Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Hey finally got ahold of some gauges and now how a few questions on hooking them up. There c2 electrical gauges and came with the electrical sender instead of the probe like the egt gauge. Oil temp and Trans temp do I just drill a hole tap it and screw these senders in or do I have to take the pans off and put a nut on the inside and screw the sender into it? And where's the best place to get the readings? Thanks
2000 White F250 PowerStroke 4X4 Off Road
6 Inch super Lift
38 Inch Nitto Muds
BushWacker Pocket Flares
Dick Cepek DC1's
AEM Bruteforce Intake
AutoMeter C2 Boost, Trans Temp, EGT
MBRP 4 Inch Turbo Back Up to 5 To 7 Inch GrandRock Miters
Edge Juice With Attitude Moniter(Just For Gauges)
Custom Programing From Jody DP-Tuner F5
Stock,No Start, High Idle, 80 Econ, 120 Race, 140 Agressiv
OverBoost Annihilator, HPX Cross Over Line IC Pipe Foil Delete MOD
Running Garret GTP38R Ball Bearin non WasteGated 1.15 Exhaust Housing
Transmisson Done by The Local Guy New Housing, Transfercase and Drive Line Factory 3.73's "All Heavy Duty Billet Steel Internals"
Pro Torq Stage Three Billet Torq Converter
Rhino Liner, 10,000K HID's, Black Diamond Eye Head Lights, Recon Running Board LED's, Remote Start, Dual 7 Inch Touch Screen In Dash DVD, 12 Inch JL Audio Sub, Rockford Fosgate 600 Amp
Still Get Smoked By 6.0's
But Whos Truck Do The Women Always Want to Ride in?
If you drill and tap the trans have enough money in the bank for a new trans. You'll need one!
There is a port on the driver's side of the trans, towards the front of the trans, just above the pan. It has a black hex head bolt in it from the factory. Remove the plug and install the sender there. You'll only lose a teaspoon or so of fluid.
__________________ Mark Former Automatic Transmission Engineer 1988-2007
Ok cool just a double check I found on the Trans the black hex bolt right by the shift linkage on top of the Trans pan can't tell if its black or not but I'm assuming that's it and for the oil ur speaking of the one bolt other than the fasteners for the housing that looks almost like it doesent belong there ? As far as the egt I already did that way back but thank you anyways guys uv been a big help as always
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
One more question I got the gauges installed everything's good except the Trans temp and oil temp both just burry the needle past there max way to hot and inaccurate. Each of these gauges had a separate port for a ground but I didn't use them because the directions on the gauge said they ground through the sender. Y are these things reading wrong or is it just because I didn't use that ground port??
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
Well each of these gauges had five hook ups 12 volt constant tied to a switch, ground, sender, then + and - for the lights so I guess ill try to hook up the grounds and see what happens. They work there just not reading the right temp there's no way my oil temp is 300 degrees and my Trans temp five min of driving is 300 degrees it should be around 140 160
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
I have the C2 gauges from Autometer. The black leads have to be attached to chassis ground. I have 5 gauges on the pillar and all 5 are crimped on one eye that is screwed into the framework under the dash.
Train Horns: Pictures here
thanks gonna ground both with everything eles i have grounded to the dash frame. iv never seen so much wiring going up a pillar before five wires to each gauge is a bit crazy but it is what it is i guess.
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
DUDE! Thats wild! im all about it man cant have enough haha. theres a guy on here i forget his name but hes got like 26 gauges on his dash guys crazy love it tho howd you get that pic like that tho iv always tried and could never figure it out
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
yea iv never been able to just post a picture only been allowed to post a url link. oh well happy new years drinking has started thanks again for the help.
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
You might be doing it wrong. You don't need permission to post them here. Enjoy your NYE, be safe and sane. When you feel like it PM me and I'll explain how I post pics.
