Favorite Upgrade To Increase Engine & Drivetrain Longevity - Page 5 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 09-18-2009, 07:21 AM   #61 (permalink)
Any more, not only for us longer time diesel owners, but for a newbie who might have his/her first Ford diesel?
2002 2WD XLT CrewCab, 3.73 Limited Slip, Assembled 08-09-01 in Cuautitian, Mexico. BTS Tranny with 6.0L Cooler, KC reverse backup lights with separate on/off dash switch, Undercover Bed Lid, Bilstein shocks, Gentex K-21 auto dimming/temp/compass mirror, Michelin LTX/MS tires, Factory Aluminum Wheels, Door Seal Mod, Ford Severe Duty AIS w/Zoodad, Royal Purple 75W-140, Fleetrite ELC Coolant, Billet Aluminium Thermostat Housing, Ford Factory Bed Liner, Sylvania Silverstar Ultras.
TooCoolTwo is offline
Old 09-18-2009, 09:18 AM   #62 (permalink)
acer2428's Avatar
Crankcase Vent Mod (CCV) - Doesn't help your motor per se, but will help your stock boots last longer.
Runs the hose the currently runs from driver's valve cover to your intake, to the rear of the vehicle, preventing sloppy oil mist from entering your intake tract.
acer2428 is offline
Old 09-28-2009, 01:44 AM   #63 (permalink)
CGBear's Avatar
Always check your differentials and transfer case fluid levels. Do it often and do it yourself.
1993 F250 supercab longbed 4x4 with a quarter of a million miles. Stock 7.3, e40d trans and 3.55 rear gears. I got rid of my silly 6" exhaust stack in the bed and installed a thrush turbo w/side dump exhaust. The thrush gave it a little too much hush. Pro comp 6" suspension lift. Got a Meyer 7.5 foot snow plow, a flipper style gooseneck hitch, a cushion ride tag hitch and a 21,000lb fifth wheel hitch.
CGBear is offline
Old 09-29-2009, 07:01 PM   #64 (permalink)
dgribble's Avatar
I'm still new at the diesel thing, but I've also caught the PMS bug sinse I retired from racing. One thing I always do is add a fuel additive. Normally the grey bottle of Powersource. The Nov 2009 issue of DIESELPOWER magazine has a good article in it! The new low sulfur diesel is lacking!
2001 F250 7.3 4x2 4R100(Performance)-Garrett GTP38R 4.0" turbo back Polished stainless exhaust K&N aircleaner tube w/Amsoil air cleaner-Snow Methanol Stage3 6ltr intercooler-Big Dawg tranny cooler W/E-Fan-air ride rear-Heat extractor hood-4:10 rear gear-08 diff cover-Isspro ev gauges Volts-Tranny Temp-Water Temp-Fuel Pressure-
Polished and Red CFM+-Airdog100-Jobes EBV delete
Stealth Dual HPOP w/custom made fittings-
Edelbrock AIS shocks CCV Mod-Amsoil bypass filter
Diesel Innovations fuel return system
Swamps 275 Injectors-Flexi-A-Lite E-Fans
09 Cyclone 40ft Toy Hauler
08 Harley FXCWC
dgribble is offline
Old 10-01-2009, 12:43 AM   #65 (permalink)
bigb's Avatar
I have seen a lot of comments on the K&N, but none on the Airraid. Are they the same? Mine had an Airraid on it when I bought it, it now has the AIS. When I looked at my turbo wheel it looked pretty good, blades all straight, clean and shiney, no pits or rounded edges. I still feel better with the AIS. I get the same power, but I do miss the WOOOOOOOOOOOOOM I'd get with the Airraid!
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 140K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Battery Tender & 2 Marincos.
bigb is offline
Old 10-01-2009, 01:56 PM   #66 (permalink)
boomboom's Avatar
It really depends on the road conditions you drive on. If it just staight highway or city asfault a open element air cleaner could ?? be fine, BUT if you have any dirt or gravel roads that you stir up dust a closed airbox system like the AIS is BEST. Just look at your engine compartment, is it dirty well all that type of dirt is being sucked by you filter. A closed system sucks from you front grille area which tends to have cleaner air even on dirt roads As long as your leading and not in second place.
boomboom is offline
