Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-07-2008, 09:54 PM   #16 (permalink)
Re: garret bb or turbonetics??
That is a stock turbo, Garrett was the supplier for the 7.3's, but yours isn't the Ball Bearing version..
Ironhide is offline
Old 01-07-2008, 09:56 PM   #17 (permalink)
kaseym's Avatar
ok thanks. thats what i thought.
2002 F-250 CC 4x4 with a ts 6 pos, k & n filter, muffler delete and auto meter guages.
kaseym is offline
Old 01-07-2008, 10:01 PM   #18 (permalink)
I know it will, but for an extra $1000 is it worth getting to satisfy his hp goal?
PS...I only live 30 minutes away from the person who developed the QSSB. [img]/forums/images/%%GRAEMLIN_URL%%/whistle.gif[/img]
Danny Om
My Truck
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
APC Projectors (HID 10k), clear corners, clear cab lights, clear dually side markers, Amp-Research retractable side-steps, power rear-slider, Snug-Top canopy, billet grill, and chrome truck nutz!
Fully built motor w/ B-codes, GT42R, and Terminator w/ remote IPR HPOS.
Auto Enginuity Pro-Bundle equipped if you need assistance locally.
duallyduty is offline
Old 01-08-2008, 01:44 AM   #19 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">I know it will, but for an extra $1000 is it worth getting to satisfy his hp goal? PS...I only live 30 minutes away from the person who developed the QSSB. </div></div>
I'm pretty satisfied with what the extra $1000 bought and I'm still running stock injectors. However, if I was staying with stock injectors, I'd have probably gone with a TN. I'm not gonna enter the whole surge war with the Garrett BB but too much has already been said and you know how it goes, "where there's smoke....". I also believe that you get what you pay for.
So being that you only live 30 minutes away from the dude that developed the QSSB, what does that make you? His neighbor? [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
1999.5 F250 2wd SC 6spd PSD, Auburn LS, AFE Stage 2 w/PG7, DP Chip, Holset H2E, MBRP 4" Turbo-Back Exhaust, Silverline 5" Black Chrome Tip, SouthBend Clutch, Midwest Short Shifter, ITP Overboost Annihilator, DI Regulated Return, AirDog, Fuel Bowl Delete, AIH Delete, HPX, 203* TStat, CCV Mod, ISSPRO Gauges in Pillar, DiPricol Gauges on Dash, Air Lift SuperDuty Bags w/Onboard Load Controller, Optima Reds, APC Headlights w/Clear Signals
PowerStroke owner since 1999
pics
mitchrock1 is offline
Old 01-08-2008, 02:20 AM   #20 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PwrStrokinDually</div><div class="ubbcode-body">I know it will, but for an extra $1000 is it worth getting to satisfy his hp goal?
PS...I only live 30 minutes away from the person who developed the QSSB. [img]/forums/images/%%GRAEMLIN_URL%%/whistle.gif[/img] </div></div>
Maybe 30 minutes on a 10 speed bike.
99.5 F-350, 6 speed - DI Tuning, DI B-Codes, DI Reg Return, DI One piece up-pipes, DI Pushrods, DI Intercooler, DI HX-crossover, DI Intercooler, ARP Head Studs, Garret GTP38R, FASS 150/150, Magnaflow Turbo back, Boost pressure regulator, Comp 910 Valve Springs, South Bend Con-FE Clutch, AFE Stage II, Autometer Sport Comp II gauges
Leveling Kit w/35X12.5R16 Nitto Mud Grapplers 10 Ply.
Rockrunner86 is offline
Old 01-08-2008, 04:18 AM   #21 (permalink)
Enabled me to learn more about turbos and forced induction the past year I've met him than over the past 15 years of working with them. And practically neighbors. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
Danny Om
My Truck
Old 01-09-2008, 12:01 AM   #22 (permalink)
Pias is a Great man to talk to I send him turbo all the time from all the equipment we have. When he was in stockton I got to see him now it's .
00 CC, LB, DRW, Black F350 4x4, 6 speed, lunar series Boost and EGT. DP tuner 6pos chip SBC clutch,fuel system. GTP 38R BB, by Diesel Inovations. Weld Typhoones rims, Tymar filter,CCV mod and TERMINATOR OIL.
97 CC, SB Green F250 4x4 5 speed, SBC clutch, F5 DP chip, Isspro boost, EGT.Stage II sticks, Tymar, CCV mod, TERMINATOR OIL, Banks pipe kit IC, fuel system, GTP 38R BB Turbo, Weld Typhoones
07 Dodge CTD, QCSB, Dark Gray 4x4, 6 speed, Tinted windows and a B&W hitch, MBRP 4in, AFE Stage 2 Progaurd 7, Centerline Wilderness Grizzly, Smarty CR, Quadzilla Commander, Fass 150, sbc , head studs so far a MPI twin turbo ,DDP 90hp tips also. It still smokes a little
deerezilla9620 is offline
Old 01-09-2008, 01:13 AM   #23 (permalink)
westvandude's Avatar
What diameter is the stock Garrett compared to the 38r or TN? And are we talking intake impeller diameter or exhaust side?
What's the max sustained psi either turbo will push without turning into a grenade? Factory Garrett is 25psi correct?
Does your intake filter setup affect surge a lot? Would a AFE stage2 be better than AIS for surge or worse?
I'd have to say, everyday driving for me sees a lot of 1500-2000rpm so a turbo that is slow to spool would disappoint me.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DarkShadowDiesel</div><div class="ubbcode-body">preference.
facts about the two:
the map on the 38r shows the surge line farther to the right than on the TN, which explains why some have surged. ANY turbo will surge under the right conditions.
the TN is 61mm the garrett is 66mm - the result is the garrett flows a bit more air. the dyno comparison i was informed of (scheid) showed a 12 peak hp difference between the two (the garrett was higher). that was the old journal bearing TN.
TN has a ceramic BB on the comp side, the turbine side is journal bearing - that is how it was designed.
garrett has a dual BB center section.
both designs have their merits.
fwiw if you plan on going past 500whp, there is a high output version of the TN in testing that is supposed to flow more than the garrett - it uses some GT-K parts/F1 turbine wheel.
basically pick a vendor and go. i run a TN BB from BWD. they sell turbos from both mfgs. plenty of others sell the garrett with satisfied customers - DI, ITP etc.
lots of happy customers either way, so you won't go wrong. </div></div>
2001 F250 4x4 crew lariat 7.3L auto, clear corners & taillights, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, PI Stallion converter, modded valve body, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Walker 21470 BTM muffler, dieselsite boots & coolant filter & HX crossover, Fleetguard LF9027 or LF3630 hi-cap oil filter, Rotella T 15w40, DIY Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck.
westvandude is online now
Old 01-11-2008, 04:15 AM   #24 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: westvandude</div><div class="ubbcode-body">What diameter is the stock Garrett compared to the 38r or TN? And are we talking intake impeller diameter or exhaust side?
</div></div>
impeller - 61mm vs. 66mm
my guess is the TN HO will be 66+mm.
garrett recommends 40psi max. TN does not list a boost limit but says 400+hp is ok. "upgraded injectors, IC, programmer, recommended"
i would go with an AFE2 intake. don't know that it'll affect surge, but both turbos could use the additional air.
neither turbo will disappoint you on spool. my TN BB spools as fast/faster than stock.
2002 F250
DarkShadowDiesel is offline
Old 01-11-2008, 10:59 AM   #25 (permalink)
CSIPSD's Avatar
My Photos: (52)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: forddieselking</div><div class="ubbcode-body">There is a pretty good deal on the turbonetics BB turbo through Jegs. It's $1292.99 with free shipping, part number 880-11117-BB </div></div>
You can post that on every forum you want but that deal never existed for the BB unit... The price they list is for the bushing TN turbo.
05/01 F-250 PSD, 125,000 miles, Zoodad, AFE Stage 2, CCV mod, Turbonetics Ball Bearing, Turbo-Master wastegate, Dieselsite's boots, 6.0 IC,Water Injection, AIH delete,ITP Regulator,DP and Wildman tunes,GTS Hybrid injectors, ITP Fuel system,Studs, 910 valve springs,Suncoast 4r100,MBRP T-409 duals,Aeroturbine, 6" tips, 16 Isspro gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
ME!
MY PICTURES
CSIPSD is offline
Old 01-11-2008, 12:31 PM   #26 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: CSIPSD</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: forddieselking</div><div class="ubbcode-body">There is a pretty good deal on the turbonetics BB turbo through Jegs. It's $1292.99 with free shipping, part number 880-11117-BB </div></div>
You can post that on every forum you want but that deal never existed for the BB unit... The price they list is for the bushing TN turbo. </div></div>
I called them too and they say that part number is for a BALL BEARING turbo.. I also called turbonetics directly and asked them about that part number and TN even says that part number is for a BALL BEARING turbo.. So unless JEGS posted the wrong part number, that one IS for a BB unit just FYI..
Ironhide is offline
Old 01-11-2008, 01:49 PM   #27 (permalink)
CSIPSD's Avatar
My Photos: (52)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ironhide</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: CSIPSD</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: forddieselking</div><div class="ubbcode-body">There is a pretty good deal on the turbonetics BB turbo through Jegs. It's $1292.99 with free shipping, part number 880-11117-BB </div></div>
I called them too and they say that part number is for a BALL BEARING turbo.. I also called turbonetics directly and asked them about that part number and TN even says that part number is for a BALL BEARING turbo.. So unless JEGS posted the wrong part number, that one IS for a BB unit just FYI.. </div></div>
You will be dissapointed if you order that turbo and when it shows up you have the bushing model...
ME!
MY PICTURES
CSIPSD is offline
Old 01-11-2008, 02:07 PM   #28 (permalink)
So then BWD is selling the journal bearing one too since thier part number is the exact same part number as Jegs? I am simply curious..
Ironhide is offline
Old 01-11-2008, 02:29 PM   #29 (permalink)
CSIPSD's Avatar
My Photos: (52)
lol... believe what you want, but Jegs is not selling the BB TN unit for that price.
ME!
MY PICTURES
CSIPSD is offline
Old 01-11-2008, 02:38 PM   #30 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
See Fullboosts reply here. . Apparently they have been but they are now getting some heat from the manufacturer.
haul_n_horses2 is offline
