The only thing I would add, the '05 and up trucks have a place to put those switches as some of them came that way from the factory. The '04 and older trucks don't have the factory location and will require some cutting and fab-ing to make them fit on the dash.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
