Foil delete - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-21-2009, 07:49 PM   #1 (permalink)
Ryanspowertroke's Avatar
Foil delete
The foil delete does it make a big difference in turbo noise
2000 F-250 7.3L
8" Lift with traction bars
325/80/16 ProComps
DP Tuner High idle,60t,80eco,120r,140ag
DIY Tymar Intake
4" MBRP straight piped
foil delete, zoodad mod, 10K mod, aih delete
Glow Shift guages they suck but they were free
Ryanspowertroke is offline
Old 07-22-2009, 01:46 PM   #2 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
yes, it actually does.
Look at my pictures to see how they can look w/o it.
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 07-22-2009, 03:08 PM   #3 (permalink)
My Photos: (23)
But the "agressive wheel" is what makes it even louder. Here:Agressive Banks Turbo Wheel
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-22-2009, 05:38 PM   #4 (permalink)
My Photos: (19)
I deleted my foil at the same time I did the ATS housing and took off the wicked wheel and returned the stock wheel. I don't know what did what for sound. But it's not all that much louder. I can hear it, but with road, tire, and radios going I can't hear much.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 07-22-2009, 05:44 PM   #5 (permalink)
My Photos: (23)
Mine is loud, it whistles , it screams even with radio etc.. and I don't even have my ported shroud installed yet.
The aggressive turbo wheel is what did it first, and now w/o the foil and the S&B intake, it really made it loud.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-23-2009, 12:55 AM   #6 (permalink)
BubbaZ71Tahoe's Avatar
i am thinking about doing this also.... do yall have to re balance the wheel when changed or is just a bolt on mod?
2002 f250 ecsb 7.3,4r100 triple disc converter shift kit, amsoil atf, 60/10.5 DIY Tymar, (ISSPROboost, trans, Egt) PHP FU.
AutoEnginuity in the Lafayette-Houma area
BubbaZ71Tahoe is offline
Old 07-23-2009, 09:16 AM   #7 (permalink)
I did mine, and mine is very loud as well. I also have a 6637 filter, tuner, and exhaust on my truck and my turbo/intake scream...between the whistle, and all the whooshing noises it's perty cool actually. Toss my trailer behind it, and on the highway I can hear all the underhood noises OVER the stereo.
'02 F-250 Super Duty CCSB 4x4. 7.3L Powerstroke, Lariat Trim, Black and Tan with Tan leather, 5% tint all around, 5% eyebrow, 4" MBRP Turbo-Back, 6" tip, A-pillar Guages, (Boost, Pyro, Trans) 6-position chip from Matt at Gearheads Automotive, ITP ported housing, Alpine WMA/MP3/IPOD Headunit, JLAudio G1300 Amp, JLAudio 12 w1v2-4 12" Sub, Leveled, 305/60/18 ProComp Xtreme A/T's, on 18x9 ProComp 1089's, Firestone RideRites. Garage Kept DD/Tow Pig.
'03 Yukon Denali, 6.0 AWD, LOADED, on 20's.
'08 Pace American 24' Pursuit Car Trailer.
Al Mighty is offline
Old 07-23-2009, 09:52 AM   #8 (permalink)
My Photos: (23)
Some say to rebalance it, most don't do it.....I didn't and so far no problems.
If you get the S&B intake don't use the clear acrylic cover on top, it rattles and it doesn't breath as good as leaving it open, big diff in noise w/ it on and off.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-23-2009, 09:57 AM   #9 (permalink)
also if you do the foil delete you csan be like me and powdercoat the pipes, add a little dressup to thee underhood
Old 07-23-2009, 10:01 AM   #10 (permalink)
My Photos: (23)
Did that to mine too , here:CAI,CFM+,Ceramic Coated IC Pipe picture by powerstrokeconverters - Photobucket
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-23-2009, 10:20 AM   #11 (permalink)
you notice any difference from that CFM intake? What about from the 4" turbo back? I want to do full 4" exhaust, with a muffler, but I'm afraid the muffler will kick my egt's up...I already fight with keeping them below 1250 loaded...
Old 08-04-2009, 08:26 AM   #12 (permalink)
Seems to me with the reading that the foil is there only to keep the noise down correct? Or does it have another function like to keep heat away from other componets near it?
Does the wicked wheel mod help with getting more boost or just a mod to prevent turbo surge?
02' F-350 Powerstroke CC Dually, Edge Juice w/attitude, 4" exhaust turbo back and K&N Air Intake
TinyScramblerMan is offline
Old 08-04-2009, 09:48 AM   #13 (permalink)
That would be my concern as well...
PowaStroka is offline
Old 08-04-2009, 10:48 AM   #14 (permalink)
With doing the WW mod to the turbo and changing the boots out would changing the wastegate be something logical to do since we will be right there? or should i just leave the stock one in?
Old 08-05-2009, 09:26 AM   #15 (permalink)
My Photos: (23)
Only if you are sure that yours is bad, I think the only problem with the stock WG is that it starts bleeding boost too early, some say as early as 5 lbs.
I have noticed a big difference in boost ever since eliminating the red line that goes to it, but I also have other intake mods like the CFM+,AIH delete,CCV relocated and S&B CAI.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
