home and its gone.
'00 F250 7.3L, 4x4, 6-spd, SCT X3, ATTA 90 gallon tank/toolbox, Air Lift Loadlifter 5000 kit. WVO kit in the making...now if I could just finish getting the CANbus code written for that HE431VE.
'96 Impreza "WRX" coupe time attack car
Homemade WRX is offline
Old 02-13-2008, 10:02 PM   #20 (permalink)
it was an early amsoil system that had no pressure when it first cranked..so it actually cause d more wear...or something to that effect.
ditching the broken tab oem air box is a good first step.
after that I imagine a coolant filter is a good one.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
Old 02-14-2008, 07:42 AM   #21 (permalink)
Any more thoughts?
Old 02-14-2008, 08:33 AM   #22 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Originally Posted by 444-4D View Post
How would a bypass oil filter be too agressive?
The dual remote bypass filter system from Amsoil was bypassing too much oil and the operating pressure was lower, especially on first startup. Those folks found that their wear metals were higher with the dual bypass even with normal oil drain intervals. The dual remote bypass is no longer recommended by Amsoil for our trucks as I understand it. I have noticed this since upgrading my HPOP. The pressure idiot gauge from Ford take longer to lift off the peg and my idle pressures are lower than before dual HPOPs. Wear metals are higher coinciding with the dual HPOP installation. I am going to install a relief valve set at 20 psi so the bypass does not filter the oil until the PSI is greater than 20.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
haul_n_horses2 is offline
Old 02-14-2008, 08:36 AM   #23 (permalink)
My Photos: (17)
Originally Posted by TooCoolTwo View Post
Any more thoughts?
I would ditch the oiled gauze filters and install the very well engineered Severe Duty AIS. As Clam said clean oil and clean air.
Old 02-14-2008, 02:52 PM   #24 (permalink)
Chrysler79's Avatar
What is the difficulty level of installing the coolent filtration and oil filtration? Are they on the exspensive side?
Chrysler79 is offline
Old 02-14-2008, 03:05 PM   #25 (permalink)
DIESELSITE - DIESEL MAINTENANCE and PERFORMANCE
most popular coolant filter out there
also check out the 203 tstat and housing....he also has a similar tranny filter
6.0 tranny cooler is a great add on not cheap for what it is , you can actually get a 6.0 IC for less? (also works)
the fs2500 or the oilguard would be my choice for an oil bypass system.
work in progress
Old 02-18-2008, 10:50 PM   #26 (permalink)
Chrysler79's Avatar
Wow pretty cheap for what you get. Gonna have to pick one up. And I was just about to do a coolent change. Good to know.
97 250HD 7.3 4X4 Supercab 3" Downpipe; 4" MBRP exhaust; AFE intake;
04 Expedition 5.4 EB; 3" Magnaflow catback
06 Suzuki GSXR 600; Galfer brake lines; M4 slip on;Pazzo shorty levers
62 Corvair Monza; 2 Door; 4 speed
79 Chrysler Lebaron; 360 4BBl; 727 trans
Old 02-19-2008, 04:43 PM   #27 (permalink)
Parts Jimmy's Avatar
Install a Motorcraft AIS and service you truck regularly. A EGT gauge should be also a priority.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights
6.0-6.4 PSD Motorcraft Filter Comparison Video
Fuel Quality Video
Parts Jimmy is offline
Old 02-22-2008, 07:24 AM   #28 (permalink)
After clean air and clean oil, transmission and differential fluid changes are next that come to mind.
What are some good, real world change intervals that could be recommended to newbies and others?
Mike
Old 02-22-2008, 09:02 AM   #29 (permalink)
prolong engine lubricant , i run it on my 6.0 2 bottles in between oil changes
will run it on the 7.3 i picked up as well
been using it for years on my performance cars
took all the engine vibrations out of my 88 300zxt highly modified back in 1995
maybe saved my supercharged and bottle 01 z06 from blowing up at 680rwhp stock block and heads when it was only supposed to hold 600rwhp and not a pony more...
makes the engine feel like its on full roller bearings ..
2006 f250 king ranch 4x2
Performance
AFE stage_1 filter
4 inch turboback strait thru 6 inch tip
bully dog power pup @ 60%
Appearance
billet grill top and bottom
HID lights top and bottom ,
recon big rig running lights under doors ,
6 train horns
20 inch aftermarket wheels
roof visor with clearance lights
crome door handle covers gascap and mirros
recon under tailgate light bar
triple L.E.D reverse lights , very bright
L.E.D third brake light
2.5 leveling kit for the front , yes they sell it for the 4x2 very hard to find ...
Entertainment
alpine touch screen tv with navi ,tv tuner, and rear back up camera
15.2 clarion flip down with pip for the rear
rearview mirror with built in tv for rear mounted camera
complete up graded sound system with pioneer speakers all around, sub, and apms..
viper alarm with remote start and pager
MIKEHKS is offline
Old 02-22-2008, 09:33 AM   #30 (permalink)
ammayernick's Avatar
Amsoil Oil Bypass filters with amsoil HD diesel oil.
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps * http://community.webshots.com/user/ammayernick
ammayernick is offline
