Gauge hookup ?'s - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 21 (permalink) Old 01-03-2013, 09:52 AM Thread Starter
LoveTurbo's Avatar
My Photos: (60)
Well iv got everything hooked up now and the temps are still to high from the test port on the tranny I'm getting over 300 iv got a built tranny aftermarket true cool cooler and the oil is a perfect red not burnt there's no way the Trans is running that temp. Oil temp same thing still over three hundred with a reading from the port right ubove the filter. Motors running a steady water temp its not over heating egts are in the sixes while driving there's no way I'm running that hot. I know 245 250 is hot so I'm gonna change the oil and check the cooler and well go from there. What temps are you guys seeing and where are u reading from is there a port on the oil resivor I can put the sensor in to maby get a more accurate reading?
2000 White F250 PowerStroke 4X4 Off Road
6 Inch super Lift
38 Inch Nitto Muds
BushWacker Pocket Flares
Dick Cepek DC1's
AEM Bruteforce Intake
AutoMeter C2 Boost, Trans Temp, EGT
MBRP 4 Inch Turbo Back Up to 5 To 7 Inch GrandRock Miters
Edge Juice With Attitude Moniter(Just For Gauges)
Custom Programing From Jody DP-Tuner F5
Stock,No Start, High Idle, 80 Econ, 120 Race, 140 Agressiv
OverBoost Annihilator, HPX Cross Over Line IC Pipe Foil Delete MOD
Running Garret GTP38R Ball Bearin non WasteGated 1.15 Exhaust Housing
Transmisson Done by The Local Guy New Housing, Transfercase and Drive Line Factory 3.73's "All Heavy Duty Billet Steel Internals"
Pro Torq Stage Three Billet Torq Converter
Rhino Liner, 10,000K HID's, Black Diamond Eye Head Lights, Recon Running Board LED's, Remote Start, Dual 7 Inch Touch Screen In Dash DVD, 12 Inch JL Audio Sub, Rockford Fosgate 600 Amp
Still Get Smoked By 6.0's
But Whos Truck Do The Women Always Want to Ride in?
WyoTech 09
LoveTurbo is offline
post #17 of 21 (permalink) Old 01-03-2013, 10:17 AM
RT
RT's Avatar
I have my transmission temperature sensor in the same port you are using. I see about 40-60 degrees over ambient. For me, that means my transmission is running around 100 since we are in the worst part of winter now. I used to monitor engine oil temp, but found the numbers were always right on with what the EOT sensor in the HPOP was reporting to the PCM, so I changed that to engine oil pressure. When I was monitoring temp, it was always within 5 degrees of ECT once the engine warmed up. For me, that was 180 - measured at the port next to the oil filter.
I would contact your gauge manufacturer - something is seriously wrong either with your installation or your gauges.
RT is offline
post #18 of 21 (permalink) Old 01-03-2013, 10:49 AM Thread Starter
LoveTurbo's Avatar
My Photos: (60)
Well there's not much to go wrong with the installation it's just a wire from the sensor to the gauge lol I think this gauge is twisted its gotta be
6 Inch super Lift
38 Inch Nitto Muds
Dick Cepek DC1's
WyoTech 09
post #19 of 21 (permalink) Old 01-03-2013, 11:05 AM
RT
RT's Avatar
True, but it is a resistance measurement so if one of the connections wasn't perfect, it could affect it. I had an instance where my trans temp would jump into the mid 200s and back every time I hit a railroad crossing. Turned out one of the crimp connectors didn't bite properly.
RT is offline
post #20 of 21 (permalink) Old 01-10-2013, 02:32 PM
As RT said some of the Autometer guages need the threaded body of the sender to be grounded. My Ultralight directions say that the threaded body of the sendor(not where the sender wire hooks up) might need to be grounded. I'm about to wire in my trans temp guage, I'll post up with results.
DelRey
NorthIdahoMudandCrawl.Blogspot.com
2001 F250 7.3 4x4 4r100 Shortbox Crew
Ford AIS filter, 31 Row 6.0 cooler
Dieselsite Trans filter, Dieselsite 203* Thermostat
Autometer EGT/Trans/H2O Temp guages
4" MBRP Exhaust, Seatbelt minder mod
CCV mod, RuffStuff 10.5" Diff cover, RiffRaff HPX
Firestone Ride Rite airbags
DP Tuner
delreyr is offline
post #21 of 21 (permalink) Old 01-10-2013, 05:21 PM
My Autometer Ultralight trans temp guage did not need a ground wire on the sender to function properly FYI. It has the one sender wire going to the sender and that's it. Hope this helps.
DelRey
DP Tuner
delreyr is offline
